viking874 Samba Member
Posted: Sat Jul 24, 2021 2:03 pm Post subject: steering wheel cancel ring/high beams |
new WW steering wheel and new WW 9 wire turn signal stalk.
cancel ring activating high beam. i tried to wrap some electric tape around column to move stalk out a bit as a test but that's not working.
anyone else have this problem?
suggested fix? _________________ 1975 Brazilian Split Window
1970 Ghia Coupe
1971 Super Beetle
2010 Meyers Manx
1985 Toyota Land Cruiser FJ60
1988 Toyota Land Cruiser FJ62
1986 Mercedes G Wagen |
Posted: Sat Jul 24, 2021 3:46 pm Post subject: Re: steering wheel cancel ring/high beams |
never mind. I'm missing the inner 1/2 circle piece that clamps around column.
hoping it's still at paint shop. _________________ 1975 Brazilian Split Window
1970 Ghia Coupe
1971 Super Beetle
2010 Meyers Manx
Posted: Fri Aug 13, 2021 4:45 am Post subject: Re: steering wheel cancel ring/high beams |
This is still happening after I put in the C Clamp.
The cancel ring will activate high beams when turn signal is either on left or right.
Could it be a ground problem? The horn works fine - so no grounding issues there. _________________ 1975 Brazilian Split Window
1970 Ghia Coupe
1971 Super Beetle
2010 Meyers Manx
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Fri Aug 13, 2021 6:07 pm Post subject: Re: steering wheel cancel ring/high beams |
Is it the kind of turn signal mechanism with the hi-low on the stalk by pulling up? |
busdaddy Samba Member
Posted: Fri Aug 13, 2021 6:54 pm Post subject: Re: steering wheel cancel ring/high beams |
Sounds like you might have the ground and high beam wires mixed, does one of the brown ones have a white stripe? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Aug 16, 2021 12:17 pm Post subject: Re: steering wheel cancel ring/high beams |
Fixed! My two Brown wires from stalk were switched.
Thank you to all for your helpful suggestions. _________________ 1975 Brazilian Split Window
1970 Ghia Coupe
1971 Super Beetle
2010 Meyers Manx
Millerz13 Samba Member
Joined: November 25, 2018 Posts: 42 Location: Sacramento
Posted: Sat Feb 12, 2022 7:41 pm Post subject: Re: steering wheel cancel ring/high beams |
viking874 were the wires on the relay switched? I am having the same issue and cant figure it out. |
Posted: Sun Feb 13, 2022 6:06 am Post subject: Re: steering wheel cancel ring/high beams |
Millerz13 - yes, mine were switched on the relay. _________________ 1975 Brazilian Split Window
1970 Ghia Coupe
1971 Super Beetle
2010 Meyers Manx
Posted: Sun Feb 13, 2022 6:49 am Post subject: Re: steering wheel cancel ring/high beams |
Interesting as I don’t have two brown wires on the headlight relay.
Thanks for the reply! |
