Manny67 Samba Member
Joined: May 20, 2019 Posts: 33 Location: Lake Los Angeles, California
Posted: Wed Jan 19, 2022 1:44 pm Post subject: Re: 1967 Beetle Noob Resto Project |
I have a 1967 Beetle I probably spent about 5k in parts, that being engine rebuild, transmission, full brake system rebuilt, including wiring with some upgrades on the rear suspension like kaddieshacks adjustable spring plates.
For the engine it is a original 67 1500cc engine that someone put 160cc cylinders on it. it was single port but i had gone over to dual port because the single port heads were cracked. New bearings, engle w100 cam and lifters, with the empi hi performance shaft to get rid of the stock wavy washer that can break off and go into the engine. 7.72:1 compression ratio.
As for bolt on somewhat performance parts I now
Empi HPMX 40 center mount carburetor
CB Magnaspark II Distributor with their ignition coil, not the blue bosch coil and their brand of plug wires.
I was also running a CB serpentine belt system stock style look pulleys but currently went back to v belt, awaiting replacement parts for my serpentine system.
Full Flow Oil, using CB Performance oil pump and their oil pump cover for the full flow".
The car runs amazing although with the vbelt i lacked some acceleration compared to my cb serpentine belt system man i could feel the acceleration alot better, i think it has to do with the crank pulley being a smaller diameter compared to stock, not sure but i loved it.
Also as for the overheating issues I would start off with buying "expansion plugs' from your local hardware store and plug off those "fresh air tubes" that come sticking out of the fan shroud. It would cause your overheating issues.
dustymojave Samba Member
Posted: Wed Jan 19, 2022 4:46 pm Post subject: Re: 1967 Beetle Noob Resto Project |
You know you can bump out that dent in the roof of the blue '67 body. A friend of mine rolled his '68 Baja and it was much worse than that and he bumped it out with no prior body work experience at all. And virtually zero bondo. _________________ Richard
SoCalBajas Member
aa390392 Samba Member
Posted: Wed Jan 19, 2022 4:48 pm Post subject: Re: 1967 Beetle Noob Resto Project |
_________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Zorba2.0 Samba Member
Joined: March 07, 2017 Posts: 60 Location: Portage, MI
Posted: Thu Jan 20, 2022 5:44 pm Post subject: Re: 1967 Beetle Noob Resto Project |
What a roller coaster of a thread so far! My heart sank when i saw the status of the red one once you got it. The blue one looks way better! |
txgunslinger Samba Member
Joined: July 27, 2021 Posts: 25 Location: San Antonio, TX
Posted: Sat May 14, 2022 5:41 pm Post subject: Re: 1967 Beetle Noob Resto Project |
dustymojave wrote: |
You know you can bump out that dent in the roof of the blue '67 body. A friend of mine rolled his '68 Baja and it was much worse than that and he bumped it out with no prior body work experience at all. And virtually zero bondo. |
Thanks for the encouragement.
I’m actually more inclined to go that route honestly. It was a good excuse to buy a decent mig welder (Eastwood 180 w/ spool), and I have a donor car, but I’ve watched a ton of body work vids and other than time and patience, it can be done. I’ve got a cheap stud gun to help with the sections of the roof close to the gutter that are somewhat inaccessible from inside. I got the metal bumping book as well just to really understand moving metal around and I’m gonna try and bang it out first. If all else fails, I have the donor bug and I can patch it.
At the moment, there’s been no further progress as I am tied up finishing honey-do house projects (ugh), but I am anxious to get back to it. I don’t want to drag this out if I can help it.
While I’m wrapping up the house stuff, I think I’ll drop the tranny and ship it to Rancho for a rebuild since they are months behind. Was thinking FF gearing maybe, but I’ll probably just stick to stock as I won’t be on too many freeways anyway. Once I get it going, country road drives to the hill country for me and short trips to local meets.
Thanks everyone for the input, I really appreciate it. |
Jos.Hall Samba Member
Joined: January 29, 2011 Posts: 336 Location: Sunny So Cal.
Posted: Sat May 14, 2022 8:54 pm Post subject: Re: 1967 Beetle Noob Resto Project |
Gunslinger, if you need any parts let me know. I've got 3 '67s here in Austin and my red vert is a parts car. I wish I would've seen you needed a hood as I've got one I'd have sold ya far cheaper. Let me know what else you need.
_________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin |
Posted: Sat May 14, 2022 9:33 pm Post subject: Re: 1967 Beetle Noob Resto Project |
Jos.Hall wrote: |
Awesome brother, will do, thanks! Nice collection! |
Posted: Sat Aug 20, 2022 9:34 am Post subject: Re: 1967 Beetle Noob Resto Project |
Alright, it’s been fairly quiet here cuz life/work/etc. but a quick update…
The rusty ‘64 donor sunroof car is getting scrapped and I’m cutting into pieces today to make room in the garage. I had it listed for sale because I couldn’t bear the thought of cutting it up, but I’m over that now. I’m going to save the front window/cowl just in case I need it for the nasty axe dent on the passenger side that ‘may’ have distorted the shape of the front window… we’ll see.
As I cut it apart, I am going to see where those sunroof drain lines go and found another old thread on here about that particular issue. I’d like to replace and/or reroute mine when I get to that.
Just for fun, I’m going to cut the top off and make a pretend convertible haha. Pics later today _________________ If it's free, it's for me! |
Posted: Sat Aug 20, 2022 4:53 pm Post subject: Re: 1967 Beetle Noob Resto Project |
It’s 95 with a feels like of a 100.
Anywho, I have space in my garage again. I’m saving the front windshield section with the cowl and dash, but I’m probably not going to do anything with it except maybe make some stained glass car art. I also saved the rear engine vent. It just seemed like an iconic piece of metal to commemorate the car I just hacked apart.
I’m gonna chalk this whole experience to money wasted on something I didn’t use or need… guessing it won’t be the last time. If anyone wants the fenders, let me know. They’re far from perfect but they’re free. In fact, if there’s anything at all of value to anyone, it’s yours. I’m headed to the scrap yard on Monday. Should I take off the vehicle ID tag?
Posted: Sat Aug 20, 2022 11:23 pm Post subject: Re: 1967 Beetle Noob Resto Project |
How’s the luggage tray my vert is gonna need one and I prefer German metal if possible. _________________ PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
