Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Mon Aug 02, 2021 7:00 pm Post subject: I need help finishing up my wiring. |
I thought I had documented my wiring well enough to be able to reconnect everything after changing out my dash, I was wrong.
I have about 3 wires I need help with.
Where does the red wire that comes from the Hazard light #30 spade go to?
Where does the white wire with 2 black stripes from the headlight switch #56 spade go to?
And what size fuse goes in the wire from Fuse #8 back to the Westfalia cabinets?
Any help is greatly appreciated! _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Mon Aug 02, 2021 8:59 pm Post subject: Re: I need help finishing up my wiring. |
Zelten wrote: |
Where does the red wire that comes from the Hazard light #30 spade go to? |
Load side of fuse #8
Quote: |
Where does the white wire with 2 black stripes from the headlight switch #56 spade go to? |
Headlight relay terminal 56
Quote: |
And what size fuse goes in the wire from Fuse #8 back to the Westfalia cabinets? |
Front dome light. White fuse. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Tue Aug 03, 2021 11:22 am; edited 1 time in total |
Zelten Samba Member
Posted: Mon Aug 02, 2021 9:20 pm Post subject: Re: I need help finishing up my wiring. |
Awesome, I thought I had figured it out and you confirmed it. The only issue is I must have mislabeled other wires going to the relay. What colored wires go to S and 30 on the relay? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Zelten Samba Member
Posted: Tue Aug 03, 2021 9:30 am Post subject: Re: I need help finishing up my wiring. |
Ok. My #9 fuse blew. There are only 2 wires going to it. One from the light switch and the other back into the main bundle. Does anyone know where I should look for the issue? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Aug 03, 2021 9:34 am Post subject: Re: I need help finishing up my wiring. |
Zelten wrote: |
Awesome, I thought I had figured it out and you confirmed it. The only issue is I must have mislabeled other wires going to the relay. What colored wires go to S and 30 on the relay? |
S will be a Brown with White stripe and there is not a 30 terminal on the relay. There is a 30 terminal on the headlight switch and it gets a fat red wire. |
Zelten Samba Member
Posted: Tue Aug 03, 2021 9:51 am Post subject: Re: I need help finishing up my wiring. |
ToolBox wrote: |
Zelten wrote: |
This is the relay I'm trying to connect.
03 Jetta TDI
15 Q7 TDI |
Zelten Samba Member
Posted: Tue Aug 03, 2021 10:16 am Post subject: Re: I need help finishing up my wiring. |
ToolBox wrote: |
Zelten wrote: |
Which fuse dose the red wire from terminal 30 on the light switch connect to? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Tue Aug 03, 2021 10:47 am Post subject: Re: I need help finishing up my wiring. |
Terminal 30 on your relay is just a retaining tang, and has no electrical connection. On the European version (and on replacement relays sold here), that terminal needs to be connected to unfused 12 volts to operate properly. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Tue Aug 03, 2021 10:52 am Post subject: Re: I need help finishing up my wiring. |
Yep...same connection for #30 on pretty much anything non-bus that uses it....and that relay actually started its life in the 411 and 412 cars as the high beam relay in 1968....hence the 411 part # prefix!
Ray |
Zelten Samba Member
Posted: Tue Aug 03, 2021 10:53 am Post subject: Re: I need help finishing up my wiring. |
telford dorr wrote: |
Terminal 30 on your relay is just a retaining tang, and has no electrical connection. On the European version (and on replacement relays sold here), that terminal needs to be connected to unfused 12 volts to operate properly. |
Thank you! There is so much I have to learn and electric is my weakness. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Tue Aug 03, 2021 10:54 am Post subject: Re: I need help finishing up my wiring. |
Zelten wrote: |
Ok. My #9 fuse blew. There are only 2 wires going to it. One from the light switch and the other back into the main bundle. Does anyone know where I should look for the issue? |
[Erroneous diagram deleted] _________________ '71 panel, now with FI
Last edited by telford dorr on Tue Aug 03, 2021 11:16 am; edited 2 times in total |
Zelten Samba Member
Posted: Tue Aug 03, 2021 10:59 am Post subject: Re: I need help finishing up my wiring. |
Zelten wrote: |
Does that work for a 1978? That's a nice diagram. I can almost understand it. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Zelten Samba Member
Posted: Tue Aug 03, 2021 11:03 am Post subject: Re: I need help finishing up my wiring. |
I also have this loose white wire with 2 black stripes. Any idea where it goes?
03 Jetta TDI
15 Q7 TDI |
Posted: Tue Aug 03, 2021 11:15 am Post subject: Re: I need help finishing up my wiring. |
The fuse block diagram does NOT apply to a '78 - sorry. On the '78 schematic, fuse #9 is a spare (normally unused). Better see what is connected to it...
From Technical (click to enlarge):
The black/white wire could be the one that runs from the ignition switch to the door buzzer... _________________ '71 panel, now with FI
Zelten Samba Member
Posted: Tue Aug 03, 2021 11:26 am Post subject: Re: I need help finishing up my wiring. |
The black/white wire could be the one that runs from the ignition switch to the door buzzer... |
I think you are correct. I looked back at some pictures I took and it looks like it connects to the same door buzzer that a grey wire connects to. So it's not being used at the moment.
Right now my #9 fuse is connected to the wire that leads to the #30 spade on the light switch. That doesn't sound correct.
I'm trying to read that wiring diagram. Where is the fuse box in that? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Tue Aug 03, 2021 11:32 am Post subject: Re: I need help finishing up my wiring. |
Fuse 9: top of columns 7, 8.
Headlight switch: columns 21-28. _________________ '71 panel, now with FI
Zelten Samba Member
Posted: Tue Aug 03, 2021 11:37 am Post subject: Re: I need help finishing up my wiring. |
Headlight switch: columns 21-28. |
I'm trying to read that, _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Zelten Samba Member
Posted: Tue Aug 03, 2021 11:58 am Post subject: Re: I need help finishing up my wiring. |
A little light reading in my future. _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
