Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Thu Aug 26, 2021 11:21 am Post subject: Syncro: Cut protection bar access for gearbox oil drain plug |
This thread is kinda "late" in the Syncro life cycle.
.....towards 30 years and a few rebuilds too late.
Lack of gearboxes will soon doom lots of nicely built-out vans to sit behind the barn.
That day is coming and it's not a happy day.
2WD vans have Subaru gearbox options (time will tell if they can push the brick....).
But there's no hope for a Syncro gearbox replacement with a compound low gear and a differential locker.
If you have a Syncro, it's wise to cut around the gearbox oil drain plug to reduce this 'barrier to proper maintenance'.
I suspect a lot of Syncro owners, knowing they have a "special antique" would have harumphed the (VW self-serving) manual stating that the gear oil 'does not need to be checked or changed';
only to slide under the van, noting the difficulty, decided it would be a big hassle to change the gear oil.
Perhaps to do it 'later'.
And then 'later' became after it started to 'make noise'.
Which is far, far too late.
The trans is worn out. And sadly, due to 'non-maintenance'.
Probably NOT intentional non-maintenence, but cultural non-maintenance.
Nobody else was maintaining their Vanagon transaxles.
I suspect many attentive vehicle maintainers fell into this trap.
It's ironic how the "protection bars" have actually DOOMED Syncro transaxles by creating a significant impediment to maintenance, moreso than 2WD.
Here's the best pic I can come up with.
If any Syncro owners would crawl under the van and take a pic of what
the 'gearbox drain area' will see from under the van,
I'm sure that other Syncro owners would appreciate it.
30 years may be late in the game, but better late than never!!👍🏽👍🏽
IMHO, a Syncro in the 1st 100k miles the oil should have been changed the first 500 / 1000 miles to flush out the break-in trash, then thereafter every 30k miles.
An "old trans" that's still quiet should be maintained every 15,000 miles.
A rebuilt trans (which has new bearings and old gears) should be changed every 15,000 miles.
Any trans with a big engine hanging on it should be changed every 10,000 or every other engine oil change. If your drainplug magnet is coming out clean at 10,000, you can reasonably extend your interval.
But ya gotta LOOK at the magnet to know this. _________________
....KTMs, GasGas, SPOT mtb |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Thu Aug 26, 2021 12:28 pm Post subject: Re: Syncro: Cut protection bar access for gearbox oil drain plug |
Sodo wrote: |
But there's no hope for a Syncro gearbox replacement with a compound low gear and a differential locker. |
I don't completely agree with this, although I do agree that the need for a new replacement gearbox is critical.
https://www.thesamba.com/vw/forum/viewtopic.php?t=665489&highlight=
There are quite a few Syncros out there that have had significant money spent on them, and there are people already working to keep them rolling like Gears and Weddle Industries. _________________ Currently:
jberger Samba Member
Posted: Thu Aug 26, 2021 1:35 pm Post subject: Re: Syncro: Cut protection bar access for gearbox oil drain plug |
I definitely used a hole saw to radius an access hole to the drain plug then cut through with a sawzall. Oddly enough the only Syncrodemayo I attended resulted in that cross member getting smashed up against the diff cover creating a weird rattle. I cut it off when I got home and it's lived in the same spot between my garage doors since. C'est la vie
J |
Sodo Samba Member
Posted: Thu Aug 26, 2021 1:43 pm Post subject: Re: Syncro: Cut protection bar access for gearbox oil drain plug |
MsTaboo wrote: |
there are people already working to keep them rolling like Gears and Weddle Industries. |
Yes we are blessed by this, currently.
Weddle does it mostly because their racing gearboxes are VW design based and use some VW parts. But some are made for racing toughness, and expected to be changed (like at 50k miles) rather than the 100-150k that we like to expect from VW gears. Better than nothing…..
This luck can’t last forever.
When the number of Syncros drops to below the sustainable numbers there will be no more parts. Or a long stretch of NLA until the number of preorders reaches a threshold to order a batch. That causes a dry spell in between where all the rebuilds have to be assembled with “the best used parts findable”.
There’s currently a Syncro needle bearing that’s gone NLA. So keep your oil clean in case you have to re-use your old bearing. And certainly don’t drive it if the trans is making noise.
If it’s noisy you KNOW the oil is fulla metal, destroying other parts.
Such as that NLA bearing at the nose of the mainshaft - you may have to re-use it.
Samba member “gears” (GT Gears) does it because he’s a Syncro fanatic, we all gotta be thankful for that. But again, how long can Porsche quality gears at VW prices possibly last? It makes some sense to buy your GT spares now, in case your increased maintenance extends your trans life to the days when more critical parts (or skilled rebuilders) have gone NLA.
And at some level it makes sense to rebuild now, even if it’s quiet, but the skill and knowledge of the builder is paramount. Otherwise (if its quiet) it could be best to leave well enough alone rather than risk a crap build, and just use attentive maintenance a light foot and no lugging.
Anyway it makes sense to maintain your Syncro gearboxes!
Cut that protection bar so its “easy” to change your gearbox oil - thats the cheapest insurance there is. 👍🏽👍🏽👍🏽
Let’s see a pic of the “OEM covered” drain plug, and some pics of access cuts.
And how you cut it. _________________
dkoesyncro Samba Member
Posted: Thu Aug 26, 2021 8:20 pm Post subject: Re: Syncro: Cut protection bar access for gearbox oil drain plug |
Sodo,
I hear you and I get what you're saying but I'm picking up another message in this PSA...I don't like it! |
Sodo Samba Member
Posted: Fri Aug 27, 2021 8:32 am Post subject: Re: Syncro: Cut protection bar access for gearbox oil drain plug |
jberger wrote: |
J |
Its pretty easy to straighten it.
A least you can maintain your trans (and keep an eye out to avoid rocks).👍🏽
RMW Syncro conversions have no skid bars at all, which could work out better for the trans (but adds risk for the engine).
dkoesyncro wrote: |
Sodo,
I hear ya. Time marches on.
I'm going under the van today, in the gravel. I've been thinking a lot about a vehicle lifts as of late.
I can still go under the van like a monkey, but incrementally, will be somewhat older when I come out.
Wish me luck.
In 10 years the landscape will have changed.
How much longer can one Samba feller maintain a campaign to thwart the non-maintenance culture that VW started?
Maintenance now is better late than never, especially for such a special antique as a Syncro.
Syncro protection bars doomed the transaxles instead of preserving them.
Don't think twice about cutting a little drainplug access.
Drainplug access at least implies that "transaxle maintenance is important to this owner'.
I cringe when I see one without drainplug access. _________________
