pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Thu Aug 26, 2021 9:15 am Post subject: All the Vanagon shops are out of rear latch extender! |
The big 4 van parts sellers (GoWesty, Bus Depot, etc) are all back-ordered on the hatch latch extender for Vanagons. Mine seems to have taken a walk during the past year-and-a-half of Pandemania, so I need a replacement. If anyone knows of a source that I’ve missed please let me know. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6245 Location: Portland OR
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3094 Location: ABQ NM USA.... Except when not
Posted: Thu Aug 26, 2021 9:44 am Post subject: Re: All the Vanagon shops are out of rear latch exteder- got one FS? |
And this is an option
Smaller form factor
Secure - can't be unscrewed
Less $
5/16 IIRC....1/4 will slip over the body side latch
Eventually I'm thinking a piece of heat shrink tubing to cover the threas
I can make one for you but shipping will be more than the part....check out your local True Value/Ace
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Thu Aug 26, 2021 11:07 am Post subject: Re: All the Vanagon shops are out of rear latch exteder- got one FS? |
the PDXWesty turnbuckle above is what I have used for a few of mine now. To secure it, a few good whacks with a hammer on the ends (peen hammer above and below, to get into the ditch) and then the mangled threads won't allow the full removal of that device by unscrewing it. It is really good to have the ability to change the gap for a variety of temps. Epoxy would also get the job done. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Aug 27, 2021 9:54 pm Post subject: Re: All the Vanagon shops are out of rear latch extender! |
Free bolt from the garage...and matching nut if you're lucky:
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Aug 28, 2021 5:14 am Post subject: Re: All the Vanagon shops are out of rear latch extender! |
[quote="dhaavers"]Free bolt from the garage...and matching nut if you're lucky:
Did you do the bends 'cold', or did you use a torch to soften the spots where you did the 90 degree bends? |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1645 Location: Budapest Hungary, Europe
Posted: Sat Aug 28, 2021 10:20 pm Post subject: Re: All the Vanagon shops are out of rear latch extender! |
pinetreeporsche wrote: |
dhaavers wrote: |
Free bolt from the garage...and matching nut if you're lucky... |
Cold...bench vise...BF hammer...done. It's only 1/4", IIRC...
"The WonderVan"
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
