jlinares Samba Member
Joined: June 30, 2018 Posts: 71 Location: Distrito Capital de Bogotá
Posted: Mon Jul 26, 2021 9:33 am Post subject: Is it possible to fix sump cover? |
Recently changed oil in my 1966 beetle, and the plug of the sump cover was not sealing correctly. I went to see the replacement but it's too ugly and I like all my car to be as original as possible so buying 4 thick washers was my solution. With them, the plug seems to tighten real good, but yesterday I found it is leaking.
Is there a way to fix this cover? |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Mon Jul 26, 2021 12:58 pm Post subject: Re: Is it possible to fix sump cover? |
jlinares wrote: |
Wait your really joking right about a sump cover ???? If a replacement would help solve your leak then why not just use it ..its not like everybody is gonna be under your car just to bash you about a repop cover 🙄 come on man some folks really are taking this to another level... |
Posted: Mon Jul 26, 2021 1:03 pm Post subject: Re: Is it possible to fix sump cover? |
[email protected] wrote: |
jlinares wrote: |
You're* And I'm not. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jul 26, 2021 1:12 pm Post subject: Re: Is it possible to fix sump cover? |
source an original cover and bolt
https://www.thesamba.com/vw/classifieds/search.php...ton=Search _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Mon Jul 26, 2021 1:59 pm Post subject: Re: Is it possible to fix sump cover? |
jlinares wrote: |
... the plug of the sump cover was not sealing correctly. I went to see the replacement but it's too ugly and I like all my car to be as original as possible so buying 4 thick washers was my solution. With them, the plug seems to tighten real good, but yesterday I found it is leaking. |
We are talking about the round cover plate that sandwiches the oil strainer to the case opening, right?
I'm taking it that your leak is around the drain plug which screws into the center of the plate? And to stop the leak you are running 4 metal washers? Running 4 metal washers will leak. Metal does not seal well against metal of the same type (steel washers).
Your problem suggests the threads on the drain plug may be stripped. By using more washers you are pushing the drain plug further out threading only to the tip of the plug threads. Take a look at the threads of your drain plug. Are the threads buggered up near the head? If so, all you need is a new drain plug.
Another option is to just use a thick neoprene washer like in the below pic.
This looks like a black rubber washer/gasket, but neoprene is better where oil is used as it doesn't break down. The thicker seal holds the plug out further and makes for a better seal than stock metal crush washers.
Clean off the surface of the plate and the flat on the head of the drain plug so the square washer has a good sealing surface.
If you need to buy a new drain plug, I recommend one with a magnet to trap metal particles in the oil strainer. _________________ AshMan40
67conv Samba Member
Joined: July 10, 2005 Posts: 386 Location: Simi Valley, California
Posted: Mon Jul 26, 2021 3:26 pm Post subject: Re: Is it possible to fix sump cover? |
You could also try using a HOLLOW style (not flat!) copper or aluminum CRUSH washer under the drain bolt head - specifically designed for preventing this type of leaking issue. Worked like a charm for me!
Belmetric likely has what you need...
https://www.belmetric.com/hollow-crush-washers-c-4_2121_2124/ _________________ 1967 VW Convertible, owned /driven /pampered for 34 years.
1957 DKW 3=6, owned /driven /risen from the dead for 20 years.
Previously owned: 72 "Baja Champion SE" Spec. Edition Super Beetle bought NEW; 79 Convertible bought NEW; 67 type 1 savanna beige; 67 2.0 911S; 73 2.4 911T; 63 356 T6 B Cabriolet; 64 356 SC sunroof coupe; 72 Type-3 Squareback; 68 + 69 Type-3 Fastbacks; 87 Vanagon GL Wasserboxer |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Mon Jul 26, 2021 5:05 pm Post subject: Re: Is it possible to fix sump cover? |
I read this as he's talking about the center drain plug too.
Use an original copper crush washer like 67conv stated and you should be good to go.
More:
I've never seen that drain plug leak because of the bolt but I guess the threads could be damaged or wallowed out on the plate?
Buy another original plate and/or bolt, they are super common.
You can even buy a brand new VW of Mexico plate if you want, I think they even have them at your local VW dealer. _________________ How to Post Photos
TheRide Samba Member
Joined: May 06, 2019 Posts: 293 Location: North Carolina
Posted: Mon Jul 26, 2021 8:48 pm Post subject: Re: Is it possible to fix sump cover? |
67conv wrote: |
https://www.belmetric.com/hollow-crush-washers-c-4_2121_2124/ |
this |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1084 Location: Dover, DE
Posted: Wed Jul 28, 2021 7:05 am Post subject: Re: Is it possible to fix sump cover? |
67conv wrote: |
To save me from having to drain my oil just to measure the washer, can you tell me what size to look for? _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
67conv Samba Member
Posted: Wed Jul 28, 2021 7:50 am Post subject: Re: Is it possible to fix sump cover? |
14 mm inside diameter x 20 mm outside.
https://www.belmetric.com/hollow-crush-washers-c-4...t0epgci1k4
order a handful.. _________________ 1967 VW Convertible, owned /driven /pampered for 34 years.
