Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Fri Jul 23, 2021 9:46 am Post subject: Cluster f@@ed |
I cant recall what the issue was. Dash running lights only work when key is off. Key on and highbeam indicator illuminates with headlights off. go headlight on then off oil light on for a second.
This was an orphan so unknown hands have been here. The foil plug is buggered.
Is it a shorted dash foil or perhaps the wrong one.
Prolly gonna want to drive at night at some point.
1991 year. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri Jul 23, 2021 9:51 am Post subject: Re: Cluster f@@ed |
I solved similar weird issues by replacing the ground(s) from the head lights to the star above the fuse box.
I suggest cutting the two into one ground from those light into two separate grounds. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Fri Jul 23, 2021 10:42 am Post subject: Re: Cluster f@@ed |
right on. there are after market headlight relays in there. good place to start _________________ LEARN TO SELF RESCUE
Posted: Sat Aug 07, 2021 12:45 pm Post subject: Re: Cluster f@@ed |
So I did this
