dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Mon Aug 09, 2021 4:51 am Post subject: Dash pod colour |
Hi all,
Just getting my 52 split deluxe finally back together. What is the colour for the dash pods? & are the knobs ivory white. Also what is the colour of hand brake & gear stick & steering column. Is the horn push the same colour as steering wheel or ivory white
Thanks for your help much appreciated
Dave |
mikeandkirsti Samba Member
Posted: Wed Aug 11, 2021 7:18 am Post subject: Re: Dash pod colour |
Deluxe pods are ivory, there is no code, you need to match the color from an original. The knobs are ivory plastic as is the horn button. Steering column tube, gear shift and hand brake lever are beige, originally L71 I think and close to RAL8025. Steering wheel is not the same color, it is slightly browner but color varies from different years so again you need match it. |
dave1 Samba Member
Posted: Wed Aug 11, 2021 8:30 am Post subject: Re: Dash pod colour |
Hi Mike,
Thank you for your help. It all ties in with what I had, although I need a colour code for the steering wheel which was slightly browner than the L71 biege. My only problem is that the restoration guy got it done in ivory for some reason so need a paint code if any one else can help would be great
Thank you
Dave |
Isbrand52 Samba Member
Joined: February 23, 2010 Posts: 55 Location: Ontario,Canada
Posted: Wed Aug 11, 2021 12:00 pm Post subject: Re: Dash pod colour |
For steering wheel the closest I found my Zwitter was a 1985 Lada color Dark Beige Code 509 I compared it to the underside of horn button. Good luck |
dave1 Samba Member
Posted: Sat Aug 14, 2021 2:46 am Post subject: Re: Dash pod colour |
Hi all,
Still trying to sort steering wheel colour as it's browner than the L71. Any help appreciated Thanks
Dave |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sat Aug 14, 2021 9:57 am Post subject: Re: Dash pod colour |
dave1 wrote: |
Hi all,
Dave |
According to my information, in Car of the Century > the dash panels or pods and dash knobs are 011 ivory-plastic (the same as L567 ivory)
Garwood goes on to say, the column housing, gear lever and brake lever are L71, beige on deluxe cars, (but different on Asure Blue cars)
I recall that the horn-push = 567 ivory and the light brown (or coffee-color, as I call it) steering wheel = L71 in most cars - are NOT the same colors - different on Asure Blue models, I was told.
All of the above info is from JT Garwood's volumes - I have been updating the incorrect info in my books, based on some feedback, from you guys - to make the volumes more correct - furthermore, the above info is for ch. no. 313830 to 397022, early 1952 with KDF-style dash
… here's a picture of my old 6/52 dash, using parts that fit, without concern for correct colors - lucky me - z
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
splitjunkie Samba Member
Posted: Mon Aug 16, 2021 7:38 am Post subject: Re: Dash pod colour |
Dash pods were only made of ivory plastic for a short time in '49. After that they were all brown/black standard bakelite painted ivory on the front. Some were painted ivory on front and back but that appears to be more in the Barndoor Bus era. _________________ Chris
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Mon Aug 16, 2021 8:54 am Post subject: Re: Dash pod colour |
And, as everyone knows, Rustoleum 'Almond' is a perfect match. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Brezelmeister Samba Member
Joined: September 11, 2017 Posts: 61 Location: Germany
Posted: Mon Aug 16, 2021 3:09 pm Post subject: Re: Dash pod colour |
splitjunkie wrote: |
Dash pods were only made of ivory plastic for a short time in '49. After that they were all brown/black standard bakelite painted ivory on the front. Some were painted ivory on front and back but that appears to be more in the Barndoor Bus era. |
That´s just wrong.
Ivory "plastic" pods were used well into 1950.
At least june (have owned circa 30 type 1s from 1950)
Have seen them on cars made as late as september 1950.
And pods painted on rear are usually a first sign of repaint. |
axel struwe Samba Member
Joined: January 18, 2005 Posts: 288 Location: Germany
Posted: Sat Oct 16, 2021 9:47 pm Post subject: Re: Dash pod colour |
Brezelmeister wrote: |
yeah, but also the original painted pods have an overspray on the the back. |
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Sun Oct 17, 2021 1:41 am Post subject: Re: Dash pod colour |
split window interior colours and their modern equivalent seems such a regular query, couldn't there be a sticky for it? _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Sun Oct 17, 2021 12:37 pm Post subject: Re: Dash pod colour |
ooops
have pm'd a thread suggestion _________________ "we're here on Earth to fart around" kurt vonnegut
