MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Fri Jul 16, 2021 1:10 pm Post subject: Intermittent temperature gauge flashing (again) |
I've looked through a bunch of threads on this issue but none seem to be quite like my situation.
My temp warning light starts flashing when I'm accelerating or otherwise have the engine under load, say downshifting to 3rd on a hill. When I let up on the gas, even the smallest amount, and return to cruising speed, it stops flashing. It mostly seems to happen between 3-3,500 rpm though not always; sometimes it's a bit lower. I'm thinking perhaps its simply a loose wire in the circuit somewhere that wiggles more when the engine is working. I repaced the wiring for the temp gauge this spring after packrats chewed it up. Grrr... If I recall a post from tencentlife, there are two circuit there, one for the gauge and one for the blinky. As far as I can tell, my gauge doesn't move.
This has become more important lately as my oil temp gauge isn't functioning at the moment (oil pressure gauge is OK) so the water temp is the only thing I can monitor. This makes me nervous.
I did see that air in the coolant lines can cause the problem and I did have the cooling system flushed this last fall and this was the first time I've run the van since then. Perhaps..but any other thoughts are welcome. _________________ 1984 Westy with tencentlife power! |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Jul 16, 2021 1:49 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
you're coolant level is dropping at higher RPM's so the light comes on
i'm betting you're low on coolant _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
turbotype1 Samba Member
Posted: Fri Jul 16, 2021 1:58 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
skills@eurocarsplus wrote: |
i'm betting you're low on coolant |
THIS ^^^^^^^^^
Just went through this myself. I had just had my waterpump replaced as well as a coolant flush. A few days later light started flashing at weird times. Coolant was low.Topped it off and good to go now. _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
Posted: Fri Jul 16, 2021 7:02 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
Actually, if anything my coolant level is too high!. Before I left on my trip on Wednesday AM I checked the coolant lever and I couldn't quite see the level through the 37 y/o old plastic container but it looked as if it was below the "max" line so I added a little H2O. Then I saw it was actually actually above the max line by about a half-inch. Would too much cause a similar flashy result?
So it was doing the flashing thing both before and after the coolant addition. Hmmm.... _________________ 1984 Westy with tencentlife power! |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Fri Jul 16, 2021 7:50 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
No Max line on the coolant reservoir - expansion tank in the engine compartment on the driver's side. Only max line I know of is on the overflow bottle behind the license plate. The blinking light low coolant sensor is in the reservoir tank. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
4Gears4Tires Samba Member
Posted: Fri Jul 16, 2021 9:28 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
MootPoint wrote: |
So it was doing the flashing thing both before and after the coolant addition. Hmmm.... |
You might have a bigger issue here. First things first, there are 2 containers that hold coolant. I call the one only accessible from the engine bay the reservoir and the one accessible from the license plate the expansion tank. (Hopefully people agree with the terminology, please correct me otherwise.) You're adding coolant to the expansion tank and this is doing nothing to the coolant in the system.
What you need to do is take the engine cover off and find the reservoir, it has a blue cap. Take the coolant line off it and remove it. Check the coolant level in this tank. It needs to be 100% full. If it's not full, have a friend start the van and hold the engine at 2000rpms. Then you add coolant until it's full and replace the blue cap. Once the cap is back on tight, shut the van down.
Before you reconnect the line to the blue cap, make sure you drain down the expansion tank ( the one behind the license plate) to about half full, to the max mark. You can use the line directed to a container to drain the tank. Once the level is appropriate, reconnect the line. _________________ '87 Syncro
SurfaceRust Samba Member
Joined: January 24, 2016 Posts: 160 Location: Los Angeles
Posted: Fri Jul 16, 2021 9:48 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
I agree with the above. It sounds like you are adding to the expansion tank and you need to add to the reservoir.
You could start the van with the reservoir cap removed. Move the throttle in the engine compartment and watch the coolant level. It should drop, and is probably dropping below the minimum for your sensor. While giving it throttle add the coolant to the reservoir till full. Put the reservoir cap on quickly and let the throttle out. Problem should be solved. |
Posted: Sat Jul 17, 2021 7:22 am Post subject: Re: Intermittent temperature gauge flashing (again) |
Ha! Thank you! Having only owned the Westy for 15years (!!), my naive assumption has always been that since the expansion tank had the easily visible max/min marks that it was the indicator of correct fluid level. Silly me! As I mentioned above, I had the system drained and flushed last fall and perhaps the shop did not fill the reservoir fully or check it after filling.
Thanks. I check that out. If you don't hear back from me it's because all's well. I don't hang out here as much as I used to; I probably need to rectify that. _________________ 1984 Westy with tencentlife power! |
Posted: Sun Jul 18, 2021 6:56 am Post subject: Re: Intermittent temperature gauge flashing (again) |
I'm 99% sure it's their fault. They probably filled it all the way when the engine was off. If the engine is running, the fluid level drops. That's why it's important to fill the reservoir while the engine rpms are held at 2000rpms. Or use a vacuum to evacuate the system and then fill.
Hopefully they sort it out. _________________ '87 Syncro
Posted: Thu Sep 23, 2021 12:30 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
SurfaceRust wrote: |
Well, I thought that worked. The temp light flashed occasionally on the first trip after the "adjustment," though it was inconsistent: Same gear (usually 3rd), same RPM (around 3K) and same kind of road and hills - sometimes it blinked on, sometimes not. If I backed off just a bit it would stop and stay off...for a while. Still a bit concerning.
But I had it out for a couple-night trip the beginning of this week and the temp light started flashing again anytime it was under load and it did that a lot. That was on Monday. Checked fluid level while in the campground and the reservoir looked OK, though even when hot and under pressure it didn't appear to be evacuating into the overflow. Crossed my fingers and drove home yesterday, similar conditions and roads. The blinking never came on once, all the way home.
It sounds perhaps maybe more electrical than temperature but...what's the deal?
Thanks in advance. _________________ 1984 Westy with tencentlife power! |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Thu Sep 23, 2021 12:57 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
Ahh, so... The level in the expansion tank (the one NOT accessible from the licence plate door) does lower at higher RPMs. Further, the slightest leak somewhere can go unnoticed for quite a while, and this can lower the level a little more than usual. As per normal 'bleeding the coolant' you need to have both heater cores open (if you have two anyway, usually there is one under the rear bench, and one up front. Anyway, those can hold air, and if you turned on your heat, it could result in the level going lower. Funny thing about heat-up and cool down of the engine is that after getting to running, and cooling off, there should be a vacuum build up in the expansion tank, resulting in fluid from the overflow being sucked in. In that case, it would be self healing as you run/let cool the engine.
But, yes, check the wires that attach to the sensor that goes into the expansion tank, corrosion has stumped many a Vanagoner in the past.
My usual approach to bleeding is to back my rear up a bit of a hill, run the engine a bit with the expansion cap open, and add fluid there. Then run it a bit longer with the tank cap back on, and go open the radiator plug a little, doesn't need more than half a turn really, don't take it out, you'll loose it, and its hard to get back in anyway. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Sep 23, 2021 1:10 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
Thanks. I took out my rear heater core years ago; it was leaking and I never used it anyway here in the stinkin' desert. Plus I like the extra under-the-seat space. But I hadn't considered the front core. As mentioned up-thread, I had a shop drain and flush the system earlier this summer and I bet they didn't touch the front.
I expect the two-way travel of the coolant to and from the expansion tank and I was surprised that, even after warming up during my campground test that the residual coolant in the expansion tank was still cold. After driving it for an hour or so (light blinking occasionally), it was slightly warm, but not as hot as the overall coolant under pressure. I was wondering if the coolant "warmth" was simply coming from the engine heat, not the vacuum process.
Thanks for the info! _________________ 1984 Westy with tencentlife power! |
Posted: Thu Sep 23, 2021 1:14 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
Now that is a new bit of info right there. You might have a faulty thermostat.
Also, there are some add-on kits that can help bleed the system. One by intrepidoverland.com [shop , Vanistan] is automatic. Purdy cool...
Hope you get it sorted! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Sep 23, 2021 1:23 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
Thanks! I'm on very good terms with Chris/tencentlife/Vanistan as he build my engine, thought I don't think his bleed device existed in 2010 or he would have suggested adding it. So I'll check with him.
I considered the faulty thermostat but the front fan sees to kick in at times, just as it always has, mostly when idling for longer periods of time and runs for a while after I shut off the engine, also as it always has. And even the, the blinkly light doesn't come on, only when climbing under load.
Once again, thanks! _________________ 1984 Westy with tencentlife power! |
Posted: Thu Sep 23, 2021 1:35 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
If my light comes on at any time other than just after starting the van, I'm pulling over, removing the engine hatch, and checking my coolant level. I guess I'm just paranoid. _________________ '87 Syncro
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Thu Sep 23, 2021 5:02 pm Post subject: Re: Intermittent temperature gauge flashing (again) |
The trouble with the "low coolant level" diagnosis is that the circuit that turns on the light is "latching". Meaning that the light is supposed to stay on if coolant level is too low until the coolant level is back up again and you've turned the key off and then back on again. This is so that the system is sure to catch an intermittent low level and keep warning you until it's corrected. Works the SAME way if there is a faulty level switch or faulty (open circuit) wiring to the level switch.
I suspect it's faulty electronics in the temperature gauge which drive the light.
There is a fairly common situation with these electronics where the capacitor in the gauge gets "lazy" and won't keep the light from blinking. I've had this situation in my '87 Syncro for years. The way to diagnose the faulty capacitor is when starting the van, turn the key to the ON position and then WAIT 7 or more seconds before turning the key to the starting position. This gives the capacitor time to charge while there's no drain on it.
While the above condition is NOT the same as yours, it would be interesting to see if this delay while starting changes your light's behavior.
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
