Mattink Samba Member
Posted: Sat Jul 24, 2021 11:53 am Post subject: Headlight replacement help |
Hello there, I'm attempting to upgrade the sealed headlights in my 74 VW single cab to a pair of Vintage Car LED headlights. When I took the assembly out I noticed that the Vintage Car LED lights don't have the same attachment brackets as the originals. I'm wondering if I can attach them with additional hardware or if I need a new headlight assembly.
Old headlight trim only has 1 screw.
Old Headlights are Bosch CR E1 14550R7
New headlights are Vintage Car LED VC5000 ULTIMATE 7 INCH
Any help would be appreciated!
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 24, 2021 12:14 pm Post subject: Re: Headlight replacement help |
Unless you are in Europe those aren't the original headlights, they look like those Mexican ones many sellers were offering a few years ago. To use those new ones you'll have to find a pair of original sealed beam style headlight baskets.
Some examples from a classifieds search: https://www.thesamba.com/vw/classifieds/search.php...ton=Search
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 24, 2021 12:46 pm Post subject: Re: Headlight replacement help |
That explains it. This is coming out of a bus that just came over from Italy. Do I need to swap out the single screw chrome trim for a 3 screw trim? |
Posted: Sat Jul 24, 2021 1:50 pm Post subject: Re: Headlight replacement help |
Those use the single screw trim, the 3 screw is for the Euro bulb and reflector units. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2021 1:28 pm Post subject: Re: Headlight replacement help |
I got a pair of buckets that work great, courtesy of the The Samba Classifieds. The lights now fit great, but they don't turn on for anything other than the high-beams.
The new lights are 25W DC 10V-30V. When the car is on they are off. When the headlight switch is pulled, the new lights are off. When the headlight switch is pulled to high-beam, the new lights turn on.
The old European sealed lights have 3 electrical connections to them: a 3 prong plug, and two smaller connectors that attach to tabs on the back of the light that are embossed with, "3" and what looks like, "58." These new lights only have the 3 prong connector.
The old headlights work fine both in the on position and highbeams.
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2531 Location: Ocean Beach in Beautiful BLUE California
Posted: Sat Jul 31, 2021 2:54 pm Post subject: Re: Headlight replacement help |
The Euro lights have a second small bulb in them for the first click of the headlight switch, since you are converting to a North American style light you'll either have to convert your signal lights to dual filament, or drill the reflectors in those LED's to accept a small push in bulb in a rubber grommet.
When you say "high beams" are you referring to two different light levels on the second pull of the switch?, or just the now missing weak glow on the first pull of the switch? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2021 4:31 pm Post subject: Re: Headlight replacement help |
Whoops, I was wrong about the high beams, I see where those are. Yes, I am referring to the two different levels of the of the pull of the headlight switch.
What is the first pull of the switch for? Daytime running lights?
Are the signal lights the ones above the headlights, the ones behind the front doors, or both? |
Posted: Sat Jul 31, 2021 5:05 pm Post subject: Re: Headlight replacement help |
Quote: |
What is the first pull of the switch for? Daytime running lights? |
In Europe they are called city lights, or in a skewed way low beams sometimes. The second click is called main beams (headlights in NA), they have two brightness options chosen by pulling back on the signal lever. In North America the first click is called parking lights, but instead of the headlights the signal lights light up, they use a dual filament bulb that's a lower wattage than the signals.
On a 74 it's the ones above the headlights, the ones on the doors are just reflectors on all models (some never even came with those). It's the lights that flash when you move the signal switch on the column up or down to signal a turn. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 31, 2021 5:27 pm Post subject: Re: Headlight replacement help |
This is really useful to know, thank you.
I'll look into either adding a bulb in the lights or converting the turn signals to a dual filament bulb. In the meantime I wrapped the unused electrical connections in electrical tape and connected up the new headlights. They still work on that second pull of the headlight knob and the signals work too when I engage them. Are there any downsides to running my truck like this for now? |
Posted: Sat Jul 31, 2021 5:42 pm Post subject: Re: Headlight replacement help |
Mattink wrote: |
Depends on the cop, you didn't mention where you are, but around here no front parking lights may provoke a fix it ticket if he's feeling prickly. If you forgo the first click and just run headlights it's likely not an issue.
If you live in a country that forbids headlights until after sundown but requires running lights at dusk (don't know if that's even a thing) you may find out right away. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Aug 02, 2021 9:24 am Post subject: Re: Headlight replacement help |
The housings you removed are much better than the Chinese housing that you bought with the LED lights. 99.9% of the drop in H4 LED bulbs are poor at best. Just because it's brighter does not make it better. |
samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Wed Aug 04, 2021 8:26 am Post subject: Re: Headlight replacement help |
In the UK, first pull on the light switch on the dash is the parking lights (5w bulbs, IIRC, in the headlight housing) and tail lights (no side markers etc in most of Europe at the time).
Second detent gets headlights on (60/55w bulbs if halogen, or 45/40w for normal bulbs), with low and high beam controlled by the column stalk. _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2947 Location: South Benfleet, Essex, UK
Posted: Thu Aug 05, 2021 12:25 pm Post subject: Re: Headlight replacement help |
busdaddy wrote: |
On a 74 it's the ones above the headlights, the ones on the doors are just reflectors on all models (some never even came with those). It's the lights that flash when you move the signal switch on the column up or down to signal a turn. |
I think poor old "Busdaddy" is getting confused about what various automotive lamps are called on either side of the Atlantic Ocean.
The first dashboard-switch pulled position, is for tail-lights, rear-licence-plate-light, front & rear side-marker lights (if fitted - obligatory only in North America!) and front side-lights (aka parking lights or position lights).
The second dashboard-switch pulled position, is for headlights only, which may be on either main-beam (high-beam in North American parlance) or dipped-beam (low-beam in North American parlance), controlled by the steering-column-mounted, headlamp dip & flasher (dimmer in North American parlance) stalk-switch and headlamp dip & flasher (dimmer in North American parlance) relay.
samwise wrote: |
Second detent gets headlights on (60/55w bulbs if halogen, or 45/40w for normal bulbs), with low and high beam controlled by the column stalk. |
I retro-fitted North American specification side-marker lights to my British specification 1973 VW 1600 Type 2 in the late-1970s.
The conventional 45/40W glass-envelope, globe-shaped bulbs have P45t mounting flanges.
The 60/55W and some higher-power quartz-halogen bulbs, are available with either P45t mounting flanges (typically substitutes for conventional 45/40W glass-envelope-bulb headlamps) or P43t mounting flanges (for purpose-made H4 quartz-halogen headlamps).
I have 100/80W H4 quartz-halogen bulbs with P45t mounting flanges for my conventional 45/40W glass-envelope-bulb headlamps.
H4 quartz-halogen and other headlamp bulb, P45t & P43t flange fittings
https://www.thesamba.com/vw/forum/album_page.php?pic_id=338649
_________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
