Clutch Issues
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 11:17 am    Post subject: Clutch Issues Reply with quote
Couldn't get the bus in gear all of a sudden. Clutch cable is fine, less than 3 years old. Connections are good at the ffront and back and it engages the clutch arm at the rear of the bus fully. I adjusted the tension a bit to tighten it up a little. Just doesn't want to go into gear when it's running. Engine noise changes when I dip the clutch and there's a faint hissing sound which has been going on for a while tbh. Do I have a possible clutch plate issue? I've noiticed a few times over the past 3-4 months that te clutch felt different when dipping it. Vibrating a little as I apply pressure.
Thanks for any tips.
1970, Deluxe, 1600cc, Type 1 Dual Port
[url=http://www.vw-mplate.com/mplate2-35638.png]Click to view image[/URL]
cmonSTART
cmonSTART is offline
PostPosted: Sun Aug 01, 2021 11:28 am    Post subject: Re: Clutch Issues Reply with quote
Did you change your pilot bearing when you did your clutch?
'78 Bus 2.0FI
de K1IGS
Wildthings
Wildthings is offline
PostPosted: Sun Aug 01, 2021 11:32 am    Post subject: Re: Clutch Issues Reply with quote
Pilot bearing or clutch lining coming apart. Either will require the engine to be pulled.
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 11:57 am    Post subject: Re: Clutch Issues Reply with quote
I did not replace the pilot bearing!
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 12:27 pm    Post subject: Re: Clutch Issues Reply with quote
Is that the same as the throw-out bearing from Muir?
Thank guys looks like it's going into the shop for the first time since i've had it if the engine needs dropping. 8 years.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Aug 01, 2021 12:30 pm    Post subject: Re: Clutch Issues Reply with quote
on a 1970 it isn't that big a job to replace a clutch and pilot bearing. Finding high quality replacement parts will be the biggest part of the job. Get a hold of Robbie to see if he has suggestions. https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=290054
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Wildthings
PostPosted: Sun Aug 01, 2021 12:31 pm    Post subject: Re: Clutch Issues Reply with quote
The throwout bearing and the pilot bearing/gland nut are different. If you are paying a shop to do the work, you probably will want them to just buy a clutch kit and redo the entire clutch, rear main seal, and tranny input shaft seal while they are in there.
On a Type 4 motor I like to used the "diesel" style pilot bearing as used on other VW and Audi products, but have never tried on a Type 1, but think it could be made to work easily enough. Maybe others will comment.
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 12:38 pm    Post subject: Re: Clutch Issues Reply with quote
Ok, I'll research how to do it. Appreciate the guidance. If the engine needs to come out I've no chance though.
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 1:41 pm    Post subject: Re: Clutch Issues Reply with quote
I think if the pilot bearing is bad you’ll see two things. Engine running = no shifting. Engine off = shifting
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 1:53 pm    Post subject: Re: Clutch Issues Reply with quote
Yes. It's not shifting when running but fine when it's off. Does that confirm it?
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 1:56 pm    Post subject: Re: Clutch Issues Reply with quote
I'd say so. Just so you know, when you buy the sachs clutch kit it comes with a pilot bearing
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 2:27 pm    Post subject: Re: Clutch Issues Reply with quote
Ok I will look that one up. Thank you.
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 3:00 pm    Post subject: Re: Clutch Issues Reply with quote
https://www.autohausaz.com/pn/KF19301
or rigid
https://www.autohausaz.com/pn/KF19302
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 3:18 pm    Post subject: Re: Clutch Issues Reply with quote
Thanks so much. Which would you get. Rigid or Super Kit?
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 3:37 pm    Post subject: Re: Clutch Issues Reply with quote
I like the spring type
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Aug 01, 2021 4:29 pm    Post subject: Re: Clutch Issues Reply with quote
A warped pressure plate gives identical symptoms:
Your 1970 should have the "early/collar" style pressure plate, but who knows what's happened after five decades of hippie fixes.
https://www.thesamba.com/vw/forum/viewtopic.php?t=148307
New plates can be a crap shoot, buy the oldest one you can.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
tunnvar
tunnvar is offline
PostPosted: Sun Aug 01, 2021 5:43 pm    Post subject: Re: Clutch Issues Reply with quote
There's no way of knowing unless the engine comes out right? Thank you for the advice.
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 5:51 pm    Post subject: Re: Clutch Issues Reply with quote
I ordered that Sachs kit a few weeks ago. It cost about $100 less than my local VW parts supply and arrived within a week.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Wildthings
PostPosted: Sun Aug 01, 2021 9:19 pm    Post subject: Re: Clutch Issues Reply with quote
I would say to not order parts until the engine is on the floor and the clutch disassembled.
aeromech
aeromech is offline
PostPosted: Sun Aug 01, 2021 10:16 pm    Post subject: Re: Clutch Issues Reply with quote
That's good advice if you have the time. How old is your existing clutch anyway?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
