Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1089 Location: Atlanta, GA
Posted: Sun Aug 15, 2021 9:33 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Thanks coqcitywesty! Here's some things I learned through my process that may help you when you get to your donor car:
-I thought I had all the nuts and bolts removed to take the dash out, but it would not budge. Discovered that under the flat trim piece at the bottom of the windshield there's 2 10mm fasteners that need to be removed.
-The metal dash bar has two vertical supports that bolt to the transmission tunnel. There's 4 bolts there, 2 12mm hex, and 2 safety bolts. I didn't have a safety bolt socket or bit, so I used vice grips to get the bolts to turn and get them out.
-Make sure both heater hoses and firewall grommets are removed before trying to wrestle with the big white heater core box.
-Don't just grab a fist full of harness and pull through the metal hole in the firewall and body work. There may be some sharp edges that could cut into your wires.
-If your donor has front collision damage you may find that the holes in the inner fenders that the harness passes through will need to be opened up. The connectors for the abs and the parts of the fuse box connectors need room to pass through. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Posted: Mon Aug 16, 2021 7:15 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
@ Captain Pike-Is that the schematic from your conversion? _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Mon Aug 16, 2021 9:03 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Its a guide to make understanding the harness easier. I took over this conversion and the harness was already there. Its was made by Autoventures.
Plug and play. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1196 Location: Vancouver, BC
Posted: Tue Aug 17, 2021 3:33 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Not a Vanagon but nothing but smiles after all the work is done!
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Wed Aug 18, 2021 11:03 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Jake de Villiers wrote: |
Shonandb wrote: |
That's a great feeling! Sounds really good! |
Thanks! _________________ *******************************
Posted: Wed Aug 18, 2021 2:11 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
@Shonandb-That looks and sounds great! _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Thu Aug 19, 2021 1:09 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Silverghost500 wrote: |
@Shonandb-That looks and sounds great! |
Thanks and all the best with your conversion. My engine only had 140,000 km on it so I didn't touch the bottom end, just had the heads done, new water pump, new timing belt kit, and new gaskets and seals all around. Used a mix of Small Car's and Busaru's Kits and did everything myself (except truing the heads) including the harness and all the mechanical. Really happy with how it turned out and love driving it. _________________ *******************************
Posted: Mon Sep 06, 2021 7:26 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Made some progress this week. I'm finally at a point where I'm not pulling parts off the donor. What a dirty, disgusting beast that thing has been!
Dropped off the cylinder heads to the machine shop spa and wine bar. Will find out if they're still good to be rebuilt, or turn into future door stops.
Packaged up the wiring harness & electrical components, and shipped them to Jeff @ Autoventures. I'm really looking forward to see the changes to the modified wiring harness.
I want to say thank you to all of you that I've had direct conversations with and those in the forums for talking some things through and offering advice & suggestions!
My focus over the next month will be putting together a complete drivetrain, engine and modified transmission. Then I'll focus on the van conversion specific parts. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Mon Sep 13, 2021 2:51 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
My conversion process has ground to a halt. The UPS Store that I shipped my wiring harness, ECU, transmission controller, etc. out of lost my shipment. How? They put my label on the wrong package! There's no checks & balance system that should have caught a label indicating a 35 pound package on a 1 pound envelope, or vice versa.
I've been dealing with the UPS store manager for over a week now. I've asked repeatedly for phone calls or emails to give me status updates, and I've always had to call. Today I went in person and spoke with the manager, who claims they're calling all these people, but no progress. I'm no closer to a solution than when I found out the wrong package was received.
I'm glad I took out insurance on the shipment, but dang! I really don't want to go down the road of having to find another wiring harness and all the electrical components again. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Tue Sep 14, 2021 8:51 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
^..man what a bummer....I wonder if with the engine issues you had with your donor if just a new donor is an easier solution. Sorry that happened to you. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Joined: January 01, 2007 Posts: 16885 Location: sticksville, ct.
Posted: Tue Sep 14, 2021 9:32 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
have you reached out to jeff? sometimes he has a spare harness or 3 laying around.
that is a real pain in the ass. hopefully they will find your harness or get you a refund. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Feb 08, 2022 12:46 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Finally found someone who would take this stupid, cursed Subaru donor out of my basement and out of my life! From the moment this vehicle came off the trailer to become a donor, to the moment the guy pulled out of the driveway with it on a flatbed it has been one mishap and calamity after another.
I'll be starting over now. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Energy Concepts Samba Member
Joined: March 12, 2007 Posts: 352 Location: Yacolt, WA
Posted: Wed Feb 09, 2022 4:57 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Re Group & Re Supply !!!
Better Days Ahead !!!
JC...
Jorma Kaukonen sez:
Well now, what is going to happen now is anybody's guess
If I can't spend my time with love I guess I need a rest
Time is getting late now and the sun is getting low
My body's getting tired of carryin' this heavy load
And sunshine's waiting for me a little further down the road !!! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Wed Feb 09, 2022 7:01 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
My conversion is not a Subaru .......... but, I'll share a piece of my story.
I determined up front that I should be the one to "make" the wiring harness, etc., because if and when problems (and there will be) show their ugly face, I'll be the one that will have to address them.
Using the Bentley Manual for my donor vehicle, I spent a lot of time deciphering the harness (it was in a garbage bag). I also did the same with the Vanagon wiring system particularly those aspects that would be integrated with the new engine. I copied the electrical schematics for making notes, etc.
Anyway, when I finished, there were over 50 circuits from the ECU and Relays under the back seat to the Cluster and back to the engine. (I installed the Jetta TDI Cluster).
I saved all of my notes and arranged them in a Ring Binder for future use.
I'm sorry you've had such a horrible experience! As others have said, re-group and move on with your conversion. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Posted: Wed Feb 09, 2022 10:17 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
Thanks for the support. It's been a disappointing experience. I still intend to perform the engine and transmission conversion. I look back on the missteps during this process and kick myself for allowing some of it to happen. But hindsight and all that.
The deal breaker has been the lost wiring harness and computer components. You would think it wouldn't be that difficult to source replacement components for a 2001 Forester 2.5 with automatic transmission, but it is. I have contacted many different resources, visited junkyard sites, Fleabay, Samba, and other entities. Components are either incompatible with what I need, damaged beyond usability, or priced to a point it'd be just as well to buy another complete donor car and start over.
If I bought another donor car I could work in the comfort of my basement and take my time out of the elements, while having my tools needed to do the job at hand. I don't want to go that route after experiencing how difficult it was to find someone who would take what was left of the original donor car.
There are some junkyards 2-3+ hours away that might have what I need, but I cannot get anyone over the phone to confirm that what I need is still on those cars and undamaged. If I went the junkyard route I'd have to figure out ways to extract what I need without damaging them in under six to eight hours. That's what concerns me. It took me three days to pull the harness and components off my original donor.
I'm sure some of you who've pulled those components yourself a few times are laughing at how much time it took me. If you have ways you get those components out quickly without damaging them I'm open to suggestions! _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Wed Feb 09, 2022 11:19 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
so are you ditching the subaru all together?
depending how crispy the car is, i can harvest an engine and harness in about 3/4 of a day including clean up.
i don't bother playing nice with the dash. stuff gets cut out of the way.
i'm also surprised that you had an issue getting rid of the carcass. those "we buy junk car" guys are plentiful here, and in fact are like buzzards.
if you are staying with the conversion, let me know. i may have a hail mary for you.
one option may be a copart auction if there is one local to you _________________
Jake Raby wrote: |
Brian wrote: |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Wed Feb 09, 2022 11:50 am Post subject: Re: Going To The Dark Side-A Subaru Conversion |
It took me three days to pull the harness and components off my original donor. I'm sure some of you who've pulled those components yourself a few times are laughing at how much time it took me. If you have ways you get those components out quickly without damaging them I'm open to suggestions! |
Definitely not laughing at the time investment and wholeheartedly agree that the harness extraction is a major PITA. Working with an experienced Subaru tech and another VW mechanic, my engine extraction took around 1.5 - 2 hours and the harness, another 3 - 3.5 hours with not a lot of love or mercy left for the dash components. Your insights (above) as the remaining fasteners proved invaluable. I cannot imagine the PITA and time factor without the insights of my Subaru buddy and him not needing to bag or label anything coming out, which is definitely not my way of working through this type of project if solo. The only things we clipped on the harness (to get it out) were the headlight and front airbag sensors. It weighed about 30 lbs when removed and when I got it back (modified) from SmallCar, it weighed about 10 lbs so lots of extras from the factory.
I am hoping that the actual re & re happens in the coming weeks. Stay tuned.
Sorry that your first experience was tainted, but I am certain that the next one will be that much more efficient given the learning curve.
Best of luck. _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
Posted: Wed Feb 09, 2022 1:36 pm Post subject: Re: Going To The Dark Side-A Subaru Conversion |
@coqcitywesty, it is a royal pain to remove them. I was a bit more careful with my original donor when removing the dash components. If I have to do it again, I won't be.
Are you and Skills going out to junkyards with battery operated sawzalls and hacking components out of the way? Do the junkyards pitch a fit when you do that?
@Skills, if you've got eyes and ears on harness components that would work with my 2001 Forester Automatic PM me. I'd be interested in hearing what you've got access to.
Yeah, you'd think with all these "We Buy Junk Car" outfits I'd almost have a bidding war on the donor carcass. Nope! Down here none of them wanted it unless the complete engine, transmission, and OEM catalytic converters were included. Then they "might" give me $150 for it.
Those places referred me to scrap yards. The only scrap yard that was somewhat interested in it would give me 8 cents per 100 pounds, and that was if those same components were included, and I had to bring it to them.
I finally found a guy who took it off for free.
Back to the wiring and computer dilemma...I've probably said this before, but after all these years and as many Subaru/Vanagon conversions done you'd think some vendors would produce a plug-n-play computer and wiring kit for bracketed year models of Subarus. Even if they used iWire or Link computers vs. OEM Subaru computers. Guess it's not enough of a market and not enough profit margins to pursue it. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
