vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Wed Jul 28, 2021 12:52 pm Post subject: Re: Rear hatch / Trunk lift supports - what is OEM strength / force? |
Gary lee indicates different strengths for the two sides, but no force numbers
The vanagon parts book specifies a different hatch strut for each side of the door.
Left side 251-829-331B lower strength
Right side 251-829-332 higher strength
http://vwrack.com/Ladder/Hatchsupport/hatchstruts.htm _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Timwhy Samba Member
Posted: Wed Jul 28, 2021 2:44 pm Post subject: Re: Rear hatch / Trunk lift supports - what is OEM strength / force? |
If you have a rack, bike rack or gas/spare tire rack on the hatch get these shocks from McMaster-Carr. Push the button watch the hatch go up!
2 each
Gas Spring
18.19" Extended Length, 250 lbs. Force
9416K28
2 Each
End Fitting for Gas Spring
Eyelet, M8 Thread Size, 0.32" ID
9416K88
2 Each
M8 Glass-Filled Nylon Snap-on Ball Socket End Fitting for Gas Spring
9416K76 _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Wed Jul 28, 2021 3:39 pm Post subject: Re: Rear hatch / Trunk lift supports - what is OEM strength / force? |
Timwhy wrote: |
If you have a rack, bike rack or gas/spare tire rack on the hatch get these shocks from McMaster-Carr. Push the button watch the hatch go up!..... |
Good info, thanks, and the direction I'm ultimately going though that is not the question I asked.
My Questions is
"What is the OEM force/strength specification for the rear lift supports?"
So I am starting at stock.
My ultimate destination is to get strengths that lift appropriately - not too much, not too little with the varying weight I have back there. Even Gary Lee cautions against mas strength all the time citing danger of self-opening speed and difficulty to pull down.
BTW, McMaster car for that order is $53 + shipping. Lift support depot is $56 shipping included (you can specify one eyelet and one bass socket) https://www.liftsupportsdepot.com/20-35-lift-suppo...-250e32-w/ _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
jimf909 Samba Member
Posted: Wed Jul 28, 2021 4:42 pm Post subject: Re: Rear hatch / Trunk lift supports - what is OEM strength / force? |
I removed a Stabilus from my van that was 300 N (67 lb) but I don't know if it was oem or a replacement. 250 lb struts held up the hatch with two mtn bikes on a Fiamma rack.
EDIT: Ha! The Stabilus shock has a url printed on it so it's clearly a replacement. doh.
Close-op of specs...
133 - 140 lbs sounds like a lot to me. I recall the Stabilus 67 lb strut working just fine. _________________ - Jim
Abscate wrote: |
jlrftype7 Samba Member
Posted: Thu Jul 29, 2021 11:38 am Post subject: Re: Rear hatch / Trunk lift supports - what is OEM strength / force? |
When I bought mine from Bus Depot in late 2018, they were offering 3 versions. I went with the middle version, it's def. got more lift than stock but not anything in a heavy lift like you would need with a bike rack or other rear hatch mounted item.
Hatch stays easy even in Winter when the shocks are really cold, so that's a nice bonus since it's a real pain when lift shocks are chilled and don't want to perform like normal in warmer weather. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
