rzepko6194 Samba Member
Posted: Thu Jul 22, 2021 6:17 am Post subject: 36hp fuel pump diaphragm replacement |
The recently rebuilt fuel pump on my 36hp engine has started leaking at the diaphragm. Can a new one be installed without removing the pump from the engine? i don’t have any spare pump to block gaskets. Thanks. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Thu Jul 22, 2021 11:56 am Post subject: Re: 36hp fuel pump diaphragm replacement |
No, you need to remove it from the engine.
You can install a new gasket without removing the cross-pin on 36hp pumps though - I've seen people remove the pin and then try to re-peen the pin and damage the lower body.
You might be ok to re-use the gaskets though while you order new ones. _________________ How to Post Photos
Posted: Thu Jul 22, 2021 1:35 pm Post subject: Re: 36hp fuel pump diaphragm replacement |
Ok, thanks. |
my59 Samba Member
Joined: August 13, 2003 Posts: 3791 Location: connecting the dots
Posted: Thu Jul 22, 2021 5:23 pm Post subject: Re: 36hp fuel pump diaphragm replacement |
You need to pre-load the diaphragm, which is best done on a bench, not in the car. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Thu Jul 22, 2021 7:40 pm Post subject: Re: 36hp fuel pump diaphragm replacement |
my59 wrote: |
You need to pre-load the diaphragm, which is best done on a bench, not in the car. |
Got it. Thanks! |
