Noppingen Samba Member
Posted: Mon Jul 26, 2021 1:40 am Post subject: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Hi there.
I distilled a 62 to 65 wiring diagram from the JBugs and Clymer diagrams.
* Added wire gages
* Added some things like high/low beam relais,
* Added an optional clamp 15 relais
* Added carb cut off valve.
I'd be happy if some of you could please proof read it and give me some feedback for improvements. Commas and dots in wire gauges are mixed, I just noticed.
Page: https://kaefer.onderka.com/artikel/stromlaufplan-kaefer-1962-1965
Ed:
See post #3
Slow-N-Rusty Samba Member
Posted: Mon Jul 26, 2021 10:02 am Post subject: Re: 1962-1965 beetle wiring diagram - redrawn, please proof read |
I think the only think I noticed that needed correction was the 'relais'. It should be spelled 'relay'. Relays would be plural but since the diagram is calling out each individual relay its just 'relay'.
Great job, by the way.
Al |
Posted: Mon Jul 26, 2021 10:46 am Post subject: Re: 1962-1965 beetle wiring diagram - redrawn, please proof read |
Thanks or the feedback!
* Fixed the Typo
* Clearly marked as beta version
* Added a legend below the heading for gauge units and clamp/terminal info
* Disabled web server caching of pdf files so you always get the current version
* Added wiper motor clamp numbers
And now it's official:
https://kaefer.onderka.com/artikel/stromlaufplan-kaefer-1962-1965/
Thanks again! |
bw65vw Samba Member
Joined: August 04, 2020 Posts: 149 Location: Tennessee
Posted: Tue Jul 27, 2021 1:16 pm Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Very nice job! It looks to me based on the right vs left and front to back you have spark plug #2 and #3 transposed. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 27, 2021 1:48 pm Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Would change "Generator Charging Warning Light"
to "Generator Charging & Engine Cooling Warning Light". _________________ In Stereo, Where Available! |
Posted: Tue Jul 27, 2021 2:01 pm Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
A generator should have a regulator shown. _________________ In Stereo, Where Available! |
Posted: Tue Jul 27, 2021 2:05 pm Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Battery ground strap goes to the body, not engine. Ghia goes directly to the engine.
Starter solenoid would be good to list. _________________ In Stereo, Where Available! |
Posted: Wed Jul 28, 2021 8:23 am Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Looks great!
Only other thing that I can think of to be updated is to show the chassi to transaxle ground strap. Mayhaps it could be squeezed in between the starter and battery.
Might be that it would be a bit clearer to newer folk if #1 & 2 spark plugs were on the other side (upper of diagram) of the distributor. _________________ In Stereo, Where Available! |
Posted: Wed Jul 28, 2021 11:30 am Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
Release 10: Added ground strap #2. Might change the spark plug and distributor arrangement tomorrow.
Release 11: Changed position of distributor, spark plugs and stuff.
Hope I didn't introduce new bugs features. |
napgonz Samba Member
Posted: Tue Aug 08, 2023 5:04 pm Post subject: Re: 1962-1965 beetle wiring diagram - redrawn as PDF file |
This is so awesome! thank you for taking the time to make it the way it is. |
