bugsy579 Samba Member
Joined: September 14, 2014 Posts: 17 Location: Wadsworth, OH
Posted: Wed Jul 21, 2021 1:13 pm Post subject: Weber Carb |
Have a 1966 VW Beetle that had a 1500 engine installed when I bought it. I have had the engine rebuilt and increased to a 1600 DP engine. the rebuild kit came with a Weber carb. Once it is warmed up after 2 or 3 miles it runs strong. But, it runs terrible while it is warming up. It backfires through the exhaust and is embarrassing driving down the road until it is warmed up. Any suggestions to improve the performance until it is warmed up? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Wed Jul 21, 2021 2:12 pm Post subject: Re: Weber Carb |
What type of weber is it as weber makes a lot of different carbs.
A photo also would be very helpful. This way we could offer suggestions. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Thu Jul 22, 2021 7:13 am Post subject: Re: Weber Carb |
Sorry, I should have noted the type of Weber carb. It is a 32/36 2 barrel progressive carb. I have the same carb on my MGB and I had problems on it until I took it to a guy who has worked with Webers on Italian cars for 40 years and it got it adjusted tuned properly by adjusting the float and changing some jets and it runs terrifically. Unfortunately he is no longer available. I don't understand why it runs so bad during warmup and runs great when it is at operating temperature. I wonder if it would be possible to put a manual choke on it and if that may solve the problem. Thanks for any thoughts on the matter. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Thu Jul 22, 2021 7:32 am Post subject: Re: Weber Carb |
bugsy579 wrote: |
It is a 32/36 2 barrel progressive carb. |
I have a Weber 32/36 DGEV on my 1988 Mazda truck and it works well (installed 2005). I haven't read too much positive though about using a Weber progressive on a 1600cc VW engine, but have no first-hand experience.
I installed a Weber (likely 32/36) onto a 1975 Chevy Luv and that worked OK, but that was 4 decades ago.
I do run a Weber 40DCNF on my VW 1835cc DP engine, since 1976. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 849 Location: South Florida
Posted: Thu Jul 22, 2021 8:50 am Post subject: Re: Weber Carb |
bugsy579 wrote: |
... it runs so bad during warmup and runs great when it is at operating temperature ... |
This is a typical symptom of insufficient intake manifold pre-heating, e.g. clogged. What type of intake manifold preheat do you have; stock muffler, or an aftermarket muffler with typical piss-poor provisions for intake heating? |
Posted: Thu Jul 22, 2021 9:22 am Post subject: Re: Weber Carb |
I had not thought of that. I do have an aftermarket muffler. Perhaps that is the problem. Thanks for the suggestion. I will check that. |
empi3 Samba Member
Joined: October 03, 2015 Posts: 346 Location: SW Wyoming
Posted: Thu Jul 22, 2021 11:45 am Post subject: Re: Weber Carb |
Thanks so much. I have printed it off so I can read through it. Thanks again for the replay and have a great day.
Rod |
