Die Reise Samba Member
Posted: Mon Aug 02, 2021 6:59 pm Post subject: Funny find in the engine block |
So I pulled the engine for a rebuild after seeing oil drip out the tail pipe and smoking something awful when running as well as low compression on cylinders 1&2. I’m thinking valve seats and bad piston rings as the cylinders were pretty scored up. After I remove all of the engine tin, oil cooler, etc….I bore scoped through the oil sump and found two legos (I’m guessing from the previous owners kid(s)). Anyone else have a WTH story like that? I’m sure it didn’t help the engine and likely contributed it to fail, but it does have 130k on the odometer. |
Posted: Mon Aug 02, 2021 7:02 pm Post subject: Re: Funny find in the engine block |
Robw_z Samba Member
Posted: Mon Aug 02, 2021 7:11 pm Post subject: Re: Funny find in the engine block |
Nice. During a coolant flush I once found a blue shop towel, as in a heavy duty paper towel, that had gotten caught in one of the side tanks of the radiator. It had been there at least a year and I was surprised it hadn’t dissolved at all.
Unfortunately the person who left it in there was most certainly me, I just can’t recall for the life of me why I would have stuck a rag in a coolant hose somewhere.
-Rob |
Posted: Mon Aug 02, 2021 9:26 pm Post subject: Re: Funny find in the engine block |
Not harmful at all compared to the mice nest many of us have found on our air cooled engines. I think my record for spark plugs found laying under the tin is six. The most damage I have found from a minor part left behind was a socket I found in the intake port on my POS 1.9L. It blocked air flow so that one cylinder ran rich and as a result the O2 sensor caused all the other cylinders to run lean. The POS had zero compression when I bought it, but gave me 75K miles of service before it died of unrelated causes. If you figure three quarts of oil every 1000 miles, then that comes out to 225 quarts of oil. Surprisingly it never smoked except when I accidentally over filled the crankcase. |
jimf909 Samba Member
Posted: Mon Aug 02, 2021 10:10 pm Post subject: Re: Funny find in the engine block |
_________________ - Jim
Abscate wrote: |
Abscate Samba Member
Posted: Tue Aug 03, 2021 4:21 am Post subject: Re: Funny find in the engine block |
That’s a standard GEX engine part _________________ .ssS! |
4Gears4Tires Samba Member
Posted: Tue Aug 03, 2021 6:46 am Post subject: Re: Funny find in the engine block |
My 540i/6 started running a bit odd. It would cruise highway speeds at 2000rpm, but the instant I got on the throttle it would stumble. I figured I had a fuel issue so I went to replace the filter and pump.
That is a stick. The disintegrating bark had completely clogged the pump prefilter and I'm sure the filter wasn't in great shape either. Stick removed, tank cleaned-ish, pump and filter replaced, and the v8 was back to smooth running. _________________ '87 Syncro
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Tue Aug 03, 2021 7:31 am Post subject: Re: Funny find in the engine block |
You could be lucky if it tries to replicate an engine for you. _________________ This free advice is worth exactly what you paid for it.
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Tue Aug 03, 2021 8:16 am Post subject: Re: Funny find in the engine block |
be glad you didn't step on it in the dark! _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Tue Aug 03, 2021 11:30 am Post subject: Re: Funny find in the engine block |
Abscate wrote: |
That’s a standard GEX engine part |
They really that bad? |
Posted: Tue Aug 03, 2021 12:45 pm Post subject: Re: Funny find in the engine block |
Die Reise wrote: |
They really that bad?[/quote]
They aren't that bad at all, so long as you are willing to accept 2.0L heads bolted down to 1.7L cylinders and/or similar misfits elsewhere in the engine. |
