Vashon Samba Member
Joined: September 23, 2012 Posts: 200 Location: Vashon Island
Posted: Sat Jul 10, 2021 12:29 am Post subject: Coolant pipe replacement with hose instead? |
Okay ,before anyone tells me there are other threads on this subject. In fact I typed in "coolant pipes" and got 2297 hits on Samba. A bit over whelming but a comfort to know there are people whom care about these things.
Ok my coolant pipes are original,old and cracking length wise .no doubt about it being time to replace them, did I mention begining to drip? They did their service and its time to retire them.
The business question I have is after doing homework Stainless pipes are the overwhelming consensus. Ok I can see that ,but why have pipes at all?
I am boat guy by trade and running long lengths of heater hose is common in many yachts . Granted these are from the engine block to aux heaters,ect. and not engine to radiator. With modern higherend heater hose maxing out at 500 degrees Heat is not an issue. Is it fear of kinking or sagging, or? . It just seems it would be easier to run and alot less connections,hose clamps and probably less expensive.
Iam not trying to buck convention just wonder why pipes at all?
Tim
'87 westy |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Sat Jul 10, 2021 4:20 am Post subject: Re: coolant pipe replacement |
Much more vibration and chafe on a car than a boat
Add in ozone , heat, and road debris and it’s a different set of dangers to mitigate. _________________ .ssS! |
danfromsyr Samba Member
Posted: Sat Jul 10, 2021 4:54 am Post subject: Re: coolant pipe replacement |
yeah but the 1.25 & 1.5 marine exhaust hose is some fairly awesome hosing.very durable out weave to it.
secure it nicely and protect from chafing where it passes sharp edges. with some edge trim (even VW used edge trim in some places) or thin plastic sheeting.
it'll be fine. _________________
Abscate wrote: |
smeeegheeead Samba Member
Joined: February 19, 2021 Posts: 48 Location: Portland, OR
Posted: Sat Jul 10, 2021 7:20 am Post subject: Re: coolant pipe replacement |
Running the stainless kit from gowesty is not too bad and a worthy upgrade. Dropping the tank in order to run the lines/re installing the tank is much more of a pain than the rest. |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Sat Jul 10, 2021 7:26 am Post subject: Re: coolant pipe replacement |
I used marine coolant hose to connect to the belly radiators on the two bay window conversions I've done. Worked fine. |
BlueTwo Samba Member
Joined: June 09, 2014 Posts: 63 Location: North Vancouver, B.C.
Posted: Fri Jul 23, 2021 1:21 am Post subject: Re: Coolant pipe replacement with hose instead? |
While waiting on various suppliers, GW, VC, BD to have a SS replacement available I'm looking for some advise to slow/stem a drip leak at the join of the insert of the lower rad hose to the coolant return pipe.
My best layman hope is with a thorough wrap of HVAC duct sealing foil tape.
Any other experienced suggestions appreciated. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Jul 23, 2021 1:54 am Post subject: Re: Coolant pipe replacement with hose instead? |
BlueTwo wrote: |
No. Use the "Silicone Rescue Tape" and put Zip-ty's at each end of the tape so no accidentally unwinding. Works 100% better then other tapes and was made for leaks.
You can find it in Home Depot or Amazon _________________ This free advice is worth exactly what you paid for it.
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri Jul 23, 2021 3:53 am Post subject: Re: Coolant pipe replacement with hose instead? |
Vashon wrote: |
Okay ,before anyone tells me there are other threads on this subject. In fact I typed in "coolant pipes" and got 2297 hits on Samba. A bit over whelming but a comfort to know there are people whom care about these things. |
That’s funny & amazing😄
A parts van I bought from a handy man in a boating town used marine hose.
It seemed like really tough stuff. Maybe it was marine exhaust hose, it was really thick & heavy.
At the time I looked into the cost and it was quite high, but I could buy it locally so no shipping - which with the size and weight of the hose in that van would have been quite high.
BTW-here’s the search syntax to use to use in the future.
Maybe it will knock it down to 457 hits😄
site:thesamba.com vanagon coolant pipe marine hose _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Fri Jul 23, 2021 4:33 am Post subject: Re: Coolant pipe replacement with hose instead? |
Looks like it is the same tape. Just be sure to add the zit-ty at the end wrap. It holds really good, but the zip-ty is a safety backup for it. _________________ This free advice is worth exactly what you paid for it.
kamzcab86 Samba Moderator
Posted: Fri Jul 23, 2021 8:51 am Post subject: Re: Coolant pipe replacement with hose instead? |
Steve M. wrote: |
No. Use the "Silicone Rescue Tape"...
You can find it in Home Depot or Amazon |
You can also find it at your local auto parts store. _________________ ~Kamz
2016 Golf GTI S
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Fri Jul 23, 2021 10:38 am Post subject: Re: Coolant pipe replacement with hose instead? |
i ran SS pipes in my build, but on the heater core lines and others, i opted in putting them all in a abrasion resistant sleeve. Id imagine this will work out in the end.
ran silicone through and through, but silicone isnt super resistant to wear _________________ -------------------------------------------------
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight= |
Merian Samba Member
Posted: Fri Jul 23, 2021 1:16 pm Post subject: Re: Coolant pipe replacement with hose instead? |
Various pipe kits exist and are a proven solution.
But I always encourage others to experiment on their vans _________________ .... |
Posted: Sat Jul 24, 2021 1:36 pm Post subject: Re: Coolant pipe replacement with hose instead? |
Before the Silicone Rescue Tape I'm wondering what the community thinks about a liberal application of PVC glue first? |
Posted: Mon Jul 26, 2021 12:46 am Post subject: Re: Coolant pipe replacement with hose instead? |
*tap tap*
Is this thing on? Can you hear me in the back? |
?Waldo? Samba Member
Posted: Mon Jul 26, 2021 8:08 am Post subject: Re: Coolant pipe replacement with hose instead? |
Vashon wrote: |
Okay ,before anyone tells me there are other threads on this subject. In fact I typed in "coolant pipes" and got 2297 hits on Samba. |
If you check the little box for 'Title Only' it searches only the titles of threads for the query 'coolant pipes' and the result is reduced down to 139. Add the word 'hose' so that the the query is 'coolant pipes hose' and the results go down to 11 threads with this one matching yours very closely:
https://www.thesamba.com/vw/forum/viewtopic.php?t=644526&highlight=coolant+pipes+hose
Going to the sticky FAQ thread then to "Engine, Cooling, Fuel, Exhaust, Ignition, Electrical" and then to the cooling system section will lead you to the thread that djkeev linked. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Mon Jul 26, 2021 8:37 am Post subject: Re:Coolant pipe replacement with hose instead? |
BlueTwo wrote: |
*tap tap*
Probably kinda silent because members want to hear about the hose method and are avoiding blowing Vashon's post off-topic.
Aging coolant pipes is a common, and serious problem, as such there are lots of threads. Perhaps too many?
If you look thru them you might find your answer and if you need to post there’s probably a thread titled well for your Qs.
I'm sure you will get lots of help!!👍🏽 _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon Jul 26, 2021 3:31 pm Post subject: Re: Coolant pipe replacement with hose instead? |
Thanks for the heads up, didn't realize the drift until you mentioned it.
Just saw your 10 year update -most informative - and will do a more focused search. |
