Scorpion1110 Samba Member
Joined: May 17, 2020 Posts: 43 Location: Maryland 21771
Posted: Sun Jul 18, 2021 11:55 am Post subject: Any secret tricks for removing seized Cheesehead screws? |
So I started removing the FI from the type 3. Pulled the Air cleaner and the passenger side injectors. Then started looking at the air intake. The vertical tin needs to come off held by 4 cheesehead screws.
Soaked them with aero-kroil. Tried a regular screwdriver for laughs. Yeah right. Not happening. OK lets try a stubby. I think I heard the screws laugh at me at that point
Ok, pulled a bit from my impact driver set, grabbed a socket and a 12"extension and a long handle 3/8 ratchet. Nothing. Went the opposite way. Nothing. More Kroil and hit the screws with a wire brush. Then a few raps from a brass hammer. Nothing/nothing/nothing.
Time for a beer break.
Now back to these @#@%^&% Cheeseheads. Any secrets? Haven't tried vice-grips yet because I am trying not to distort the head of the crew.
I have to say the Type III is an ornery little rascal.
I dropped a crate 350 in a friends 1972 C/10 last weekend and it was a piece of cake, but with the type III I cant get a darn screw out.
I feel another beer break coming.
Dave |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Sun Jul 18, 2021 12:34 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
If the engine is out of the car to you can reach it....the HAND impact driver properly used...with a 3lb hand sledge hammer...should either take the screw out or twist it flat off.
Try heating it to about 500F...try the classic mixture of 50/50 ATF and acetone on the threads. It should be hot enough to sizzle on the first few drips...apply a little as its cooling down. Try the impact driver again...with violence. If it does not come loose....then teh screws will never be usable again anyway. Just vise grip them which will usually twist them off. Ray |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Sun Jul 18, 2021 1:24 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
1/2" drive breaker bar gives you plenty of leverage as you hold the bit tightly to the screw!
I use this setup for Phillips head door bolts with a #4 bit. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
vwpieces Samba Member
Joined: March 23, 2005 Posts: 345 Location: UpHill BothWays, PA
Posted: Sun Jul 18, 2021 1:44 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
raygreenwood wrote: |
the HAND impact driver properly used...Ray |
Extension on the impact driver will reduce its effectiveness. Also most people do not understand how to properly use one. You need to load or twist the driver in the direction you want screw to turn, with out pushing the driver down. Now you hit it with a 2lb+ hammer.
Not saying you don't know how or are doing it wrong, but just my observations over the years. Might help others... _________________ 68 BUS
83 JETTA TURBO DIESEL
83 2dr JETTA 16V
81 Turbo Diesel Jabbit |
Posted: Sun Jul 18, 2021 1:49 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Thanks Mike.
Thanks Ray. Thats about the method I used for pulling the studs from my Lancia's exhaust manifold. Heat/Kroil and vice grips. I also keep a home brew bottle of ATF/acetone and will alternate.
In this case,
The second beer and an array of Vice Grips, worked them loose. I have a well-known vice grips fetish so I have about every type known to man. The front came loose with a combination of the bit driver and the vice grips. I was using a long 3/8 ratchet for leverage and one finally popped. Vice grips took care of the other.
However, the little rat in the back was a fight. I used a small set of line vice grips to finally get the sob to break loose. Then I could turn it by hand.
However, these were just the appetizers.
The main course was the two 13mm bolts holding the air intake on. The front came loose pretty easily. The back? I had every ratchet, extension, and swivel socket out. It finally broke with a 13mm deep, straight down with a 12" long quarter-inch wobble extension and an adapted long swing 3/8th.
Total Franken-tool set up.
I now know why everyone advocates keeping the FI, it's a nightmare to remove
Is going to be carefully packed away, and may get an encore at some point in the future.
The bottom line is I was being too careful. Take the cheezers out with vice grips and replace them as needed.
Is it acceptable to use some anti-seize when reinstalling? or does that create problems?
Thanks as always!
Dave |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7527 Location: Santa Cruz
Posted: Sun Jul 18, 2021 9:53 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Yes on anti-seize.. Love that stuff.
They make that high-temp copper kind - i use it on almost everything.
Pretty much anything that doesn't get lock tite... _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sun Jul 18, 2021 10:14 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Clatter wrote: |
Pretty much anything that doesn't get lock tite... |
Exact same method I use.
If it does not need locktite and is not some kind of very special fastener with inch-pound torque setting.....I sparingly coat it with anti-seize...and am mindful of the torque rating difference it may give certain bolt types.
The damn sheet metal screws....those and lug bolts are the very first ones I learned to religiously apply to. Ray |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Mon Jul 19, 2021 2:26 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Scorpion1110 wrote: |
Thanks as always!
Dave |
I've been replacing them with M6 hex head screws, in case I need to remove them again. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jul 21, 2021 5:24 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
So decided to pull the remaining four cheeseheads for the tins that needed to come off while I mess with the carb intakes. Three went peacefully. Number 4 put up a fight.
Was messing with vicegrips when I remembered these. These socks grip and remove pretty well. Tapped it on old Cheezy and gave it a turn with a 3/8th ratchet and it was out.
Just an idea if you get stuck.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Wed Jul 21, 2021 6:07 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
A good penetrating oil, sprayed 3 times a day for a day or tow and heat. Try turning it clockwise first to break the bond.
I take pride in disassembling an old engine and not snapping a single stud or screw. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jul 22, 2021 1:17 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Are these from Lowe's? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jul 22, 2021 1:30 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Bobnotch wrote: |
Are these from Lowe's? |
Bob, they are from ACE Hardware. Pretty sure.
Dave |
galencurrington Samba Member
Joined: March 16, 2004 Posts: 426 Location: bowling green, ky
Posted: Fri Jul 30, 2021 10:49 am Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
I have a set kinda like that but it's craftsman and you can using it with a cordless impact drill not the big impact it works every time. _________________ "asking and getting are two different things" |
glassbuggy Samba Member
Posted: Fri Jul 30, 2021 5:55 pm Post subject: Re: Any secret tricks for removing seized Cheesehead screws? |
Everyone stop. Have I got the tool for you! A conduit reamer ( get one right down at Lowes ) has an end that captures the cheese head. As an electrical tool, it is for those conduit fitting screws. Holy F, for these damn tin screws, this tool is the shit. |
