Maine Samba Member
Joined: September 21, 2010 Posts: 150 Location: Maine
Posted: Mon Jul 19, 2021 8:46 am Post subject: Go Westy Lithium Battery Install |
I replaced my NAPA 100 Ah house battery that was located under the sink with a Go Westy 50Ah lithium battery. I put the new battery under the drivers seat. I liked the cost about $360 delivered to Maine, its really light compared to the same size lead acid battery and it is small enough so there is plenty of room. It even sits upright.
I have a couple of questions though. How many volts can you safely discharge it to? Also the voltage when driving hangs around 13.4 volts where as the lead acid voltage showed 13.9-14.0 volts. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Mon Jul 19, 2021 9:21 am Post subject: Re: Go Westy Lithium Battery Install |
Maine wrote: |
That's mainly depending on the battery BMs setting - I'd ask GoWesty for such.
Maine wrote: |
For proper charging off the alternator, you will likely be best served by a DC-DC Charger. Plenty here like the RedArc brand. Victron has a pretty reasonable DC-DC charger available. Sorry, I'm not experienced enough to make a model recommendation. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Maine Samba Member
Posted: Mon Jul 19, 2021 12:49 pm Post subject: Re: Go Westy Lithium Battery Install |
Is a DC-DC charger required? |
Chestercopperpot Samba Member
Posted: Mon Jul 19, 2021 12:51 pm Post subject: Re: Go Westy Lithium Battery Install |
Only required if you want to do it correctly, you'll be hard pressed to get it to charge without |
Maine Samba Member
Posted: Mon Jul 19, 2021 1:11 pm Post subject: Re: Go Westy Lithium Battery Install |
How many amp charger for a 50Ah battery? |
Maine Samba Member
Posted: Mon Jul 19, 2021 1:14 pm Post subject: Re: Go Westy Lithium Battery Install |
Would this work?
DUAL INPUT 25A IN-VEHICLE DC BATTERY CHARGER |
nohabusguy Samba Member
Posted: Mon Jul 19, 2021 1:19 pm Post subject: Re: Go Westy Lithium Battery Install |
Quote: |
How many volts can you safely discharge it to? |
I have these batteries - the discharge/charging specs are on the GW website where the battery is listed in one of the tabs on that page _________________ 1967 Double Cab
1967 21 Window Deluxe Bus
1989 Westy Syncro (Subaru 2.5, dreaming of installing a NAHT)
1990 Doka Syncro (WBX 2.1) |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
