ncpi Samba Member
Posted: Mon Aug 02, 2021 7:50 am Post subject: Rubber part vendors |
I recently ordered parts from Wolfsburg West. I'd heard good things about them and thought I'd give them a shot.
I ordered the fuel tank rubber hose kit (supposed to be German hoses), and clamp kit and the rear bumper grommets for my 74 SB.
About a month after installation I smelled fuel pretty strongly after a fill up. Found the overflow hose was split. The tube it is over doesn't seem to have sharp edges, i removed the original cloth cover hose from it.. the clamp didn't really feel sharp either. WW is sending me a replacement. Kind of disappointed it failed so soon.
On the rubber rear bumper grommets, they seem to not be the correct shape, they don't extend low enough, actually seems like the hole is too high for the bumper shock. The old dried out ones fit better.
Is there a vendor recommended that is your favorite for rubber parts? |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1385 Location: Wichita, KS
Posted: Mon Aug 02, 2021 8:15 am Post subject: Re: Rubber part vendors |
I had similar issues with some of Wolfsburg West's (and other vendors') rubber parts a few years back. For Wolfsburg West, I just sent them pictures of the failed parts, and they refunded my money for those w/ no hassle. _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Mon Aug 02, 2021 8:45 am Post subject: Re: Rubber part vendors |
ncpi wrote: |
Did your overflow hose from the filler to the evap T come pre-bent? I just received mine from them, and was disappointed to find it was straight, and everytime I attempted to install, it would kink pretty bad. _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
I recently had the “gas fume smell” again, and bought all the hoses and rubber bits once again, and replaced them all. This time, however, I used 4 mm German Flennor braided hose for the vapor hoses. The split rubber elbow that you show was about seven or eight years old. I went ahead and replaced mine, but it was still in great shape. It was purchased from Wolfsburg West.
I have noticed that my Wolfsburg West manifold boots are beginning to crack, and those were replaced about five years ago. My engine has had few miles since replacing these, and since the engine also runs cool, it seems odd that they’re showing signs of cracking.
Also, the short rubber hose from the oil filler to the air cleaner needed replacement. I can’t remember where I bought it, however.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Mon Aug 02, 2021 8:47 am Post subject: Re: Rubber part vendors |
Q-Dog wrote: |
Try West Coast Metric. |
I second that statement! Best rubber parts available! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Mon Aug 02, 2021 9:01 am Post subject: Re: Rubber part vendors |
VW_Jimbo wrote: |
Q-Dog wrote: |
I second that statement! Best rubber parts available! |
Do they still have a lifetime warranty on their in-house rubber parts?
Though, last time I looked for replacement ball joint boots from WCM they were out of stock and after months waiting I gave up and bought some no-name boots which only lasted a year or two before cracking. It made me wonder if they gave up making some rubber parts?
And for those with short-lived cracked rubber hoses... are you running ethanol-free gasoline? There is a well understood problem where it comes to ethanol-based fuels drying up inside pure rubber hoses causing then to prematurely fail. Once ethanol gasoline was introduced all car manufacturers replaced all the rubber in the fuel systems with synthetic replacements. You often see this failure as the exposed ends of rubber hoses cracking after only months. It is especially noticeable in areas where fuel flows but then is allowed to dry up. Cars driven only weekly or less will probably see this happen sooner than daily drivers that maintain fuel in all the hoses between drives. Hoses below the fuel tank often last a long time but hoses at the tank filler go bad sooner as they are only part-time covered by fuel.
Even the black rubber intake boots suffer from this. Maybe good reason to switch to silicone intake boots. _________________ AshMan40
ncpi Samba Member
Posted: Mon Aug 02, 2021 9:04 am Post subject: Re: Rubber part vendors |
Thanks guys on the suggestion regarding West Coast Metric.
cjsuner - yes, that hose was pre-shaped/bent as was the one on the other end of the T fitting. The rubber "feels" kind of hard, not really soft/flexible as I would like to think.
FYI...The blue evap hoses are fuel rated tubing I bought from Amazon (not WW) and had installed earlier. |
ncpi Samba Member
Posted: Mon Aug 02, 2021 9:34 am Post subject: Re: Rubber part vendors |
Ashman40 - good question, ethanol is bad in many ways; from absorbing water to breaking down rubber/plastic parts that aren't designed to handle it.
However, I am actually using non-ethanol fuel. I am fortunate that is readily available to me where I live. |
Posted: Mon Aug 02, 2021 12:35 pm Post subject: Re: Rubber part vendors |
Well, Ashman, it was recommended on the Samba to buy the black Wolfsburg West “German” manifold boots, since folks were having premature failure with the orange silicone boots that other vendors were offering at the time. And I’m just now noticing some small cracks, which is odd since I don’t drive the Bug that much, and my engine runs very cool, having all its tins and seals.
Richard O'Brien |
Posted: Mon Aug 02, 2021 1:33 pm Post subject: Re: Rubber part vendors |
I've had mixed experiences with a lot of the currently available rubber & polymer replacement parts over past few years, from a variety of vendors. Some seem to hold up just fine, while others will start to crack and/or disintegrate almost immediately.
I've personally had to just keep trying various different parts from various suppliers, until I found example(s) which actually held up. In some cases, I'm still searching (e.g. ball joint boots -- been through 3 sets of those so far, and still no luck). It's aggravating, at best... _________________ 1971 Standard Beetle — fairly stock / driver
fredybear Samba Member
Posted: Mon Aug 02, 2021 5:03 pm Post subject: Re: Rubber part vendors |
WCM
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 636 Location: Louisiana
Posted: Mon Aug 02, 2021 7:39 pm Post subject: Re: Rubber part vendors |
Let us know how everything fits.
Thanks _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
wheel607 Samba Member
Posted: Tue Aug 03, 2021 2:08 am Post subject: Re: Rubber part vendors |
WCM and Wolfsburg West used to sell parts to each other. Not one person can stock everything so they chose to sell to each other. If this is still the case, you will get most of the same parts by buying from each dealer. I would check and see if this is still the case. |
Posted: Tue Aug 03, 2021 9:03 am Post subject: Re: Rubber part vendors |
wheel607 wrote: |
This is the case.
It is my experience that WW sells WCM rubber parts. Not the other way around. Or even better, they both sell the same Chinese manufacturer parts! That is probably it! _________________ Jimbo
TDCTDI wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Tue Aug 03, 2021 9:16 am Post subject: Re: Rubber part vendors |
VW_Jimbo wrote: |
wheel607 wrote: |
This is the case.
It is my experience that WW sells WCM rubber parts. Not the other way around. Or even better, they both sell the same Chinese manufacturer parts! That is probably it! |
WW sells WCM stuff for the parts they don't make themselves (or maybe source elsewhere) so it might be hard to know which is which.
I know on some of the Bus seals, they both make some of the same parts... and for some WW are better and some WCM are better. _________________ How to Post Photos
ncpi Samba Member
Posted: Tue Aug 03, 2021 9:38 am Post subject: Re: Rubber part vendors |
Wow... this doesn't make it easy does it. 🙃🤪
Anyone buy super beetle rear bumper grommets that fit well? |
Posted: Wed Aug 04, 2021 1:13 am Post subject: Re: Rubber part vendors |
The parts come up on the Samba all the time. The large rear bumper grommets are direct from VW.even has a VW part number and VW on them. Just look and take some time. Not everything GOOD is overnight anymore! |
ncpi Samba Member
Posted: Wed Aug 04, 2021 6:24 am Post subject: Re: Rubber part vendors |
wheel607 wrote: |
Buuut... I want it now Just kidding, I'll keep a watch out. Thanks |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Wed Aug 04, 2021 8:20 pm Post subject: Re: Rubber part vendors |
Those rubber hoses are not meant to fail so quickly. I replaced mine a few years ago and no problems.
You can also try your local autoparts store. Behind the counter they have a rack of rubber hose and tubes. Ask them to let you back there and measure them to find something that closely fits. _________________ www.vwnos.com [email protected]
