The making of cylinderheads for an Okrasa engine on steroids
Page: Previous  1, 2, 3  Next
Alstrup
Alstrup is offline
PostPosted: Sun Jul 25, 2021 2:12 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
I do not want to reduce the stem strength that much. It is after all an older construction and the flow improvement is almost non existant.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
earthquake
earthquake is offline
PostPosted: Sun Jul 25, 2021 2:51 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Here's a old post I made 11 years ago [damm where does time go] about using Honda Goldwing [1975-79] valves and springs but I never went anywhere with it.
https://www.thesamba.com/vw/forum/viewtopic.php?t=437391&highlight=goldwing
Might give you another option?
eQ
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison]
TomSimon
TomSimon is offline
PostPosted: Mon Jul 26, 2021 9:41 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
For pistons, take a look at 1000cc iron head Sportster, they have an 81mm diameter (also available in .06" oversize, +1.5mm) a pop up dome close to the right shape to fit in the Okrasa head combustion chamber, and 20.1mm wrist pin.
If JE has a forge mold, you can work with their custom side of the house, and perhaps order the domes unfinished, maybe undersize pin bores as well.
Ball mill a 'kernel pocket' for the spark plug tip to reside?
Just tossing out ideas
2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer
Alstrup
Alstrup is offline
PostPosted: Mon Jul 26, 2021 10:29 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
I will take a look at those pistons. I need 83 mm bore though. But the pin height is great, maybe even a tad low.
W1K1
W1K1 is offline
PostPosted: Mon Jul 26, 2021 1:30 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
what about some type 3 1500s domed pistons?
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
Alstrup
Alstrup is offline
PostPosted: Mon Jul 26, 2021 2:19 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Good idea, but not enough dome for what I´m after when the time comes. The dome on those are about half of what I need.
Also, the domed 83 mm (1500S) pistons are hard to come by.
Alstrup
Alstrup is offline
PostPosted: Thu Aug 19, 2021 9:09 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Soo, Rome wasnt built in a day. Rolling Eyes
One step further.
New alu bronze seats installed for 37 x 32 mm valves. Chambers machined for 83 mm bore. This is max as you can see we juuust broke though here and there. Nothing serius, but this is it.
Next is getting the ports massaged so we can see if our simulations hold water.
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Thu Aug 19, 2021 9:30 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
May I ask where you purchased the alu/bronze seats?
I presume the benefit of using this material is head dissipation, yes?
Other than cost, what's what are the downsides of using this alloy?
Cheers,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Alstrup
Alstrup is offline
PostPosted: Thu Aug 19, 2021 10:21 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Not really any downsides that I know of.
We buy a 3 meter rod and cut what we need.
We make the seats ourselves. (Westspeed that is) I´m not that good with a cnc. In fact I am worth very little Rolling Eyes
earthquake
PostPosted: Thu Aug 19, 2021 12:05 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Can you use a surface gap plug for your spark plug problem?
eQ
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Alstrup
Alstrup is offline
PostPosted: Thu Aug 19, 2021 2:18 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
To recess the spark plug? I most likely could. But at this stage we are working from the point of view that we will make pistons which protrudes into the chamber, leaving as much as possible of the outer squish and make the center part "356 look alike" This way I can get a little of the benefits of wedge chambers and not suffer so much from the Hemi shape. Sort of like this _/ \_
if you catch my drift.
It will be a while until I get the next step done. I have gotten a new work contract with assisting in setting up a new Mazak cnc for cylinder honing 20 to 250 mm Shocked which will restrain me from working so much on engines for a while.
FritzCP
FritzCP is online now
PostPosted: Fri Aug 20, 2021 12:38 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Would an AC.net Super Squishy Piston top design work well with the okrasa (or stock 36hp) head chamber design?
Fritz Custom Products
Fritz 10 - Tin Screw Torquer
Fritz 124 - Crank Pulley Puller
Fritz 70 - 6306 Bearing Puller
Fritz 44 - Dizzy Puller
JeeWee
JeeWee is offline
PostPosted: Mon Aug 23, 2021 12:04 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
I love this topic~! Great work and awesome you do share the results!
1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm
chris fryer
chris fryer is offline
PostPosted: Sat Aug 28, 2021 3:50 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
So impressed with you sharing the infiormation and your knowledge, thumbs up.
1959 Karmann Ghia project https://www.thesamba.com/vw/forum/viewtopic.php?t=724633
1966 Morris mini Cooper S
1964 Morris Mini Cooper 998
1965 Porsche 912/6 https://porscheforum.com.au/topic/3826-australian-delivered-1965-912-restoration
5500
5500 is offline
PostPosted: Sat Dec 04, 2021 8:53 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Hello Alstrup. Wondering if you've done any more with these heads?
Alstrup
Alstrup is offline
PostPosted: Sat Dec 04, 2021 8:57 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
No. I´m swomped with work, so I have very little time to do VW stuff. I expect to make progress during the Christmas hollidays.
RWK
RWK is offline
PostPosted: Sun Dec 05, 2021 7:16 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Here is some info on the copper (bronze) alloy seats, guides and other components.
I use their material extensively in plastic tooling, this company started out with the alloys for industry and branched out into engine components.
One of the benefits of high copper alloys is that it work hardens, good for seats.
As Alstrup says you can purchase the material and cut your own.
http://www.performancealloys.net/MotorsportApplications.htm
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
sled
sled is offline
PostPosted: Tue Apr 12, 2022 2:48 pm    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
Hi Torben, any updates on this monster??
drive your split.
Alstrup
Alstrup is offline
PostPosted: Wed Apr 13, 2022 9:44 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
No. I got some issues I needed to adress, so the winter have been very non productive. But I am gearing up to start working on them again.
Matthew
Matthew is offline
PostPosted: Fri Apr 22, 2022 6:11 am    Post subject: Re: The making of cylinderheads for an Okrasa engine on steroids Reply with quote
One step further.
Are you planning to use modified 40hp 83mm cylinders?
1965 Beetle sedan
Click to view image
Page 2 of 3
