satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Mon Aug 02, 2021 4:40 pm Post subject: Self Cancelling Not Working |
This is actually on a 914 but I figured there are a lot more later Bugs out there and its the same system. Here's the deal, I have spent hours and hours trying to get my self cancelling to work. New switch, new ring, good used switch, good used ring even a different stock steering wheel. Tried greasing the mechanism. I can take a screwdriver and flick the little plastic tab and it works as it should. Putting the steering wheel on I can get it to click or maybe one side will work for a little while but it ends in failure. What am I missing?
_________________ DDC racing
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Aug 02, 2021 4:45 pm Post subject: Re: Self Cancelling Not Working |
Did you install the two metal spacer in the new switch ? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Aug 02, 2021 4:48 pm Post subject: Re: Self Cancelling Not Working |
60ragtop wrote: |
Did you install the two metal spacer in the new switch ? |
There are four metal spacers under the wiper switch. Or am I missing something? _________________ DDC racing |
Posted: Mon Aug 02, 2021 5:06 pm Post subject: Re: Self Cancelling Not Working |
Like the two screw holes on the right? _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Aug 02, 2021 5:09 pm Post subject: Re: Self Cancelling Not Working |
60ragtop wrote: |
Like the two screw holes on the right? |
Yes mine has four of them, one for each screw. _________________ DDC racing |
Posted: Mon Aug 02, 2021 6:44 pm Post subject: Re: Self Cancelling Not Working |
on a bug only two are used as shown in the pic, maybe Porsche is different? Try and loosen all 4 screws and try that, aftermarket switches tend to bind up if to tight _________________ Rick
tasb wrote: |
sb001 wrote: |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 625 Location: Louisiana
Posted: Mon Aug 02, 2021 7:25 pm Post subject: Re: Self Cancelling Not Working |
60ragtop wrote: |
Try and loosen all 4 screws and try that, aftermarket switches tend to bind up if to tight |
Agree.
Loosen screws from tight to snug and try again.
In addition, ensure tab on rear of steering wheel is striking the CANCEL tab on switch properly.
Good Luck _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
vwoldbug Samba Member
Posted: Tue Aug 03, 2021 3:56 pm Post subject: Re: Self Cancelling Not Working |
How big is the gap between the bottom of the steering wheel and the switch and housing. |
Posted: Tue Aug 03, 2021 4:04 pm Post subject: Re: Self Cancelling Not Working |
vwoldbug wrote: |
I can measure the gap to the housing but how do I measure the gap to the switch? _________________ DDC racing |
