Bugeye54487 Samba Member
Posted: Sun Aug 15, 2021 7:18 pm Post subject: Help with B6 engine code |
I recently bought a 1967 vw sedan. The engine code is B6. It has a pict 2 carb and a 205t distributor. The engine code is from a 1970 engine I'm pretty sure. It's a single port. Runs hot and rough idle. Are these parts compatible? |
gt1953 Samba Member
Posted: Mon Aug 16, 2021 5:36 am Post subject: Re: Help with B6 engine code |
Do tell us what you have done to the engine since you just obtained the vehicle.
Alos how hot is the engine running. What method of heat detection are you using? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Mon Aug 16, 2021 6:59 am Post subject: Re: Help with B6 engine code |
1600cc engine in an older VW with a solid engine lid can have air flow issues. VW used vented engine lids starting with 1600cc engines for 1970 year.
Ya' gots all your tins and rubber seals there????
Try the tennis ball trick, lid standoffs, etc. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
Posted: Mon Aug 16, 2021 7:26 am Post subject: Re: Help with B6 engine code |
I have replaced the spark plugs, cleaned carburetor, and reset valve gaps. The engine runs super ruff at idle until warmed up, but still runs ruff. I rebuilt carburetor and still ran poor. I put brand new pic 3 on. Still runs bad. Like a huge misfire when cold. No carb adjustment on the pic 2 carb. Just keeps running poorly. I believe it is over heating because I can't grab the dipstick and the plugs are burning very white. Ordering new cap and components. Will see if is the cure. So I am ok with pict 2 and 205T distributor? |
vwoldbug Samba Member
Posted: Thu Aug 19, 2021 9:38 pm Post subject: Re: Help with B6 engine code |
Have you checked points ( dwell ) and timing with a timing light . Also can you get a picture of the engine compartment. |
Posted: Fri Sep 17, 2021 7:37 pm Post subject: Re: Help with B6 engine code |
grvwsic Samba Member
Joined: June 14, 2004 Posts: 102 Location: SF/Long Beach
Posted: Fri Sep 17, 2021 7:52 pm Post subject: Re: Help with B6 engine code |
Looks like that red and black wire from your distributor is going to the same connection at the coil. Are you running points or electronic ignition |
Posted: Fri Sep 17, 2021 8:27 pm Post subject: Re: Help with B6 engine code |
You had me worried for a minute but here is a better picture.
Cusser Samba Member
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sat Sep 18, 2021 7:12 am Post subject: Re: Help with B6 engine code |
If what you have tried has not made a difference, then try something even more basic. Do a compression test to at least see where you are at since it doesn't sound like you have any history on the engine. Or disconnect one plug wire at a time while running and see if you can locate the offending cylinder. If you find that disconnecting one wire and the engine has no change in idle, then I think you found the culprit. Speaking of wires, how are they? Any bad spots or chaffing? _________________ Come on, It's not rocket science. KISS |
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sat Sep 18, 2021 3:05 pm Post subject: Re: Help with B6 engine code |
Cusser wrote: |
Get a shepherd's crook tube for the vacuum advance. |
Good to see that someone else knows what a crook is versus a hook. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sat Sep 18, 2021 8:20 pm Post subject: Re: Help with B6 engine code |
I took a new photo of the motor. I did run the vacuum tube up in the back higher than the outlet on carb. Does it need a higher hook? I also unplugged spark plug wires to check cylinder. 1 and 3 have a large effect on Idle, 2 and 4 have a very small effect when unplugged. Yes I am going to move the gas filter this week yet. All wires are new, cap, rotor ,points, condenser, coil are all new. Point dwell is at 47, timing is at top dead center...valves were all set and checked 3x...not going there again! Lol I will run a compression test tomorrow and see whats up. Maybe rings are bad from sitting to long? Thanks
Posted: Sat Sep 18, 2021 8:35 pm Post subject: Re: Help with B6 engine code |
I also found this on my tin...I thought maybe it was oil leak from cooler or temperature sensor. But what are these little pieces? They are not steel they wont stick ro magnet. I can any assume its aluminum but where from?
Posted: Sun Sep 19, 2021 2:01 pm Post subject: Re: Help with B6 engine code |
My eyes are deceiving me . The new pic shows what looks like an H30/31 carburetor. I always clean the two jets on the right side -- sometimes it gets crud. |
Posted: Mon Sep 20, 2021 8:30 pm Post subject: Re: Help with B6 engine code |
raydog wrote: |
If what you have tried has not made a difference, then try something even more basic. Do a compression test to at least see where you are at since it doesn't sound like you have any history on the engine. Or disconnect one plug wire at a time while running and see if you can locate the offending cylinder. If you find that disconnecting one wire and the engine has no change in idle, then I think you found the culprit. Speaking of wires, how are they? Any bad spots or chaffing? |
Cylinder 1 is 125lbs, 2 and 3 are at 110lbs and 4 is at 75lbs. Lot of oil on the jug of cylinder 4. |
Slow 1200 Samba Member
Posted: Tue Sep 21, 2021 1:18 am Post subject: Re: Help with B6 engine code |
The PICT2s are hit or miss, sometimes they are worn beyond adjusting and also like to get dirty in places that are almost impossible to clean properly. The H30/31 on the other hand doesn't play great with the 205T in my experience, you would be better off with a (decent) centrifugal distributor
and of course the low compression on #4 has to be dealt with too |
raydog Samba Member
Posted: Tue Sep 21, 2021 4:40 am Post subject: Re: Help with B6 engine code |
Bugeye54487 wrote: |
raydog wrote: |
There ya go! Now you've got a place to start looking. Stop messing with the other stuff and see what's going on with #4. _________________ Come on, It's not rocket science. KISS |
Posted: Wed Sep 22, 2021 6:25 pm Post subject: Re: Help with B6 engine code |
Thank you for your guidance. I have to pull engine to diagnose exactly what is happening. |
