timvw7476 Samba Member
Posted: Fri Jul 30, 2021 2:55 pm Post subject: Re: Minimal set of tools for a trip |
lunohod1 wrote: |
Abscate wrote: |
San ‘Frisco
Weed to bribe people to push you off the Bay Bridge.
Once done, don’t give it to them and tell them they are a co-victim of capitalism. Then go post angry stuff in the internets |
Don't push me I'm only here because my wife needs to check in with the local hospital every month. I would run if I can... |
The East is being smoked out by Western fires, & the central area is 105F.
Being on the West coast is oddly enough the best position on the board 7/30/21
winner winner chicken dinner ! |
danfromsyr Samba Member
Posted: Sun Aug 01, 2021 4:28 am Post subject: Re: Minimal set of tools for a trip |
no smoke here
not 100* either
our reservoirs are full
our lawns are green
but don't tell anyone _________________
Abscate wrote: |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3329 Location: 802 The Pointless Forrest
Posted: Sun Aug 01, 2021 10:36 am Post subject: Re: Minimal set of tools for a trip |
Yep our pond (spring fed ) has not dropped this summer, a little hazy last week for a day or two. High of seventy today. _________________ "Albatross"! |
Posted: Sun Aug 01, 2021 11:00 am Post subject: Re: Minimal set of tools for a trip |
Drove up US 395 last week taking a long detour into Nevada to get around the one Northern California fire and then camped at a hot springs only a few miles from the large fire in southern Oregon. We were told to be ready to leave on a moments notice, but the fire laid done well over night and we awoke to blue skies. Certainly been hazy in north central Oregon since our return but nothing all that bothersome. |
lunohod1 Samba Member
Posted: Sun Aug 01, 2021 12:37 pm Post subject: Re: Minimal set of tools for a trip |
aeromech wrote: |
Spare loaded distributor
Is there any specific model of distributor I need for this specific type of engine with carburator? Some folks recommend "009 Distributor, [made in] North America", but seems it's out of stock on aircooled.net - should I stick to this one? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sun Aug 01, 2021 12:53 pm Post subject: Re: Minimal set of tools for a trip |
The problem is someone stole the twin carbs your 1972 bus came with, and replaced it with thst crappy center mount carb.
The distributor has to get the right vacuum signal from the carb to advance correctly.
This is a typical bad cascade of life cycle in a Bay Bus, good OG parts are replaced with marginal crap based on price , and then poor running frustrates you.
Long term, it’s good to work your way back to the OG parts
Reach out to Robbie at airschooled.com and he can put you on the good path _________________ .ssS! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Aug 01, 2021 4:32 pm Post subject: Re: Minimal set of tools for a trip |
lunohod1 wrote: |
aeromech wrote: |
An exact copy of whatever your bus has in it when running well.
Those of us who have replaced them on a hot engine know it's easiest to pre-install and time the spare distributor so you won't be fumbling around on the side of the road, one nut/wire and you're done.
www.airschooled.com |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sun Aug 01, 2021 5:45 pm Post subject: Re: Minimal set of tools for a trip |
It’s a spare. I’d suggest an 009 and it can be a good used one.
Here’s one for $40 or contact Bill Fowler for a nicer one
https://www.thesamba.com/vw/classifieds/detail.php?id=2481455 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Aug 01, 2021 7:54 pm Post subject: Re: Minimal set of tools for a trip |
Normally I would as well, but if the OP is mechanically challenged finding a spare that uses the same cap and wire configuration would make that roadside swap so much more simple, leave the wires in the cap and snap it onto the new distributor. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Aug 01, 2021 8:17 pm Post subject: Re: Minimal set of tools for a trip |
That’s a good point but then you aren’t swapping in a good distributor cap _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 284 Location: East Tennessee
Posted: Sun Aug 01, 2021 11:38 pm Post subject: Re: Minimal set of tools for a trip |
I like Wildthings's list but want to add
-Magnetic pickup tool- so much easier than using a fork out of your kitchen box to retrieve that fallen #3 spark plug
-"claw" pickup tool for when the above is too short
-magnetic bowl for holding any nuts and washers and tin screws you may remove
-sandpaper
-small brass wire brush for cleaning out cv joint bolt heads or if you forget your toothbrush
-hookup wires with roachclips
-safety wire
-tire valve installation tool
-pry bar and/or crowbar
-hacksaw _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
