68 Ghia Vert Samba Member
Joined: August 30, 2011 Posts: 51 Location: Baltimore Md
Posted: Mon Aug 23, 2021 5:31 pm Post subject: Newton carpet question |
Anybody who has installed a newton carpet kit did you guys have to trim parts of the wheel well piece that hangs into back seat area?
Marcdeb Samba Member
CruisinMark Samba Member
Joined: July 09, 2006 Posts: 56 Location: Nanaimo, BC, Canada
Posted: Fri Sep 10, 2021 11:51 am Post subject: Re: Newton carpet question |
My Dad has just bought a set of Newton carpets for his 1961 RHD Ghia coupe. There is no allowance for the floor mounted headlight dip (high beam) switch. Does anyone have a photograph of how the original carpet was made in this area please? We're not sure if there should be a grommet in the carpet or if the dip switch should be fitted on top of the carpet and a small hole punched through for the wires, which is what Newton has suggested to him. Thank you in advance. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Sat Sep 11, 2021 10:54 am Post subject: Re: Newton carpet question |
CruisinMark wrote: |
There is no allowance for the floor mounted headlight dip (high beam) switch. Does anyone have a photograph of how the original carpet was made in this area please? |
Ghias never had carpet right behind the pedals and around the dimmer switch. A rubber mat was the only thing covering that area.
You can do whatever you want to accommodate the switch, since that spot was never carpeted in the first place. An auto upholstery shop should be able to cut a hole for the switch and trim it out with a suitable vinyl grommet.
_________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Sun Sep 12, 2021 4:15 am Post subject: Re: Newton carpet question |
This seems like a very odd place to put the dimmer switch. I've never driven a Right Hand Drive car, but how do you get around the clutch pedal to use the switch? Fin fact, I don't see any convenient area for the switch with a RHD? _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Sun Sep 12, 2021 1:45 pm Post subject: Re: Newton carpet question |
Marcdeb wrote: |
This seems like a very odd place to put the dimmer switch. I've never driven a Right Hand Drive car, but how do you get around the clutch pedal to use the switch? Fin fact, I don't see any convenient area for the switch with a RHD? |
Its a proper PITA manoeuvring your foot around the clutch. My '61 had that and I hated it. Fortunately the '66 has a button on the flasher stalk and a headlight relay featuring a toggle function. Much nicer to use.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Posted: Fri Sep 17, 2021 2:15 pm Post subject: Re: Newton carpet question |
Thanks Gents. We appreciate the input. |
