llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Sat Jul 24, 2021 6:13 pm Post subject: Windshield washer |
Mine's never worked. Today I decided to fix it. I have power to the pump so I'm going to buy a replacement pump (gowesty). The tube to the nozzles, however seems kinked and crushed. Like someone took down the reservoir, couldn't figure out the problem and then jammed it back up catching the hose between the reservoir and frame.
Can someone suggest an easy way to splice a new section of tube to replace just the damaged section? I did a quick perusal of threads about replacing the whole line and it seems like a can of worms. I really don't want to remove my dash.
Thanks in advance. _________________ 87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present) |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Sat Jul 24, 2021 6:25 pm Post subject: Re: Windshield washer |
I recently spliced the washer tubing to my rear window in order to replace the weatherproof boot. I used a 3/16” brass barb connector. Good luck! _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Mon Jul 26, 2021 7:07 am Post subject: Re: Windshield washer |
Are you sure you need a new pump? Did you test your current one? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Posted: Mon Jul 26, 2021 9:29 am Post subject: Re: Windshield washer |
cmayna wrote: |
Are you sure you need a new pump? Did you test your current one? |
Had power at the fuse and the connector but motor didn't work, so I assume motor was bad. Now that I think about it maybe the previous owner put the plug in backwards? I kind of doubt it. He was a JPL engineer. _________________ 87 syncro tintop
90 gl tin top
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Tue Jul 27, 2021 9:55 am Post subject: Re: Windshield washer |
I had some issues with my pump when I got it - turned out a previous owner replaced the connectors, and they had corroded/were not connecting well (hence the intermittent problems)
I cut the ends off, and put new connectors on - no problems since. _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Thu Mar 03, 2022 11:05 pm Post subject: Re: Windshield washer |
Just finished fixing my non working windshield washer. Took everything apart and noticed that the motor was not getting 12v in a consistent manner. Took off the steering stalk, cleaned up the contacts (electric spray and 400 grit emery paper) and it's working great. Lesson to all: Do this every 30 years or so. _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
DuncanS Samba Member
Posted: Fri Mar 04, 2022 6:18 am Post subject: Re: Windshield washer |
Replacing the hoses does not require dropping the dash. Tie a string to the PS hose and when you withdraw it. You now have a messenger to pull the new one back. The DS is accessible. Put the T connection wherever you want for convenience.
Duncan |
Ronzo_volvo_guy Samba Member
Joined: December 31, 2015 Posts: 194 Location: Connecticut
Posted: Fri Mar 04, 2022 7:26 am Post subject: Re: Windshield washer |
Forum;
Duncan's suggested method is THE technique when doing a total tube replacement, but as a option, if just splicing is called for, plastic 3/16" hose connectors are common for aquarium air hose...
Also, I've never tried using the silicon aquarium air line, but it seems to me that it's the same size and would last a lot longer before becoming hard as a rock.
Cheers |
Posted: Fri Mar 04, 2022 10:44 am Post subject: Re: Windshield washer |
Why would you splice and risk leaks when new rubber--and use rubber, not plastic--is so cheap? Rubber can grab the nozzle spigots and be less apt to slip off than plastic. This is a no brainer. And while you are at it, XO the factory nozzles which are terrible. There are plenty of improvements out there. Personally I like wet arms. https://www.amazon.com/Wet-Kit-Wiper-Arm-Replacement/dp/B00G1FYAGS Not as sexy as this: https://www.youtube.com/watch?v=07AZHkkLR0k
I have two nozzles fixed on each arm and the rubber tube runs down the arm and through a grommet at the base of the pivot. Highly recommend this adaptation. Didn't bother to fill the old nozzle holes--just left them in place. They aren't any more useless like this than they were before.
Duncan |
GreggK Samba Member
Joined: May 17, 2008 Posts: 897 Location: Colorado/Philidelphia
Posted: Fri Mar 04, 2022 1:02 pm Post subject: Re: Windshield washer |
DuncanS wrote: |
Duncan |
I like that idea. Could you show a picture of how you ran the hoses into the van, if you get a chance. I have an idea but would like to see what you did. Thanks Duncan _________________ '86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady |
hardway Samba Member
Joined: January 03, 2012 Posts: 416 Location: Fidalgo Island
Posted: Fri Mar 04, 2022 1:33 pm Post subject: Re: Windshield washer |
I have no problem with the plastic tubes. Being translucent is an advantage in diagnosis. It helps if you warm up the plastic before you remove and install it onto the barbs. Sometimes you need to trim it to get to an unstretched section.
My Golf broke the tube to the tailgate. The plastic didn't hold up to the flexing. I used BMW vacuum hose to splice the tubing around the hinge, 11 73 1 259 035. This is a silicon rubber hose. It is very supple and might last longer than our supply of petroleum. If you want to be stylish you can use 11 73 1 259 996. It is the same material but in blue rather than black. It is also available in red and white. |
Posted: Fri Mar 04, 2022 2:06 pm Post subject: Re: Windshield washer |
Greg-Car is currently "resting" comfortably in the ICU, but when it comes home I'll send some pics.
Duncan |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Fri Mar 04, 2022 2:44 pm Post subject: Re: Windshield washer |
hardway wrote: |
I have no problem with the plastic tubes. (...) The plastic didn't hold up to the flexing. (...) This is a silicon rubber hose. It is very supple and might last longer than our supply of petroleum. |
So... rubber is better than plastic then?
_________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
