BUSorBUST Samba Member
Joined: March 05, 2013 Posts: 42 Location: Laguna Beach
Posted: Wed Jul 28, 2021 10:58 am Post subject: Split Bus disc brake conversion suggestions |
Need some help fellas-
Bought this 65 panel bus with this adjustable beam - don't think it matters what beam I have if the ends are stock drum?
Need suggestions for good disc brake options?
Thanks!
Brian
[/img] |
blitzkrieg59 Samba Member
Joined: July 04, 2001 Posts: 873 Location: Davenport, Iowa
Posted: Wed Jul 28, 2021 11:03 am Post subject: Re: Split Bus disc brake conversion suggestions |
This kit is currently out of stock, but it's what I'm planning on going with. It uses parts that are easily available at any local auto parts store anywhere in the country. A brilliant piece of kit, IMO.
https://type-emotorsports.com/products/type-e-ez-s...4739508284 _________________ SST X, XI, XII
'65 Riviera Camper |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Wed Jul 28, 2021 12:07 pm Post subject: Re: Split Bus disc brake conversion suggestions |
https://www.thesamba.com/vw/forum/viewtopic.php?t=475194&highlight=disc+brake _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
sled Samba Member
Posted: Wed Jul 28, 2021 12:32 pm Post subject: Re: Split Bus disc brake conversion suggestions |
yes, check out that thread posted above ^^^
but, as also mentioned above, the Type-E kit is definitely the best quality and price on the market. I have installed multiple on customer buses as well as run a set on one of my own buses. _________________ drive your split. |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 557 Location: I don't recognize it anymore
Posted: Wed Jul 28, 2021 1:26 pm Post subject: Re: Split Bus disc brake conversion suggestions |
you have 1 ton spindles, make sure you order accordingly.
Stay away from China stuff, it's crap. I installed a couple of these and had several problems w clearance - studs - one needed spacers.
I use SACO, it's a bit $$, but zero issues and complete kit. _________________ kaiser kills kids.com |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3439 Location: San Diego
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Wed Jul 28, 2021 6:34 pm Post subject: Re: Split Bus disc brake conversion suggestions |
I installed the Wolfgang Intl. kit on my '63 DC. It is a straight bolt-on, no mods to the vehicle. Easy install, no hiccups. It uses 73-79 Bus calipers and pads. Some grinding of the calipers is required to clear 15" stock wheels.
https://wolfgangint.com/home/1213-bus-front-disc-brake-conversions-kit-2615107b.html _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
buspeople Samba Member
Posted: Thu Jul 29, 2021 11:34 am Post subject: Re: Split Bus disc brake conversion suggestions |
Hi all, I just did a disc conversion on the front of my ‘58. The driver side tire for one is wearing super fast and uneven now, towards the inner part of the tire. The hub/rotor seems to be a little loose on both sides. My question is, is the hub and rotor supposed to have some play or should they be tight so as to be 1:1? Thanks |
Posted: Thu Jul 29, 2021 11:59 am Post subject: Re: Split Bus disc brake conversion suggestions |
Sounds like you have some loose nuts or bolts. Have you rechecked anything for tightness?
What kit? |
Posted: Thu Jul 29, 2021 12:08 pm Post subject: Re: Split Bus disc brake conversion suggestions |
I guess that is my main question is should I retorque the hub/rotor assemblies? The kit I installed was the billet bus kit from kustom1warehouse. |
Posted: Thu Jul 29, 2021 12:52 pm Post subject: Re: Split Bus disc brake conversion suggestions |
buspeople wrote: |
There should be no play or looseness of any sort between the rotor and hub. However, if the tire is suddenly wearing unevenly, I would look beyond the rotor. Something is very wrong and it could be quite dangerous. Check the axle nuts, any spacers and lug nuts. Start by jacking up the wheel and spinning it, looking for wobble and listening for noises. _________________ Craig ('51 WASP)
