bagilosi Samba Member
Posted: Wed Jul 28, 2021 11:44 pm Post subject: Front brake line |
I’m having real problems removing the flexible brake hose on the front brakes of my fasty.
I’ve never know anything like it. I’ve even removed the whole right hand section from the Brake Master Cylinder and held the copper brake line nut in a vice and I still can’t disconnect it. (It’s the 17mm nut and 11mm combo which just won’t shift)
I’m at risk of rounding the 11mm nut on the brake line which will mean I need to replace it.
If anybody has any serviceable front brake line sections they don’t need I’d be interested. I can’t see I’d going to be able to unbolt this.
I’m sure I’ll have the same problem on the longer left hand side (it’s a RHD car) so I’ll need both sides.
Any other suggestions welcome! _________________ Sexy beauties in sexy lingerie waiting for you here https://thesexygirlsinlingerie.com/ |
Scorpion1110 Samba Member
Joined: May 17, 2020 Posts: 43 Location: Maryland 21771
Posted: Thu Jul 29, 2021 6:24 am Post subject: Re: Front brake line |
Just a quick comment. To avoid the risk of rounding always use line wrenches on the fittings, unless the tolerance is too tight to fit the wrench head. If that's the case, there are line wrench vice grips that might work.
Also, use Kroil as a penetrating lubricant and always try and rock the fitting. Go forward and backward gently. You can also mix your own penetrant using a combination of Acetone and Automatic Transmission Fluid with a 50/50 ratio.
You're probably doing all this, but just in case.
Dave |
gt1953 Samba Member
Posted: Thu Jul 29, 2021 8:27 am Post subject: Re: Front brake line |
Soak it for a day or three. I had to use vide grips on mine and did not care if they got rounded. When the new ones want on I did have the line wrench. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Thu Jul 29, 2021 2:24 pm Post subject: Re: Front brake line |
gt1953 wrote: |
Soak it for a day or three. I had to use vide grips on mine and did not care if they got rounded. When the new ones want on I did have the line wrench. |
Yup. sometimes on that connection I'll use 2 vice grips, mostly for the leverage to "crack" the connection loose. Might be worth a shot. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
