VJP5 Samba Member
Joined: May 22, 2021 Posts: 52 Location: San Diego, CA
Posted: Fri Jul 30, 2021 2:18 pm Post subject: Jumper seat bracket and a ruler - help please? |
Hi
I have a 1988 tin top that had 2 jumper seats at one time (prior to my ownership). I recently had the front re-carpeted but the installers did not mark where the bracket holes were. I want to use these for tie-downs for my fridge/cooler. I was able to find one, as you can see it from the battery compartment. However the other side is alluding me. I have tried 'poking' around but am not confidant of the location. I do not want to tear up brand new carpet.
If there is someone out there that has a jumper seat (behind the front passenger side), I would really appreciate it if you could measure where the right side (facing it) bolt hole is and let me know the distance.
I realize this is a trivial request, but I don't know where else to turn.
Thanks
Vince _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Fri Jul 30, 2021 4:59 pm Post subject: Re: Jumper seat bracket and a ruler - help please? |
Following! Recently purchased a jump seat (like new) to accommodate the grandkids. Machined a pair of pin receivers for the floor and made the reinforcements for the bracket but would like the actual dimensions for both. _________________ Schau in das Buch |
mdub Samba Member
Joined: February 05, 2020 Posts: 48 Location: Bellingham, WA
Posted: Fri Jul 30, 2021 6:01 pm Post subject: Re: Jumper seat bracket and a ruler - help please? |
Here you go! looks like 16 3/8" center to center spacing L to R, and there's a 2nd row of bolts 1 7/8" down from the upper row. _________________ '86 Syncro / Reimo Poptop / EJ22 |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Fri Jul 30, 2021 6:12 pm Post subject: Re: Jumper seat bracket and a ruler - help please? |
Another reply. There are two bolts arranged vertically on the right side of the bracket, mirroring the left side shown above.. They are each 3 5/8” from the inside face of the B pillar. The lower bolt is 2 7/8” below the top of the battery compartment. The bolts are 1 7/8” C-t-C. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
DuncanS Samba Member
Posted: Fri Jul 30, 2021 6:51 pm Post subject: Re: Jumper seat bracket and a ruler - help please? |
Pull the expansion tank and drill from the other side. |
VJP5 Samba Member
Posted: Sat Jul 31, 2021 5:08 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
Awesome!! Thanks for the replies. Between the pictures and RRs clarifications, I’m in business.
Really appreciate the help. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
Posted: Sat Jul 31, 2021 2:17 pm Post subject: Re: Jumper seat bracket and a ruler - help please? |
VJP5 wrote: |
Really appreciate the help. |
😁👍 _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
VJP5 Samba Member
Posted: Mon Aug 02, 2021 5:17 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
Red Ryder wrote: |
....They are each 3 5/8” from the inside face of the B pillar. The lower bolt is 2 7/8” below the top of the battery compartment. The bolts are 1 7/8” C-t-C. |
This ^ put me 'spot on'
Thanks again _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
Posted: Mon Aug 02, 2021 10:03 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
Nice!🤗 _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
Posted: Mon Aug 02, 2021 11:10 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
What are the D rings for? |
4Gears4Tires Samba Member
Posted: Mon Aug 02, 2021 11:18 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
VJP5 wrote: |
I want to use these for tie-downs for my fridge/cooler. |
_________________ '87 Syncro
Posted: Mon Aug 02, 2021 11:25 am Post subject: Re: Jumper seat bracket and a ruler - help please? |
Got it. Right in the first post. Somehow, I was fixed on the jumpsuit bracket itself and missed that. Hope the fridge/cooler is less than 16 3/8ths wide. |
