simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Mon Jul 12, 2021 2:53 am Post subject: rear wheel axle nut torque in real units |
so, for a swing axle, in numbers I can understand, 217 ft-lbs is 294Nm
so if I have a 2m long extension, I apply 150N or 15kg (rounded) is that right? it doesn't seem much |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Mon Jul 12, 2021 7:01 am Post subject: Re: rear wheel axle nut torque in real units |
Your arithmetic is easy enough to check, and you're correct. It doesn't seem like much force, but I know none of my joints could take it. |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Mon Jul 12, 2021 4:17 pm Post subject: Re: rear wheel axle nut torque in real units |
before I had a torque multiplier, I used to stand on the bar about 14 inches out, as I was around 200 lb, and gave a gentle bounce for 'good luck' |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
misterh Samba Member
Joined: May 03, 2018 Posts: 23 Location: Central Texas
Posted: Tue Jul 13, 2021 8:32 am Post subject: Re: rear wheel axle nut torque in real units |
simon varley wrote: |
A 2m extension is pretty long. |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Tue Jul 13, 2021 4:17 pm Post subject: Re: rear wheel axle nut torque in real units |
I have a 250lb torque wrench. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Tue Jul 13, 2021 4:56 pm Post subject: Re: rear wheel axle nut torque in real units |
misterh wrote: |
yup - it's what I needed to undo the nut after fifty years |
Posted: Tue Jul 13, 2021 4:57 pm Post subject: Re: rear wheel axle nut torque in real units |
jeffrey8164 wrote: |
I have a 250lb torque wrench. |
Jeez, I'd need a floor jack to lift that wrench , but if you're 6'6" tall and have 33lb boots you're good to go on an axle nut! |
Posted: Sat Jul 17, 2021 1:00 am Post subject: Re: rear wheel axle nut torque in real units |
I present.......
......the 300Nm torque wrench
Posted: Sat Jul 17, 2021 1:30 am Post subject: Re: rear wheel axle nut torque in real units |
Simon, thats a bit of good old Aussie ingenuity |
