pwweiden Samba Member
Joined: November 16, 2012 Posts: 3 Location: Pennsylvania
Posted: Thu Jul 29, 2021 1:10 pm Post subject: Ignition problem |
I’ve just completed my Westfalen 1976 with a. 1600 engine. My problem is with ignition switch on and. A remote stater connected I have been able to start and run engine just fine. Now I remove remote starter switch and engine won’t start with ignition switch. Can it be he ignition switch or a wiring problem. The starter works fine with the switch but engine will not start. Once as I quit cram king the engine started when the switch went back to the run position but almost like a after thought. Anxious to get on the road any help would be appreciated.
Pete |
Starbucket Samba Member
Posted: Thu Jul 29, 2021 1:33 pm Post subject: Re: Ignition problem |
Bad electrical part of ignition switch. You can test by running a jumper wire from license plate light to + on coil, turn on parking lights and start the bus if it starts and runs it's the switch, turn off lights to stop motor. |
Jrh5r Samba Member
Joined: January 08, 2021 Posts: 33 Location: East coast
Posted: Thu Jul 29, 2021 3:47 pm Post subject: Re: Ignition problem |
Check your ground strap on the transmission. _________________ 1973 1.7L Bus |
Posted: Thu Jul 29, 2021 3:49 pm Post subject: Re: Ignition problem |
Check your voltage at the coil while cranking. Zero voltage may be a bad ignition switch and low voltage (<9v) could be bad wiring. If you have 9+ volts at the coil it could be bad points, condenser, or coil. |
Posted: Sat Jul 31, 2021 1:04 pm Post subject: Re: Ignition problem |
I’ve checked transmission ground it’s good.
I tried jumping from license plate light to coil in start position parking lights will not come on. There is no voltage at coil while cranking. I’ve retired the bus is it possible I got wires mixed? Sorry I’m new to the forum and not sure how to reply individually |
Posted: Sat Jul 31, 2021 1:56 pm Post subject: Re: Ignition problem |
The neg. (1) coil terminal stud goes to dist. the other wires go to + terminal. To reply to a poster clk. the quote tab and when you get the new screen move the bottom quote down a few lines and reply. |
Posted: Mon Aug 02, 2021 7:18 am Post subject: Re: Ignition problem |
Starbucket wrote: |
Thanks for the come back. Since I retired the complete bus I’m going to track all the coil circuits. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Tue Aug 03, 2021 10:12 am Post subject: Re: Ignition problem |
It is a quite common fault that the ignition switch disconnects the coil when you are cranking. If that happens, the switch is worn out.
The moving part of the switch eventually cuts through the stationary part inside the switch, helped by the current flowing - see EDM machining for the effect in question. _________________ Ancient vehicles and vessels
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Aug 05, 2021 9:53 am Post subject: Re: Ignition problem |
mikedjames wrote: |
The moving part of the switch eventually cuts through the stationary part inside the switch, helped by the current flowing - see EDM machining for the effect in question. |
That and if it is one of the craqppy new switches, the plastic likes to melt and the contacts move and are no longer contacts... |
