Heart tail lights lenses not fitting
jpaulnewman
jpaulnewman is offline
PostPosted: Mon Jul 19, 2021 1:30 am    Post subject: Heart tail lights lenses not fitting Reply with quote
My new heart lenses do not seem to fit between the bulb holder and the housing.
The current heart tail lights on my 1954 Oval appear to have been painted black, so I purchased some new (sold as NOS) glass heart lenses.
But when I've tried to fit them I have found that my existing hearts are plastic unlike my new glass ones which are thicker and do not fit between bulb holder and the housing.
Can anyone tell me what may be the problem?
I've attched some photos showing the glass lens compared to the plastic lens:
Bulb holder:
D. Haviland
D. Haviland is offline
PostPosted: Mon Jul 19, 2021 6:27 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
Heart lenses are supposed to be plastic. I have some if you need some.
finster
finster is offline
PostPosted: Mon Jul 19, 2021 6:47 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
if your plastic ones are intact and not cracked then I would clean and use them. they can look quite dark if that's what you mean by painted black?
we are only given a little spark of madness - so you mustn't lose it!
a kubelwagen is on my bucket-car list
banana split
banana split is offline
PostPosted: Mon Jul 19, 2021 10:52 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
I assume you bought the new Kaefer-Nostalgie versions ?
https://www.thesamba.com/vw/classifieds/detail.php?id=2464271
Glass sounds neat but VW never made glass heart shaped lenses - they are all plastic.
Since they interfere with your bulb holders, I assume they have a design flaw that Kaefer-Nostalgie didn't catch before releasing them.
1951 Crotch Cooler Split Ragtop
1953 Zwitter
1964 chop top
jpaulnewman
PostPosted: Mon Jul 19, 2021 12:07 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
These are my current lenses and they look much darker than others I have seen.
I'm not really sure what to clean them with that will not damage them.
Previous owner also fitted the eyebrows.
jpaulnewman
Mine look the same as those Kaefer-Nostalgie, but I bought them from a seller in Germany.
The seller told me that the glass lenses he sold me are genuine NOS and that original VW lenses were glass and only later replacement lenses were plastic.
Can you confirm this is not true before I take this up with the seller and ask for a refund?
Brezelmeister
Brezelmeister is offline
PostPosted: Mon Jul 19, 2021 1:49 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
Heart lenses were never made of glass. Always plastic.
Looking at the lenses from Kaefer-Nostalgie it looks like the edge is far to thick.
And I also found that lots of the stuff Kaefer-Nostalgie sells are usually somewhat off.
banana split
PostPosted: Mon Jul 19, 2021 2:34 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
I've polished tons of automotive plastic lenses etc over the years - tail light lenses, oval sunvisors etc. Just use some automotive wax/polish. You can get a decent shine by hand but if you have a high speed buffing wheel, even better.
1953 Zwitter
1964 chop top
janerick3
janerick3 is offline
PostPosted: Mon Jul 19, 2021 6:37 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
x2 on the original heart lenses always having been plastic. Both the original Euro-market amber lenses and the U.S./Canada market red lenses are very dark. The light-colored lenses are always either later (1960s) replacement stock or reproductions.
Any good plastic polish or headlight lens cleaner will work. Metal polish will also work, but you do not want to cut so deeply into the plastic that any markings wear off.
Thanks,
Jan K.
Matts Bug Parts
Matts Bug Parts is offline
PostPosted: Mon Jul 19, 2021 9:18 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
I have bought and sold many 100s of NOS heart lenses, oval bottom lenses were always glass and the top hearts always plastic.
To bring your original heart lenses back to life simply wet sand them with 1000 and then 2000 grit sandpaper. Follow this with hand polishing with a cotton cloth and Maguires plastic polish. They will look like new. Never use machines due to risk of creating too much heat. Due to shelf wear I do the above with most Heart lenses although sometimes I might only use the polish.
All repro heart lenses are very wrong colour wise. If you polish lenses as described above using a white cotton cloth the residue on the cloth will be quite brown, not bright red.
Matt
finster
finster is offline
PostPosted: Tue Jul 20, 2021 1:38 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
as suggested above - go carefully. I've used a polishing product called 'peek' which was good but even some toothpaste and spit with a cloth will work.
do not use any paint removal fluids as these will likely damage the plastic.
jpaulnewman
PostPosted: Wed Jul 21, 2021 5:12 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
Thanks, I didn't think any hearts were amber were they?
I will have a go at polishing them.
Thanks, this was my concern.
Matt
Thanks Matt,
the seller is still insiting they are genuine NOS, so I am having difficulty getting my money back!
janerick3
PostPosted: Wed Jul 21, 2021 6:54 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
Matt
Thanks Matt,
The dark amber and dark red plastic lenses are hard to tell apart until you place them side-by-side and shine a light through them.
There is a remote possibility the lenses you bought are NOS, as the DIN(?) standard for translucence changed in the early 1960s and red plastic lenses produced after that date had to meet the new, lighter shade specified. The standard for amber lenses may have already changed by the late 1950s; being forced by the adoption of amber combination brake/turn signals in Europe.
Thanks,
Jan K.
Srecko
Srecko is offline
PostPosted: Wed Jul 21, 2021 9:20 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
The darker lenses are NOS, I have aftermarket lenses on my tail lights and they fit ok, I think I will put the NOS lenses on for a better fit. If you still have the original lenses clean them up and polish them, they will be a better fit.
Matts Bug Parts
PostPosted: Thu Jul 22, 2021 10:44 am    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
Janerick 3 posted "There is a remote possibility the lenses you bought are NOS, as the DIN(?) standard for translucence changed in the early 1960s and red plastic lenses produced after that date had to meet the new, lighter shade specified. The standard for amber lenses may have already changed by the late 1950s; being forced by the adoption of amber combination brake/turn signals in Europe".
To that I would say NO! NO! NO! NO!
First the question of plastic versus glass for top heart lenses as well as amber versus red top hearts has been discussed for many years in the forums. Amber lenses were made and glass hearts were not.
Second, if VW had them made they would fit perfectly.
Third and fourth, I have been an avid split/oval fan since 1989 - the glass top lenses just appeared recently and Kaefer Nostalgia is clear in their current ad that they are new production.
Fifth, I have walked swap meets in the US and Europe for 30 years, probably walking 1000's of miles, and ZERO top, heart glass lenses found. As well, no one else has located them to my knowledge.
Lastly, all sorts of parts are listed on the Samba as NOS and are clearly not. Some months ago I tried to engage others in a debate about parts qaulity and deceptive advertising her on the Samba with almost no interest generated. Sad nut a reality of our times.
PostPosted: Thu Jul 22, 2021 12:16 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
I have an NOS one.
It's in the VW bag.
It's plastic.
janerick3
PostPosted: Thu Jul 22, 2021 6:29 pm    Post subject: Re: Heart tail lights lenses not fitting Reply with quote
My bad--I had forgotten he said they were glass. I looked at the OP's photos and noticed the glass lenses do not have the sharp ridges on the inside that the plastic lenses do.
I am surprised that VOA was still willing to repackage, tag and keep old stock lenses in inventory as late as the 1970s.
As for Garwood, he assumes heart lenses were dropped at the start of the 1954 model year on U.S. market cars, which we now know is not true.
Thanks,
Jan K.
