Emily_is_going_Westy Samba Member
Posted: Mon Aug 23, 2021 10:17 am Post subject: Replacing expansion tank |
Hey all! Replacing the coolant expansion tank and sensor today (as soon as it arrives)! Any notable advice? Moral support? Must have tools? I was told to refill the tank with coolant that was in the original tank and top it off with more coolant then burp it. Lol! I was like “like a baby!?!?” Mechanic said “pretty much” I had babies, I can do that.
I have a ‘90 Vanagon multivan westfalia _________________ Her name is Greta she is a 1990 Westfalia Weekender Multivan |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12103 Location: Port Manteau
Posted: Mon Aug 23, 2021 10:46 am Post subject: Re: Replacing expansion tank |
If you use coolant hose clamps, you can minimize the coolant loss, and thus the need for significant air bleeding. Just be aware that the plastic tanks on the market now have a dismal record of early failures. I strongly recommend the GW aluminum tank. I swapped one into a 2.3 WBX Multivan a few months ago. That van had two tank failures in five years--no more. It's pricey, but worth it in the long term. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16474 Location: Brookeville, MD
Robw_z Samba Member
Posted: Mon Aug 23, 2021 11:25 am Post subject: Re: Replacing expansion tank |
There is some plastic tank which is of good repute, I think GoWesty sells it. I have had it installed for three years, still good.
That said if you have the money buy a metal tank. If you were unaware of the bad reputation of many plastic tanks, be aware there is one and consider researching if the one you ordered isn't due to cause you suffering in the future.
-Rob |
Posted: Mon Aug 23, 2021 11:32 am Post subject: Re: Replacing expansion tank |
Thanks guys! Both metal and plastic tanks are out of stock at GW so just to get her going again (my daily driver) I had to order a plastic one from van-again. I will for sure be keeping a close eye on the tank. The metal one is in my future as soon as they are available again!
Hose clamps-check. _________________ Her name is Greta she is a 1990 Westfalia Weekender Multivan |
valvecovergasket Samba Member
Posted: Mon Aug 23, 2021 12:29 pm Post subject: Re: Replacing expansion tank |
I'm certainly no GW fanboy, but I do like the sight glass on the side of the tank. This really helps with refilling the tank at the end of the swap. _________________ Casey--
y u rune klassik? |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9776 Location: Mt Lemmon, AZ
Posted: Mon Aug 23, 2021 1:58 pm Post subject: Re: Replacing expansion tank |
Emily_is_going_Westy wrote: |
...I was told to refill the tank with coolant that was in the original tank and top it off with more coolant then burp it... |
The 'burp it' step may be a bit more involved than simply topping up the new tank -- depending on how much coolant gets lost and how much air gets in you may need to bleed the cooling system to get it full enough.
Lots of superstition, tricks and voodoo on this subject in the archives.
I use an electric pump but the 'Libby Bong' method seems to work well for many. A search on that term should turn up an exhaustive thread.
It is important to get the system pretty full (by bleeding) - once you have done that any remaining air will usually find its way to the tank so you just top it up (cold engine) a few times after a heat cycle. |
DeLvxe Samba Member
Joined: January 08, 2019 Posts: 104 Location: Seattle
Posted: Mon Aug 23, 2021 2:43 pm Post subject: Re: Replacing expansion tank |
Does anyone know about the special "subaru bracket" that van cafe sells. Is this necessary if I am replacing the tank in my already-swapped van? _________________ 1991 manual camper with EJ25 |
Posted: Mon Aug 23, 2021 2:46 pm Post subject: Re: Replacing expansion tank |
DeLvxe wrote: |
Does anyone know about the special "subaru bracket" that van cafe sells. Is this necessary if I am replacing the tank in my already-swapped van? |
probably depends on what youve got going on for mounting tabs in your bay already.
i used one when putting that tank in my tdi swap
https://www.vancafe.com/RMW-ALB-p/rmw-1002104.htm
just lets you hang the tank on something. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Thu Sep 23, 2021 7:42 am Post subject: Re: Replacing expansion tank |
Hey party people! I did it! I replaced the coolant tank with the help of my 12 year old son. This van has been an amazing thing for him and I. He is learning some valuable things on her that I’m sure he will take with him the rest of his life.
Some things I learned:
It’s messy.
Get good hose clamps (the plastic ones are meh)
Hoses are persnickety
Make sure the temp thermometer is really really on tight
It’s messy (needed to be repeated)
It wasn’t as scary as I thought when all was said and done
I went with the plastic tank for cost purposes. I will replace with the metal one for sure down the road (pun har har).
Have a great day everyone!!! Thanks for the support 🥰 _________________ Her name is Greta she is a 1990 Westfalia Weekender Multivan |
4Gears4Tires Samba Member
Posted: Thu Sep 23, 2021 9:51 am Post subject: Re: Replacing expansion tank |
I didn't realize plastic hose clamps were a thing and I would definitely not use them.
Glad you got it sorted! _________________ '87 Syncro
