MicBergsma Samba Member
Joined: October 25, 2015 Posts: 222 Location: Maui Hawaii
Posted: Tue Jul 13, 2021 8:00 am Post subject: Photos of rear backing plates |
Aloha everyone,
I am wondering do y'all have photos of rear backing plates to share (driver and passenger side) ?
I want to make sure I have correct one
Thank you!
_________________ 1967 VW Bus walk-thru 21 window deluxe
Restoration series on YouTube right now!
YouTube videos > http://bit.ly/2g0E5b5
Instagram > http://bit.ly/2gHjIOV
Facebook > http://bit.ly/2Q9atMs |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Jul 13, 2021 8:53 am Post subject: Re: Photos of rear backing plates |
The “Ty III” leads me to think no. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Tue Jul 13, 2021 9:30 am Post subject: Re: Photos of rear backing plates |
Those are indeed Type 3 backing plate(s).
I actually have late Type 3 rear brakes on my '73.
The drums are of a larger diameter than the stock Thing drums, and the shoes are wider than the stock Thing Type 1 shoes.
The Type 3 wheel cylinders are different as well; the difference is in the mounting "ear" where the wheel cylinder is bolted to the backing plate.
However, the wheel cylinder bore diameter is the same as that of the stock Thing rear wheel cylinders.
Hand brake cables and associated hardware is the same as that on a stock Thing.
If you choose to mount standard Thing backing plates instead of those, don't just throw those away; they are a somewhat "in demand" item.
Good luck, Mondshine |
FJBLF Samba Member
Posted: Tue Jul 13, 2021 4:18 pm Post subject: Re: Photos of rear backing plates |
There are two types, depending on the year of your car. they changed in the middle of 73.
If your car serial number higher than 183 2346 525 then your part numbers are:
113 609 440 E for the Rigth
113 609 439 E for the Left
If your Serial number is lesser than the above, then you need the older style like I do on my 72. take a look at my video.
_________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Wed Jul 14, 2021 7:28 am Post subject: Re: Photos of rear backing plates |
I got two rear drums number is 181 501 615A… any idea what exactly backing plate to work with? _________________ 1967 VW Bus walk-thru 21 window deluxe
FJBLF Samba Member
Posted: Wed Jul 14, 2021 6:26 pm Post subject: Re: Photos of rear backing plates |
MicBergsma wrote: |
I got two rear drums number is 181 501 615A… any idea what exactly backing plate to work with? |
That Drum # corresponds to the newer version. I assume your serial number is later than the number I listed above. So you have CVJ's instead of GRB's
If that is the case, you should use the part numbers I listed above, not the once on my video. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Thu Jul 15, 2021 2:35 pm Post subject: Re: Photos of rear backing plates |
sorry, I didn't put enough info in my post...
I don't have a Thing... I have a 67 bus that I am lowering 3.5" with 68 beetle's straight axles and upgrade rear brake with Thing brake system...
I got drums, shoes, and all the parts from The Thing Shop online... only thing I don't have backing plates so I am searching to get the correct ones... a guy have some plates and asked me to send photos to match what he has before ship to me _________________ 1967 VW Bus walk-thru 21 window deluxe
FJBLF Samba Member
Posted: Thu Jul 15, 2021 4:13 pm Post subject: Re: Photos of rear backing plates |
MicBergsma wrote: |
I got drums, shoes, and all the parts from The Thing Shop online... only thing I don't have backing plates so I am searching to get the correct ones... a guy have some plates and asked me to send photos to match what he has before ship to me |
Ohhh Wow!!!! You are "Frankeinstaining" something... Did your Bus had GRB's (Gear Reduction Boxes) Are you changing your Gear Box? or are you rotating your Dif?..... anyways.... too many questions ... sorry.....
The Drums you got need the newer style Back Plate.... which are the once I listed abobe. Your springs are also different, take a look at my video. On your set up the springs go between the shoes, on my set up the springs go to the backing plate.... you also need the parts for the Emergancy Break. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Thu Jul 15, 2021 5:45 pm Post subject: Re: Photos of rear backing plates |
‘69 up Beetle backing plates will work with that combination. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Admiral Fishwich Samba Member
Joined: May 06, 2011 Posts: 23 Location: Ontario, Canada
Posted: Mon Jul 26, 2021 8:02 am Post subject: Re: Photos of rear backing plates |
