fredybear Samba Member
Posted: Wed Jan 19, 2022 4:48 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
New pan bolts, forgot someone took all the bolts and things in the junkyard
Who needs brakes anyway Crap, I drove beetles with no brakes, a brake cylinder blew out with like 10 peops in the beetle E Brake and shifter.
Deliverin pizza with my honda and the metal snapped that connects the pad, Cause I drive-m till they grind, no brakes. ebrake and shifting finished the deliveries.
We should be running this weekend |
Posted: Thu Jan 27, 2022 5:18 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Forklift Damage
Straghten it out and weld it back in
Posted: Sun Jan 30, 2022 6:09 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Anybody wanna go for a ride
Gettin the juices flowin, turnin it over and herd that splu-put. Its ready tooooo goooo
Notice the broken axle look Sumptins Up, hmm
Maybe I should just take it all back apart and redo it, hmmm |
Posted: Sun Feb 06, 2022 1:25 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
It sounds like a Nasty Beetle I call it Deep Throat
Posted: Fri Feb 18, 2022 6:03 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Who got Seat Belt Meeee
who need a retractable , bolt in 1 belt for fitty dola YO
Tomorrows a good day to roll, got a 1 day temp, good till ya get caught
BUT
Look whos a failure, a looser, a waste of space, good for nothong, worthless and weak, useless, wait, I agree with useless
A leak, why O why, help
I was so excited, I forgot to tighten the pump cover fully and it started leaking. UGG . It was snug for fitment. Pretty Brass
Tightened it up, Now lets roll the Beetle. Well its gonna be around 76 tomorrow, think its too cold????
Just need to get too triple A for the vin verification. |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4423 Location: Stuck in Ohio
Posted: Sat Mar 19, 2022 12:10 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Im Back Baby After flooding my carbs and having beetle trauma.
Covering the stacks, woops. Choke, gasp, puke
How to de flood the sleezy method One drop in that compartment and look out. Be careful when doing this.
Short stacks and covers should work beautifully
After the choking and coughing, it was purring, while it drained the carbs to correctness |
Posted: Tue Mar 22, 2022 12:26 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Taking the motor back out. Why, Cause I have to repolish all the chrome
No, why again. Whinning in the clutch area. What did I do now
Rear Bolt Abuse. What happenes when your JB Weld breaks
Lets have some fun with this one. Sepcially worse when you have no help..ugg
Socket, ugg ... Hows that for coolness
Lock er in place
Why O Why
Anyone ever made this mistake.??? Next up, what went wrong... |
Posted: Tue Mar 22, 2022 3:44 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Fried Bearing The stink is a strange one
Posted: Tue Mar 22, 2022 5:08 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Can anyone guess what I did wrong
Lookie
The oil in this stinks. It has a nasty odor when fried
O wait, he was supposed to put the single port in with matching pressure plate. But. Lets be cool and put the HiPo Motor that belongs in a swing axle.
What happens when you dont pay attention. Good thing its just a minor BOO BOO
WOOPS |
Posted: Tue Mar 22, 2022 6:08 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Whos gonna be back in bidness
PoP The Ring Off like so
and reinstall. This time will be the best time cause everything will be Perfect Plus repolishing all my Chrome.....
I made sure I marked a line for the balancing, just in case any bodies wondering Good thing I have extra bearings |
Posted: Tue Mar 22, 2022 6:27 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Im goin insane today. To have the engine running on Sunday and completely back out on Tuesday would make most people crazy
Im so used to double and triple job, if it went right the first time, I would think something was wrong
Notice some differences |
Posted: Wed Mar 23, 2022 5:02 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
I still don't get the drip, gasket is fine. I think the red one is too thick anyway. Switch to the white one.
Look at that full flow system. Aint that cool.
Im on a mission--- and im wishin-- I can-- get this-- in drivable condition |
RLFD213 Samba Member
Posted: Wed Mar 23, 2022 6:19 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Do you have the o-ring installed also? And you can’t use some permatex on the paper gasket. Also maybe take a straight edge and make sure the cover is not warped at all. |
Posted: Sat Mar 26, 2022 3:53 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
RLFD213 wrote: |
I did it, I think. No O ring, just gasket. We will soon find out.
Clutchie all better
Cone ground and fixed Add new bearing
And for the hack and sleaze club
Who loves some sleeze JB Weld on the nut |
Posted: Thu Apr 14, 2022 6:48 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Useless Updates
Polyed the back of the bumpers
Installed engine. Much smoother without the sticking disc Plus short stacks with air cleaners works beautiful.
Check out the cool Horn from HF.....OOOO Its loud right there
Posted: Sun Apr 17, 2022 10:39 am Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Before I crash and die from brake failure
Betrix goes in.
Letting the fluid drip dry. |
Posted: Sun Apr 17, 2022 12:21 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
Can you believe that went in in like 5 minutes
WOW
Bietrix Loves Me Tighten and a fill and we are done.....
Whata Sunday |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Apr 17, 2022 1:34 pm Post subject: Re: 1971 Beetle Restoration (The Junkyard Bug) |
What are you doing with that JB weld? You know there is a threaded insert that goes in there right? |
