pondoras box Samba Member
Joined: March 22, 2004 Posts: 1225 Location: Eerie PA
Posted: Thu Aug 05, 2021 1:21 pm Post subject: 1988 cabriolet brake booster |
I am restoring a 1988 cabriolet and am wanting to completely rebuild the brake system with all new stuff.
The problem I am having is finding a brake booster. I can find one for the earlier rabbit convertible, same body style, but nothing for the 88.
Will the earlier one work?
Thank you
Robert _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 198 Location: Porto - Portugal
Posted: Fri Aug 06, 2021 1:41 pm Post subject: Re: 1988 cabriolet brake booster |
Hum... what does it have now, 171 612 107, 155 612 107?
If so, you can fit the 191 612 107 or 357 612 107 that were in use on the Golf II and Passat.
Do you really need new? You can try reclaim a used one harvesting on the Golf II (191 612 107) or on the Passat (357 612 107). But, if it ain't broke, don't fix it Tony! |
Posted: Fri Aug 06, 2021 3:48 pm Post subject: Re: 1988 cabriolet brake booster |
I will need to check what I pulled off of it but there a lot of different versions with a letter suffix so it gets very confusing _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1957 Oval ragtop
