hale6968 Samba Member
Joined: August 19, 2014 Posts: 41 Location: Cleveland Ohio
Posted: Tue Aug 10, 2021 4:33 pm Post subject: 6 volt idle sensor |
I am trying to buy a 6 volt idle sensor for my Pict 30, 31. Otherwise called a electro magnetic pilot jet that screws into the right side of the carb. Only fine them for 12 volts. Any ideas where to get one? Thanks all Jeff |
mukluk Samba Member
Posted: Tue Aug 10, 2021 4:45 pm Post subject: Re: 6 volt idle sensor |
No such thing as an idle sensor for these old cars, it's just an idle cut off solenoid or electromagnetic pilot valve/jet.
I'm not aware of anybody making a new 6 volt version of the cut off, only 12 volt versions. Your options are to source a used one (there are quite a few listed in the classifieds section), or you can replace it entirely with just a simple idle jet of the appropriate size (typically g50, g55, or g60 for a 30 PICT carb). _________________ 1960 Ragtop w/Semaphores "Inga" |
mukluk Samba Member
Posted: Tue Aug 10, 2021 5:01 pm Post subject: Re: 6 volt idle sensor |
To add: if you're talking about a plunger-style idle cut off for an H30/31 carburetor and not one for a 30 PICT-1, you're not likely to find one of those in 6 volt. In this case, you can either replace the cut off with an appropriate sized plug, snip the plunger off, or (in my opinion the best option) replace that carburetor with a 6v 30 PICT. _________________ 1960 Ragtop w/Semaphores "Inga" |
67conv Samba Member
Joined: July 10, 2005 Posts: 386 Location: Simi Valley, California
Posted: Tue Aug 10, 2021 5:42 pm Post subject: Re: 6 volt idle sensor |
It's not new, but probably what you're looking for:
https://www.thesamba.com/vw/classifieds/detail.php?id=2083914 _________________ 1967 VW Convertible, owned /driven /pampered for 34 years.
1957 DKW 3=6, owned /driven /risen from the dead for 20 years.
Previously owned: 72 "Baja Champion SE" Spec. Edition Super Beetle bought NEW; 79 Convertible bought NEW; 67 type 1 savanna beige; 67 2.0 911S; 73 2.4 911T; 63 356 T6 B Cabriolet; 64 356 SC sunroof coupe; 72 Type-3 Squareback; 68 + 69 Type-3 Fastbacks; 87 Vanagon GL Wasserboxer |
Posted: Wed Aug 11, 2021 6:18 am Post subject: Re: 6 volt idle sensor |
Thanks all for coming through again. Jeff |
