dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Sun Jul 25, 2021 4:03 pm Post subject: Remote Oil Filter with Thermostatic sandwich Adapter |
I mocked this up and while I was assembling I noticed that there is no IN or OUT on the Thermostat adapter.
The IN and OUT on the filter adapter are clearly marked.
The unit is Mishimoto. https://www.mishimoto.com/rear-mount-thermostatic-sandwich-plate.html#features
I've watched their video and they simply say cooler lines attach at ports. Are they reversable? Doesn't matter? I'm confused.
I appreciate the feedback. Thank you.
dgsaz |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Jul 25, 2021 4:22 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
Dump the Fram filter, they have cardboard internals _________________ Glenn
Member #1009
#BlueSquare |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4857 Location: sanger ca
Posted: Sun Jul 25, 2021 4:37 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
Glenn wrote: |
Dump the Fram filter, they have cardboard internals |
Nice answer to a question not asked.
OP, the cooler is non directional therefore no need to have a direction arrow _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Sun Jul 25, 2021 4:50 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
it appears the oil goes throgh the cooler first.
"in" is the passage that connects to the oil filter side.
"out" is the passage that connects to the engine(or adapter) side.
If you don't like people telling you fram is crap, paint the oil filter a different color. |
dgsaz Samba Member
Posted: Sun Jul 25, 2021 5:18 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
mcmscott wrote: |
Glenn wrote: |
OP, the cooler is non directional therefore no need to have a direction arrow |
It's not the cooler I'm trying to figure out. It's the sandwich thermostat that the filter attaches too. The gold fitting the filter screw onto.
As I understand the operation, the oil enters the filter adapter (IN), the oil goes down into the filter and back out through the filter adapter (OUT).
About 10% of the oil passes through the oil cooler.
When the oil temp reaches 185 degrees the thermostat adapter opens and all oil passes through the cooler.
My sincere apologies for the Fram filter, it was the only thing in the shop, the parts store was closed, i couldn't get an Uber,I was broke, they said it would be fun, all the cool kids are........I digress.
dgsaz
BTW my GGF was C.M.Scott |
dgsaz Samba Member
Posted: Sun Jul 25, 2021 5:26 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
modok wrote: |
It's not mine, I was holding it for a friend.
Here's another approach I looked at but the Filter hung too low so I went horizontal. What I'm trying to figure out is the IN/OUT on the thermostat adapter. The fitting in the middle.
dgsaz
modok Samba Member
Posted: Sun Jul 25, 2021 6:28 pm Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
In order to see what passage connects to where, take the oil filter off and look.
you could also blow in it and see where the air comes out.
Some people are averse to that, but I would.
Well.....I'd wipe it off first, but that's all you really need to do.
A little won't hurt. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Mon Jul 26, 2021 6:38 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
The sandwich plate is connected to the inlet side of the filter, with the oil flow being down from the filter head, through the plate, out the hose connected to the top side of the plate and back in the hose connected to the bottom side of the plate.
Between the two hose connections is a bypass gallery with a wax thermostat controlled plunger that closes off the bypass at the set temperature.
It really does not matter that much which way the oil flows through the cooler if there is airflow cooling it. _________________ Ancient vehicles and vessels
Olli from NJ Samba Member
Posted: Mon Jul 26, 2021 7:12 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
For a shorter filter you can use a WIX 51085. |
mark tucker Samba Member
Posted: Mon Jul 26, 2021 7:42 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
make a map and be sure what go's where. the oil needs to be filtered first. then to the cooler. so...in the outer portion of the fram filter( all the little holes or slots are the in.the outlet in the big ceter threaded hole in the filter. the cooler flows both ways it dont mater.unlkess it has a anti drain back valve witch I doubt. the fram filters are fine.people that have issues like to blame their dirt floor build failures on the fram filter and other things due to being tottaly clueless. I prefur the motorcraft filters.1 there pretty and 2, they usualy have bigger inlet slots.
Ive cut appart fram filters.none were "defective"broken,waded up or anything else. I have seen other filters that were. we did split 1 fram hp filter at the track. for regular cars they are fine.and most performance & race cars too. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Jul 26, 2021 7:53 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
Should be like this, if my memory is correct-
(expertly prepared in Lingwendil-CAD, apologies for the quality )
Blowing through the fittings will also give you a quick answer. It's easy to wrap your head around once you remember that the oil feed to the filter comes IN to the outside, and OUT through the center feed. The nipple in the center is the return to the engine.
For most purposes it doesn't matter the direction you plumb unless the cooler itself requires you to do it a particular way, or if you have a thermo-switch in the output of the cooler, for instance as a trigger for a fan or something like that. Which is actually a good idea, in my opinion.
_________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
Posted: Mon Jul 26, 2021 8:00 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
I would have to see the entire setup in my hands to be able to determan if thats correct. |
Posted: Mon Jul 26, 2021 9:45 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
The outlet of the filter goes up the centre threaded tube through the sandwich plate and into the engine.
So the sandwich plate hoses are on the inlet side of the filter. _________________ Ancient vehicles and vessels
dgsaz Samba Member
Posted: Mon Jul 26, 2021 11:12 am Post subject: Re: Remote Oil Filter with Thermostatic sandwich Adapter |
Lingwendil wrote: |
Correct. Lots of people erroneously believe that they bypass the filter when the cooler is active, but it's all on the inlet side. |
Thanks for the picture Lingwendil, well worth a 1000 words.
dgsaz |
