scottmatlock Samba Member
Joined: April 04, 2018 Posts: 13 Location: Stillwater, OK
Posted: Mon Jul 19, 2021 7:05 am Post subject: Oil Burn after Top End Rebuild |
Hey all! I just converted from single to dual port on my 70 Westfalia. New pistons, rings, cylinders, obv. heads and carb (34-Pict). Put it back in and it ran GREAT for about 2 weeks, then I noticed that I was having to put in a qt of oil every few days. Yesterday while idling, the white smoke began. Changed the oil (20w-50) and fired it up and CLOUDS of smoke! It was after about 1 minute of running, not instantly.
Before the rebuild I was having low pressure issues, put in a 30MM oil pump and Empi oil pressure booster kit (https://www.jbugs.com/product/9202.html)
Could it be I have a bad set of rings already? Less than 300 miles since new pistons. Too much oil pressure? Crank case pressure issue? I also am noticing there is also oil coming from rear main seal. That was also replaced along with flywheel on this last rebuild. Endplay looked good.
I am ready to pull the engine again, but thought if I was over looking something easy it may save me the labor! Thanks for the advice! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
SGKent Samba Member
Posted: Mon Jul 19, 2021 8:17 am Post subject: Re: Oil Burn after Top End Rebuild |
if oil consumption is increasing that is not a problem with rings seating in the conventional sense. It could be many things. I would start by pulling the plugs with the engine cold and see if all or one cylinder is the culprit. With that much oil the plugs in the defective cylinders should be really oily.
What are you using for a breather?
It is also possible that a valve guide has broken or slipped so that oil is running past it. When you rebuilt it, did you mess with the guides? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Jul 19, 2021 8:47 am Post subject: Re: Oil Burn after Top End Rebuild |
One thing I know. You are over oiling the engine. Get that high pressure plunger out of there first. Go back to stock. A 30mm pump is more than enough. Maybe too much. Breather pressure is a definite issue too. New rings = more breather. You must vent that pressure or it will cause the leaks you describe. Can we see a pic of your engine? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Jul 19, 2021 8:49 am Post subject: Re: Oil Burn after Top End Rebuild |
New carb might be leaking gas into your oil causing white smoke _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Jul 19, 2021 9:00 am Post subject: Re: Oil Burn after Top End Rebuild |
I wouldn’t use 20w50 during break in. Try 10w30. You want wear right now. You want the rings to wear in. Later you can go back to slippery detergent oil. But the 20w50 is too heavy right now _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Mon Jul 19, 2021 9:08 am Post subject: Re: Oil Burn after Top End Rebuild |
Thanks all - I will change out the bypass plungers to stock. I will grab a pic over lunch. As far as the valve guides, It could be but I bought fully assembled brand new heads so I did not mess with valve guides.
I did not do the break in properly, but I did have 10w-30 for the first oil on the new engine. I just put the 20W-50 in yesterday and have not driven with it. I will swap it back for the 10W-30 and try the proper break-in procedure to see if I can set those rings still.
For the breather, I swaped it for a simple paper breather from the original oil filled breather, but I was using that on the previous engine too. I still have the stock breather if that could be a culprit? Appreciate all the advice! |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon Jul 19, 2021 9:54 am Post subject: Re: Oil Burn after Top End Rebuild |
Did you make sure to stagger the ring gaps? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Jul 19, 2021 11:36 am Post subject: Re: Oil Burn after Top End Rebuild |
I like to use original oil fill/ breather vents because many of the aftermarket ones are a smaller diameter. Looking forward to yours pics
Here's a pic of an engine I did in a 1972 bus. Notice the aftermarket breather
Took it for a drive
Then found this. Main oil seal leaking
So I changed the seal twice more and continued to find leaks. Finally going back to stock fixed the venting issue.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Mon Jul 19, 2021 12:32 pm Post subject: Re: Oil Burn after Top End Rebuild |
Quote: |
For the breather, I swapped it for a simple paper breather from the original oil filled breather, |
huh? you mean air cleaner? If you put on a paper air cleaner, how did you plumb the breather hose? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Jul 19, 2021 12:36 pm Post subject: Re: Oil Burn after Top End Rebuild |
Replaced the plungers with the stock over lunch and swapped back to 10w-30 oil. Took it out and ran hard up some hills around the area. When I parked it after about 20 minutes of driving, rear main clearly having issues! Was pouring out of there.
Posted: Mon Jul 19, 2021 12:38 pm Post subject: Re: Oil Burn after Top End Rebuild |
SGKent wrote: |
huh? you mean air cleaner? If you put on a paper air cleaner, how did you plumb the breather hose? |
Yes, obv. meant air cleaner. There is a photo above. |
SGKent Samba Member
Posted: Mon Jul 19, 2021 12:54 pm Post subject: Re: Oil Burn after Top End Rebuild |
pull the top off the air cleaner and with the engine running see how much blowby there is coming out the breather opening (over where the breather hose is connected). Make sure it isn't plugged. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Jul 19, 2021 1:03 pm Post subject: Re: Oil Burn after Top End Rebuild |
So the hose connected to your breather tower is very close to 1/2 inch ID. You need to check the carb air cleaner connection for that hose and make sure it isn’t reduced down from the 1/2 inch. Also, there needs to be a smooth downhill flow for that hose. If not, it can accumulate oil which can block the breather air _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Jul 21, 2021 11:36 pm Post subject: Re: Oil Burn after Top End Rebuild |
aeromech wrote: |
So the hose connected to your breather tower is very close to 1/2 inch ID. You need to check the carb air cleaner connection for that hose and make sure it isn’t reduced down from the 1/2 inch. Also, there needs to be a smooth downhill flow for that hose. If not, it can accumulate oil which can block the breather air |
I hogged out my aftermarket breather by almost double and yes definitely make sure there is no low spot in the breather hose. Not just oil will accumulate, but water as well from short drives and if you are in a cold climate like me it will freeze and you’ll be blowing oil out everywhere! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
