donovjim Samba Member
Joined: June 27, 2014 Posts: 100 Location: NovaScotia
Posted: Tue Jul 27, 2021 4:49 am Post subject: auto tranny leak - 1970 squareback |
'70 squareback - converted to dual EMPis and electronic ignition- tranny leak repaired now into the start up phase.
Im mechanical but far from a mechanic- doesnt help Im in eastern Canada and no one here has seen one of these since their adult grandkids were in diapers.
Earlier this year with help from you guys here i managed to remove the engine and tranny. Im at the final reinstall details now.... but as I search tech threads here and the www Im having an issue understanding what to do with a couple of hoses. a couple of questions..can you help?
Hose from the automatic transmission modulator valve ... Benley cant help as i have carb swap so what do i do with that hose now?
Vacuum advance on he distributor- I lost track of where that went at disassembly- where to direct that line?
'apreciate any help JD |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Tue Jul 27, 2021 9:55 am Post subject: Re: auto tranny leak - 1970 squareback |
All dual carbs are supposed to have a vacuum balance tube between them.
You can drill/tap the EMPI aluminum intake manifolds to add matching outlets.
Remember you want the balance tube pointed to the back of the engine, so you drill & tap the manifolds differently.
Steel dual Solex manifolds have matching outlets on them.
Put a tee in it for vacuum balance tube for a third outlet back to your automatic transmission modulator valve. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5360 Location: Lefty, CA
Posted: Wed Jul 28, 2021 4:25 am Post subject: Re: auto tranny leak - 1970 squareback |
Guys- that so far over my head you have no idea!
I have to do this in a non technical/ very simple way- I’m not able to drill and tap a manifold …. The car functioned well enough previously these 2 tubes went “somewhere”.
Im thinking the one at the distributor went to a (male) port inlet at the bottom of the left carb- I’m thinking the one from tranny went to a similar port on the right carb.
On the balance of probabilities- do you think this was the previous set up? |
