nanometer Samba Member
Posted: Sat Jul 24, 2021 6:02 pm Post subject: Door problem |
Hi ...... I've got a 71 bay window. In this photo the door is shut and only opens 5" unless I take my finger and push part A in toward the body. I'm
wondering if someone put part B on incorrectly. Maybe it needs to be turned clockwise. What do you think ? Thanks
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Jul 24, 2021 7:09 pm Post subject: Re: Door problem |
I don't know the answer to you question.
But this is a great post of Colin's for revamping your mechanism...
https://itinerant-air-cooled.com/viewtopic.php?f=4...21ac3bc10b _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Jul 24, 2021 10:18 pm Post subject: Re: Door problem |
basically yes. it's upside down and backwards _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
Posted: Sat Jul 24, 2021 10:37 pm Post subject: Re: Door problem |
Looked at some older pictures of my latch, and you can see the same thing in Colin's post pictures - that part you have labeled "B" needs to be rotated clockwise 90 degrees, but I noticed it's also installed upside down/backwards - the cam lobe of that part needs to be going in the other direction so that it slides/pushes part "A".
If you can, definitely take the time to do the hinge refresh/rebuild - like Kent mentioned check out Colin's post...his technical writeups are awesome, and it's worth the time for sure. _________________ -Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue |
Posted: Sun Jul 25, 2021 9:51 am Post subject: Re: Door problem |
mikewire wrote: |
If you can, definitely take the time to do the hinge refresh/rebuild - like Kent mentioned check out Colin's post...his technical writeups are awesome, and it's worth the time for sure. |
Yeah I thought something was a little fishy so I'll flip it etc and do the rebuild. Thank you fellows for the news. I'll ASSUME that Colins hinge mechanism is the same as my 1971 right ?
Anymore my brain is upside down and backwards |
