BlueBounty Samba Member
Posted: Tue Jul 13, 2021 12:14 pm Post subject: Plugs foul on 1&3 only need help |
I cant seem to fix this issue. I have a 1776 with duel Kadrons rebuilt by I pro builder. I'm running Compufire with a vacuum advanced 009. I have the carbs jetted and set with a fuel ratio meter. My problem for ever is it runs great until the plugs on #1 & 3 foul. Then of course is starts sputtering and back firing. 2 & 4 look great. I can't seem to figure this out. I could see maybe an adjustment problem on one of the carbs if the fouled plugs were on the same side but this not the case. Can anyone help me out on where to go next?
Thanks |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Jul 13, 2021 12:22 pm Post subject: Re: Plugs foul on 1&3 only need help |
real common issue with dual-single barrel carbs like Kadrons.
Magnified when you go with a hi-po camshaft.
Can usually be managed by adding a balance tube from one manifold to the other.
Your manifolds likely have fitting bosses in them already.
Try to use 3/8" or 1/2" hose.
It should "help" your problem. |
Dauz Samba Member
Posted: Tue Jul 13, 2021 12:55 pm Post subject: Re: Plugs foul on 1&3 only need help |
those things idle on two cylinders. The balance tube like Tom mentioned should help |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Tue Jul 13, 2021 12:57 pm Post subject: Re: Plugs foul on 1&3 only need help |
I always get a chuckle out of engines that run great but...
I suspect it's not, and has the same 2 cylinder idle/4 cylinder run mid range and up that I too had when running Kadrons. I played with them with a balance tube and without and quite frankly just wasted time and effort. If I got a good synchronize on the carbs it would run virtually identical with the balance tube on or blocked off. The best I ever got it was a 4 cylinder fast idle coming off a hard run that would drop back to 2 cylinders as the engine cooled off before the lights turned green again.
What that made the most difference of all the things I tried was to put the thermostat and flaps back on so that the engine ran warmer around town and at a more consistent temperature all around. Very hard to tune one that is hot - cold - hot - cold especially with Kadrons on it.
I was at a VW event 3 weeks ago and after talking to a Beetle owner about his Kadrons (he assured me that his did not have this problem and ran perfect) I listened to his wife idle it around the parking lot and out onto the street... on 2 cylinders and heard it clear up and catch the other 2 as she drove away! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1058 Location: St. Louis
Posted: Tue Jul 13, 2021 1:22 pm Post subject: Re: Plugs foul on 1&3 only need help |
What is your idle ignition timing, cam, and compression ratio? _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Tue Jul 13, 2021 2:35 pm Post subject: Re: Plugs foul on 1&3 only need help |
BlueBounty wrote: |
Hmmm! No such thing. Are you referring to a "034" SVDA copy distributor?
Thanks |
Kads can be set up to run well. Sadly not many know how, not even engine builders/tuners. That said, We need to know more to be able to get an idea about what to do and how good we can make it.
Cam
CR if you know. (Builder should state that.)
Ignition coil and the exact type of distributor, - and spark plugs.
Ignition timing at idle.
Type of exhaust
Type of intake manifolds
What AFR at idle, cruise and WOT?
Where do you take the AFR reading?
I probably forgot something, but this will be a good start. A couple of pictures may tell more than a thousand words, especially if youre in doubt.
On a second note, I´m not super fond of the balance tube as a means to solve varius issues. - Sometimes, it is possible to even out an issue that way though.
Let us hear ya! _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Tue Jul 13, 2021 4:25 pm Post subject: Re: Plugs foul on 1&3 only need help |
Thanks folks for the info. Let me gather the specs and post some pictures and maybe we can figure this out or I might just go to a single carb for reliability but my bounty hunter does not fair well for that as it has a overhang on the back and not much clearance. Stay tuned. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5412 Location: Holland, MI
Posted: Tue Jul 13, 2021 4:45 pm Post subject: Re: Plugs foul on 1&3 only need help |
Cam will be the biggest factor in if you can get the mixture evened out on those dual single barrel carbs with a balance pipe. As duration goes up, and overlap increases, the vacuum signature changes in the manifolds, and the balance tubes effectiveness drops off like a rock. On stock to mild cams, balance tubes can work wonders. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
mark tucker Samba Member
Posted: Tue Jul 13, 2021 5:42 pm Post subject: Re: Plugs foul on 1&3 only need help |
also plug type and heatrange.have the plugs been heat range checked to see if they are right or not?? |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Jul 15, 2021 2:19 pm Post subject: Re: Plugs foul on 1&3 only need help |
I wonder what effect a 1" spacer under the carbs would have? it would give you a little more plenum area. Kinda like putting a open bore 1" spacer on a V8 with a dual plane intake manifold, it kinda makes it act more like a single plane manifold.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Jul 15, 2021 3:06 pm Post subject: Re: Plugs foul on 1&3 only need help |
I´m still waiting on engine details. Until we get that there is no telling what would be the best approach.
That said I agree on the plenum _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Fri Jul 16, 2021 12:21 pm Post subject: Re: Plugs foul on 1&3 only need help |
The problem is a fundamental design issue.
The firing order on a VW motor is un-even on each side.
First cyl 3 draws a charge in, then 4 air in, then a big pause as 1/2 side draws air.
So with any performance cam, 3 is still drawing air it, when 4 starts.
This robs 4 of some charge. Enough that it won't hit at idle.
The 1/2 side has the same issue.
So you get the 1/3 idle thing.
A balance tube can help to stabilize the vacuum, much like a plenum would.
The problem with plenums is always the same. It's a band aid to mask a poor manifold design. Plenums have to be jetted around and they usually suck fuel.
It is for this reason, you won't find may dual/singles on my motors.
I find it much easier and smoother running to just install a set of dual IDF's.
they actually run smoother and get better fuel economy. |
Posted: Fri Jul 16, 2021 1:55 pm Post subject: Re: Plugs foul on 1&3 only need help |
OK, how about putting two Kadrons on a IDA manifold on each side of the motor?
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Jul 16, 2021 2:35 pm Post subject: Re: Plugs foul on 1&3 only need help |
Only if you build the linkage _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Fri Jul 16, 2021 8:11 pm Post subject: Re: Plugs foul on 1&3 only need help |
earthquake wrote: |
eQ |
Quadrons, the world wants to see it! I asked KadyShack about this, they laughed and said they would love to try it when they have time. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
Janne71 Samba Member
Joined: September 29, 2015 Posts: 127 Location: Sweden
Posted: Sun Jul 25, 2021 12:23 pm Post subject: Re: Plugs foul on 1&3 only need help |
BlueBounty wrote: |
Thanks |
Hello
I’m in same problem whit my 1776 and kads on empi alu intake. Run a tube between intake and that’s not enough. The plug does fouling but not like very blackish and 2 and 4 are looking lean. Have you notched the intake against the head like the standard manifold DP engine? I’ll read something like that in the samba but it’s several years that’s been writing
Somebody else that have tested with notched kads carbs
Hav standard camshaft and cr like 8.5:1 |
oprn Samba Member
Posted: Sun Jul 25, 2021 12:52 pm Post subject: Re: Plugs foul on 1&3 only need help |
The only 2 carb set ups that don't have this mixture imbalance in my limited experiance is a single center mounted one or give each cylinder it's own carb barrel. Even the stock twin singles were somewhat this way. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Jul 25, 2021 1:04 pm Post subject: Re: Plugs foul on 1&3 only need help |
oprn wrote: |
The only 2 carb set ups that don't have this mixture imbalance in my limited experiance is a single center mounted one or give each cylinder it's own carb barrel. Even the stock twin singles were somewhat this way. |
Ok what’s the meaning with the notch. Is it to make engine run on all cylinder at light running like cruising |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sun Jul 25, 2021 6:49 pm Post subject: Re: Plugs foul on 1&3 only need help |
the notch at the intake gasket surface is for single carb manifolds IMO.
Properly shaping the plenum area right below the carb is more important for this type of carb setup. You PROBABLy want to make sure it splits evenly both sides. The fuel also should IN THEORY come straight out the lower hanging side of the throttle and you can look at the manifold and think about where that is going to go, what it will hit.
Weird plug fouling without any other cause can often be traced to liquid gasoline dribbling into one cylinder or another. It could be a manifold problem or a carb problem. Float level is too high causing the main nozzle to drip, or acc pump squirt mis-aimed it can run just fine but still be fouling plugs. I don't know which is more likely the problem but these units do have a reputation of having problems with both. |
