roadkingdoc Samba Member
Posted: Wed Jul 28, 2021 4:31 am Post subject: 6 volt or 12 volt voltage regulator |
I found a voltage regulator in my parts the other day. how do I tell if it is 12 volt or 6 volt. no marking on it. thanks |
mukluk Samba Member
Posted: Wed Jul 28, 2021 7:23 am Post subject: Re: 6 volt or 12 volt voltage regulator |
Voltage regulators typically have markings stamped into the metal legs used to bolt them in place. If none are there then it's likely an aftermarket piece and you'll need to look over the whole thing for any kind of identifying marks, part numbers etc, in order to figure out what it is. Posting up several clear pictures from different angles may help. _________________ 1960 Ragtop w/Semaphores "Inga" |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Jul 28, 2021 9:37 pm Post subject: Re: 6 volt or 12 volt voltage regulator |
A rough guide for VW regulators is that the six volt regulators have curved mounting legs and 12 volt do not since they are mounted in places other than the generator housing.The one above is a 12v. The one below is a 6v.
_________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Thu Jul 29, 2021 5:34 pm Post subject: Re: 6 volt or 12 volt voltage regulator |
well I think I have a 12 volt 38 amp Bosch regulator. can it be used on a beetle or bus? thanks |
mukluk Samba Member
Posted: Thu Jul 29, 2021 8:38 pm Post subject: Re: 6 volt or 12 volt voltage regulator |
roadkingdoc wrote: |
Only if it's paired with a GR-17 38 amp generator as used on some '68-'71 Type 2s. I wouldn't use it with your typical Type 1 GR-15 rated at 30 amps as it won't have the correct overcurrent protection. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri Jul 30, 2021 2:04 am Post subject: Re: 6 volt or 12 volt voltage regulator |
thanks so much for the help! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 30, 2021 6:22 pm Post subject: Re: 6 volt or 12 volt voltage regulator |
tasb wrote: |
As almost always there are exceptions....
Back in the late 1980s there were 6 volt sized generators with regulators on top (like the above image), that were a 12 volt unit. Think they were manufactured out of Nippon. Bought two of those gen/reg kits and ran them till the regulators needed to be adjusted. Still have them somewhere here... _________________ In Stereo, Where Available! |
