dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Thu Jul 22, 2021 10:15 am Post subject: options for 10 pin headlight switch replacement? |
my 1991 has the 10 pin headlight switch which is NLA. it is having issues, and if cleaning does not resolve, a replacement will be needed.
what options exist to replace the 10 pin switch? hacking the wiring and changing to the 8 pin would bypass something needed in the 10 pin switch i would assume, correct? _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Thu Jul 22, 2021 10:51 am Post subject: Re: options for 10 pin headlight switch replacement? |
You can use the more common earlier headlight switch in your late van but you should add an inline fuse to a wire by the switch.
Coming out of the switch wiring socket is a small Gray/Blue wire from pin 58b.
I would put an ATM fuse holder and 5 amp fuse there in that wire.
Mark
dabaron wrote: |
what options exist to replace the 10 pin switch? hacking the wiring and changing to the 8 pin would bypass something needed in the 10 pin switch i would assume, correct? |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Thu Jul 22, 2021 1:05 pm Post subject: Re: options for 10 pin headlight switch replacement? |
The T suffix 10pin switch is readily available, I have 2 on hand. If you revert back to a M suffix you will need the connector housing as the pin configurations are not interchangeable. _________________ Schau in das Buch |
Posted: Fri Jul 23, 2021 6:38 am Post subject: Re: options for 10 pin headlight switch replacement? |
dgbeatty wrote: |
The T suffix 10pin switch is readily available, I have 2 on hand. If you revert back to a M suffix you will need the connector housing as the pin configurations are not interchangeable. |
none of the US Vanagon specific vendors have them in stock, several claim they are NLA.
do you have an OEM part? _________________ 1991 Vanagon GL Camper
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Fri Jul 23, 2021 10:23 am Post subject: Re: options for 10 pin headlight switch replacement? |
The ones I have on hand are OE VW switches. The T switches are available. _________________ Schau in das Buch |
Posted: Fri Jul 23, 2021 10:35 am Post subject: Re: options for 10 pin headlight switch replacement? |
dgbeatty wrote: |
The ones I have on hand are OE VW switches. The T switches are available. |
available from where? _________________ 1991 Vanagon GL Camper
Posted: Fri Jul 23, 2021 2:20 pm Post subject: Re: options for 10 pin headlight switch replacement? |
dabaron Google https://tinyurl.com/yg2h7h9u I stopped cpunting at 10 vendors. Even GoWesty aka "sold out" has them. _________________ Schau in das Buch |
kamzcab86 Samba Moderator
Posted: Fri Jul 23, 2021 2:58 pm Post subject: Re: options for 10 pin headlight switch replacement? |
dgbeatty wrote: |
Even GoWesty aka "sold out" has them. |
GoWesty:
"Part #: 251-941-531M
VW Part #: 251941531M
Works With: 1980-1990
Weight: 0.20 lbs
There are two different headlight switches for Vanagon:
Early: # 251-941-531M (1980-1990)
Late: # 251-941-531T (1989-1991)
From the front they look and function identically. However, they are slightly but significantly different on the back. The early style switch has only 8 pins, while the late style switch has 10 pins.
The 10 pin option is no longer available from VW and we are only offering the early style, 8 pin switch. "
https://www.gowesty.com/product/switches/3609/headlight-switch- _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Jul 23, 2021 4:08 pm Post subject: Re: options for 10 pin headlight switch replacement? |
Brickwerks.co.uk
Headlamp Switch - T3 / Late
Genuine VW headlamp switch, as fitted to very late (1990 on) T3 models.
ADDITIONAL INFORMATION
OUR PART NUMBER 251941531T
VW PART NO 251 941 531 T
MANUFACTURER VW
£31.33 (Inc VAT)
ADD TO CART
In stock
What else can I say. $60 shipped _________________ Schau in das Buch |
bobhill8 Samba Member
Posted: Fri Jul 23, 2021 5:24 pm Post subject: Re: options for 10 pin headlight switch replacement? |
Does it come with a scone? I say you take that chopped one from Jersey Dave. _________________ 1986 Westy
1971 Squareback |
Posted: Fri Jul 23, 2021 5:38 pm Post subject: Re: options for 10 pin headlight switch replacement? |
dgbeatty wrote: |
Brickwerks.co.uk
MANUFACTURER VW
£31.33 (Inc VAT)
ADD TO CART
In stock
What else can I say. $60 shipped |
brickwerx webshop is closed.
gowesty does not have them.
like i said, i looked before i asked, this isn't Facebook.
the option of using the 8 pin i already own is honestly the long term viable option. Dave... put it in the box. _________________ 1991 Vanagon GL Camper
Posted: Fri Jul 23, 2021 9:29 pm Post subject: Re: options for 10 pin headlight switch replacement? |
You want 1 right? I have 2 for sale. What problem am I not seeing? _________________ Schau in das Buch |
Posted: Sat Jul 24, 2021 8:36 am Post subject: Re: options for 10 pin headlight switch replacement? |
I relooked at vendors and contacted a couple. I found 2 in the US and 6 in Europe that have them in stock. If you do decide to revert back to an 'L" (8 pin) switch I would like to buy your 10 pin connector housing.
On a somewhat related note I am looking for a 11 pin connector housing, they were used with the 323941531J and 251941531S switches.
Thanks _________________ Schau in das Buch |
Posted: Mon Jul 26, 2021 12:24 pm Post subject: Re: options for 10 pin headlight switch replacement? |
dgbeatty wrote: |
Thanks |
which US vendors have them? i could not find any that were in stock. as for Europe, the shipping is the price of the item, i understand that, but would rather not have that CO2 footprint added to my already bad Vanagon life.
it was not even remotely clear you were selling. no PM, no price, nothing.
the best solution is to eliminate a hard to find part and go for the one that is easily sourced. _________________ 1991 Vanagon GL Camper
Jennybenny Samba Member
Posted: Mon Jul 26, 2021 8:23 pm Post subject: Re: options for 10 pin headlight switch replacement? |
Vanagain in Jersey yo. I was looking today. Worry about next time next time.
dabaron wrote: |
the best solution is to eliminate a hard to find part and go for the one that is easily sourced. |
Posted: Tue Jul 27, 2021 5:20 am Post subject: Re: options for 10 pin headlight switch replacement? |
Jennybenny wrote: |
doh, i thought i checked there and came up with nothing... thank you. _________________ 1991 Vanagon GL Camper
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
DeLvxe Samba Member
Joined: January 08, 2019 Posts: 106 Location: Seattle
Posted: Sat Dec 16, 2023 7:15 pm Post subject: Re: options for 10 pin headlight switch replacement? |
This is an old thread but an unresolved problem. I have a ‘91 with a mostly fried 10-pin headlight switch. The 10-pin switch’s are truly NLA now and seems any old stock is completely dried up.
Can I use an 8-pin switch in place of my 10-pin and if so what modifications do I need to make for it to be fully functional and safe?
Thanks _________________ 1991 manual camper with EJ25 |
