RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Sat Jan 21, 2023 2:51 am Post subject: Re: Nova Scotian 54 standard restoration |
Plug A is on early buses too - at least 1952s (Hornbecker)
It is like (prob exactly the same as) the two Beetle rear apron plugs, and the bus sunroof corner plugs
While we’re here…my ‘55 has rubber buffer B on the vertical
This is exactly the same as the 4 seat buffers
What is buffer B for?
I don’t see it on some 54s…so it must be a late Barndoor revision
Your bus must have it, EB
_________________ -StockRocks- |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2013 Location: SW Nova Scotia, Canada
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
Posted: Sat Jan 21, 2023 1:08 pm Post subject: Re: Nova Scotian 54 standard restoration |
Starting to turn this guys thread into a mystery
I was poking around at some 55 images and so far have only found a couple(this area is not a very photo interesting area until now)
My old Dec. 54 Crappingbox Standard , I happen to have an image , does not have the "B" hole but surprisingly did still have the rubber "A" plug in place , which ive never noticed.
The PBRDD Panel, a Jan 55, is the same, no "B" hole.
Making me wonder if the "B" hole is a Deluxe only thing.
Here is another image I came across of the Mo & Domsjo 55 which does appear to have an extra hole but doesnt look to be in the same place as Rockstocks.
_________________ www.thebustransfer.com
Whaaaaat? |
Posted: Sat Jan 21, 2023 3:00 pm Post subject: Re: Nova Scotian 54 standard restoration |
Started stripping off the frame.
Quick work. Rear frame is better than I thought.
Got the pedals and park brake lever out. I drilled a hole in the left frame to drive the pedal pin out. That bit of frame needs work anyway. I didn't realize the pin had plugs in the ends and I drove one in a bit. Will need to fix that.
Park brake lever is in great shape. Cables are usable also but may be a bit ruff for what I want. The tubes were full of grease.
I need to do some more drawings before going much farther on the front.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2171 Location: Graz, Austria, Europe
Posted: Sun Jan 22, 2023 6:43 am Post subject: Re: Nova Scotian 54 standard restoration |
^Great to have all these rare pieces!
according the rubber plug and hole.
That could make a lot of sense. We know that many parts on early Volkswagens have asymmetrical 'drip holes' or recesses in stamped parts ( like the beetle frame head f.e.) so that trapped paint from primer dipping could drain out. Would make more sense even, if the bus bodies were dipped with a slight angle to the right and to the front. primer could easily get trapped in that corner of the tool chest.
BeaterBarndoor wrote: |
Interesting to see there was a plug there. Just last week I was asking around to confirm this was factory and not a hack on my bus(although I found images of my older buses with it as well)
It seems the only logical reason for it was drainage maybe? Certainly odd for just one side. |
_________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
myklsmyth Samba Member
Posted: Mon Jan 23, 2023 3:51 pm Post subject: Re: Nova Scotian 54 standard restoration |
Enjoyed the first video so far! Even the raw footage is important to document the little differences and be able to have a reference for rebuilding, not just for you but for those of us who have a project as well. |
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5505 Location: 1st Coast
Posted: Thu Jan 26, 2023 3:14 am Post subject: Re: Nova Scotian 54 standard restoration |
Outstanding video documentation and to feel a part of your build. I love your shop/barn. Great way to start the morning with your build. Thank you for taking the time to do this. I’m sure it will help others in their builds too.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Thu Jan 26, 2023 8:24 am Post subject: Re: Nova Scotian 54 standard restoration |
Those videos are great! I'm looking forward to seeing your metalworking skills. The accent is making me a little homesick _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
Two Glove Boxes Samba Member
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Tue Feb 28, 2023 5:10 am Post subject: Re: Nova Scotian 54 standard restoration |
Great work! Following along from Ontario. If you end up with a spare tube tranny hanger, even a part, please let me know. I need to patch one on a 55 bus. |
