kingkarmann Samba Member
Posted: Tue Sep 28, 2021 5:53 am Post subject: Re: Introducing Joan! |
Rome wrote: |
Congratulations on Joan's first show results, and the pleasurable drive! Were some spectators doing double-takes as to how correct and overall beautiful the car was? Usually you only see that level of factory detail on Porsches. |
The ones that really stopped to take a closer look seemed to enjoy her. There were a few working on projects that took photo's. I did include some history of Joan. If someone was inclined to read it the would have realized the details
Interestingly Sophia is more an attention magnet _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Trylon Samba Member
Joined: August 16, 2019 Posts: 4853 Location: Connecticut
Posted: Tue Sep 28, 2021 6:30 am Post subject: Re: Introducing Joan! |
Vicarious thrill here— thanks for sharing! _________________ 1973 Porsche 914 2.0
1959 Volkswagen Karmann Ghia
1979 Volkswagen Rabbit
1973 Volkswagen Bus
1970 MGB-GT
1962 Oldsmobile Jetfire
More tomfoolery on
The Karmann Ghia Fever YouTube Channel! |
Posted: Tue Sep 28, 2021 6:49 pm Post subject: Re: Introducing Joan! |
I installed the NOS Beauty Rings from Alex and his crew at ISP West.
He said they were just waiting for this moment after sitting in a box for 50+ years.
Of course the rings needed a bit of polish but WOW! They are some serious jewelry. VW should have put a warning in the owners manual to make sure not to use a pry bar or screwdriver against those soft aluminum rings to pop the hubcaps. Unfortunately almost everyone did.
The wheels now look really fantastic😎
Mike Gerson
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Tue Sep 28, 2021 7:51 pm Post subject: Re: Introducing Joan! |
**gasp!** You didn't use Autosol for the polish ?? Okay, I kid (though it's the best ). Seriously, what a splendid difference those trims make against that shiny red car... WOW!!
Now, if you EVER take your car into the shop for ANYTHING, remove the trims FIRST! Don't question it, just do it . There will be no reason whatsoever to touch your wheels, BUT invariably, the trims will come back damaged! Because the shop/mechanic (insert stupid excuse here!) Fair warning _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Wed Sep 29, 2021 5:27 am Post subject: Re: Introducing Joan! |
67 Florida Deluxe wrote: |
Now, if you EVER take your car into the shop for ANYTHING, remove the trims FIRST! Don't question it, just do it . There will be no reason whatsoever to touch your wheels, BUT invariably, the trims will come back damaged! Because the shop/mechanic (insert stupid excuse here!) Fair warning |
Flitz is a German engineered polish
And thanks for the heads up! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Wed Sep 29, 2021 5:31 am Post subject: Re: Introducing Joan! |
So, years ago I made a "custom" puller. It consists of coat hanger wire and fuel line. Works great! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Braukuche Samba Member
Posted: Wed Sep 29, 2021 7:17 am Post subject: Re: Introducing Joan! |
That’s some bling King. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Trylon Samba Member
Posted: Wed Sep 29, 2021 8:51 am Post subject: Re: Introducing Joan! |
Nice!
Are these really something that can be taken on and put back on at will?
I am only familiar with those that can not be put on at all and come off whenever they wish. _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Wed Sep 29, 2021 9:07 am Post subject: Re: Introducing Joan! |
Trylon wrote: |
Nice!
I am only familiar with those that can not be put on at all and come off whenever they wish. |
Now your making me consider a separate insurance rider!
Yup!
Easily albeit carefully removable. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Wed Sep 29, 2021 2:47 pm Post subject: Re: Introducing Joan! |
Quote: |
Are these really something that can be taken on and put back on at will? |
Yes, indeed. To further explain King's response, the inner edge of the ring is held down by the bottom edge of the hubcap. The hubcap sits snugly against the rim center hub, kept in place by the 4 wedge-shaped bumps in the wheel hub that catch inside the hubcap. You can see the 4 bumps on this stock-style wheel from Stock Steve's gallery-
The outer edge of the ring rests against the outer shoulder of the rim. 4-bolt rims had various widths (4.0", 4.5") and offsets (ET40, ET34, ET41, ET46) so that the ring really needs to be matched to the rim so that the ring's slight bevel outer edge presses slightly against the rim, pressed down by the hubcap. On properly fitting rings, there is no relative movement between the ring and the wheel, nor is there any friction from retaining prongs, etc. So "ideally" the ring can be removed and installed many times by pulling off the hubcap before there is any scuffing of the rim paint.
This particular rim has a deeper dish than for an OG Ghia rim- the hubcap contact surface is farther down/inward/deep than the outer edge of the rim where the outer edge of the ring would sit. If Steve attempted to install the Ghia beauty ring, the outer edge of the ring would rest against the rim but the center edge would be about 1/2" up off the rim. The rings would not be able to be correctly fitted. |
Posted: Wed Sep 29, 2021 3:52 pm Post subject: Re: Introducing Joan! |
Great info Rome!
On another subject, The license plate frame from the dealership where Joan was sold new on April 28, 1967 arrived today.
After Flitzing” it I deciding that it looks really nice with the paint chipping and chrome pitting. I think it adds character 😎
Ted Trudon Volkswagen
Terryville Conneticut
Peer pressure
And yes, those are old pushrods that the seller used to reinforce the package from bending. Ingenious!
Mike Gerson
Trylon Samba Member
Posted: Wed Sep 29, 2021 4:57 pm Post subject: Re: Introducing Joan! |
Your license plate even looks like old CT — blue and white!
Now anyone have a New Milford Motors one? _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Wed Sep 29, 2021 6:14 pm Post subject: Re: Introducing Joan! |
My apologies to the good people of Conneticut
Talcottville
Not terryville 😳 _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Sat Oct 02, 2021 3:55 pm Post subject: Re: Introducing Joan! |
Show season around here is winding down around here.
We had a local car show just around the corner.
Drove Joan, called the wife who picked me and took me back to the garage. Grabbed Sophia the 3 miles to show.
So much fun!
Mike Gerson
Posted: Thu Oct 07, 2021 2:51 pm Post subject: Re: Introducing Joan! |
"Winter Is Coming"
I believe that's the line from Game of Thrones.
I may be able to get Joan out a time or two before calling it quits for the season.
Just want to thank you all for the positive vibes.
It truly was a dream come true!
My plans are to submit an application for consideration to the Ault Park Concours in Cincinnati. Ault usually has a fairly high bar for selection but I think she has a good chance.
A may also might try the Dayton Concours. I've had Sophia there a couple of times.
I have some prep work to do over the winter. I have one nagging issue, the battery.
I would love to find a vintage style 12v battery that would be correct for our Ghia's. I've searched high & low. No luck. Any suggestions? _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Trylon Samba Member
Posted: Thu Oct 07, 2021 4:42 pm Post subject: Re: Introducing Joan! |
kingkarmann wrote: |
Talcottville
Not terryville 😳 |
Just realized that you have to apologize to the good people of Connecticut again! _________________ 1973 Porsche 914 2.0
1973 Volkswagen Bus
1970 MGB-GT
More tomfoolery on
Posted: Fri Oct 08, 2021 5:53 am Post subject: Re: Introducing Joan! |
Trylon wrote: |
Talcottville
Not terryville 😳 |
Just realized that you have to apologize to the good people of Connecticut again! |
I think I have to apologize to my teachers too _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
