Orangebug65sunroof Samba Member
Posted: Sat Jul 24, 2021 8:01 pm Post subject: Grinding on rebuild |
65 with 1600 recently rebuilt on the cheap. 50 50 chance it would work but looks like it’s going to need to be redone. Any advice opinions are welcome. Wherever this takes me I’d be keen on sharing the journey as I’m new to being a member but not new to the forums.
Here is the story.
Buttoned her up and installed an external oil filter. Little clearance on the belt pulley so had so shave some tin. Other than that started fine and timed. Did notice the gen light saying on and after about half hour of driving loss power but idle was fine. Limped home. Swapped out the alternator 12v but no luck light still on. Then the squealing grinding started. Thought it was the belt pulley hitting the oil pump but not the case. Sounds internal with some smoke coming out the oil breather/ carb.
So something is not right, clearly.
Next step pull engine and start over? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Jul 24, 2021 9:08 pm Post subject: Re: Grinding on rebuild |
Pull off the alternator belt. Start the engine just for a few seconds to see if the noise stopped. |
Posted: Sun Jul 25, 2021 5:42 pm Post subject: Re: Grinding on rebuild |
Yes sorry I should have mentioned that I tried running the engine without the pulley and the grinding is definitely internal occurs within 1min of running. Guess is a crank bearing that is not getting oil… maybe slipped off the dowel…turns over by hand just fine.
Dang really not looking forward to pulling the engine again.
Will post a photo but should have held a poll |
Posted: Wed Jul 28, 2021 6:15 pm Post subject: Re: Grinding on rebuild |
Just found out I accidentally flipped the generator and oil pressure lights. Therefore, I had a low oil pressure issue from the start, which would explain the grinding
Anyone out there ever run into low oil pressure from an external oil filter instal? There is oil going to the filter but it does not look like as much as you would expect…. |
Zundfolge1432 Samba Member
Posted: Wed Jul 28, 2021 6:31 pm Post subject: Re: Grinding on rebuild |
Bearings don’t slip off dowels |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Thu Jul 29, 2021 9:18 am Post subject: Re: Grinding on rebuild |
You say "installed an external oil filter".
Full flowed case or filter pump setup? |
Posted: Sat Jul 31, 2021 10:09 pm Post subject: Re: Grinding on rebuild |
Surprised no guesses.
Threw a rod because oil pump intake was blocked
Fun getting that off and stoked about taking one step forward and two steps back
Does anyone know where I can pick up a single connecting rod and with bearings? |
dustymojave Samba Member
Posted: Sun Aug 01, 2021 9:52 am Post subject: Re: Grinding on rebuild |
Bearings come as boxed sets.
Rods may be available separately, although they too are generally sold in sets. If you did damage to one rod's bearings, You may as well replace ALL of the bearings, main, rod and cam.
What was it that was blocking the oil pump intake?
And you did not answer the question above as to what sort of external oil filter.
Is it a filter-on-pump?
Is it from the top of the case stock oil cooler location?
Is it an out & back in oil pump?
Is it full flowed?
_________________ Richard
SoCalBajas Member
Posted: Sun Aug 01, 2021 10:02 am Post subject: Re: Grinding on rebuild |
Plenty of good used rods out there and try to find one close to the weight of the other 3. You might even find some bearings but I think it would be easier to just buy another set. How’s the crankshaft journal look?
Concerning replacing all the bearings I’d give them a real close visual inspection looking for any kind of foreign material embedded. I’d also think about using a different oil cooler. Another wild card? You might want to consider cleaning out the oil passages in the case halves.
Pictures would help us help you. |
Posted: Sun Aug 01, 2021 1:10 pm Post subject: Re: Grinding on rebuild |
Sorry y'all didnt see these other replies.
It is a spin on cheaply aftermarket oil pump and filter.
Pretty sure my culprit was another aftermarket spring piece that was blocking the pickup. When I found it
Point here is to not run and identify the obstruction if your oil pressure light come on.
Learning the hard way here.
So is there consensus about replacing all rods? Others seem fine. Just the one is fried and the journal has some melted on bearing that I'll try to sand off.
If a photo would help I can post once I get to it. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9771 Location: Oregon
Posted: Sun Aug 01, 2021 1:33 pm Post subject: Re: Grinding on rebuild |
Orangebug65sunroof wrote: |
Most here cannot read. But post a pic. And you'll get plenty of advice.
Besides, we love to see carnage pics. Sick fucks, we are! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Aug 01, 2021 6:34 pm Post subject: Re: Grinding on rebuild |
Welcome to my second shit show
[/img] |
Posted: Sun Aug 01, 2021 6:38 pm Post subject: Re: Grinding on rebuild |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Aug 01, 2021 6:44 pm Post subject: Re: Grinding on rebuild |
It made a "grinding" noise ? |
Posted: Sun Aug 01, 2021 6:53 pm Post subject: Re: Grinding on rebuild |
Close up of bearings from position 1. Cranked rod was 4.
I'd say I'm good ,
How close does the rods have to be?
Closest # I can give is 1lbs 4.4 oz |
Posted: Sun Aug 01, 2021 6:56 pm Post subject: Re: Grinding on rebuild |
Bearings cleaned up nicely.
Smooth even!
Must be that 20+ years of grime.
Wifey callen...thanks again everyone get lonely up here. |
Posted: Mon Aug 02, 2021 5:10 am Post subject: Re: Grinding on rebuild |
578.33 grams. give or take... |
Posted: Mon Aug 02, 2021 9:13 am Post subject: Re: Grinding on rebuild |
Just noticed bearing photo did not post. |
Posted: Sat Aug 14, 2021 1:56 pm Post subject: Re: Grinding on rebuild |
Are you SURE that rod is bad? It should buff out, shouldn't it?
Lifter faces look pretty gronked too.
Looks like you're up for a complete rebuild. _________________ Richard
SoCalBajas Member
Posted: Tue Aug 31, 2021 7:31 pm Post subject: Re: Grinding on rebuild |
Update:
Picked up a rod from a local saint.
Bearings for the rods.
Buffed out the old melted bearings.
Feeling super proud putting the crank in the cleaned case and WTF
The crank doesn’t want to rotate…
Come on…the crank bearings adjacent to the gears are seized!
Guess since they are aluminum they shrunk when they heated up?
Oh and the case looks to have been thrust cut to 2mm and that bearing has quite a bit of play….
Worth going forward or cut my losses?
At this point it’s learning and brings back memories of working on small engines. |
