iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Tue Aug 31, 2021 4:14 pm Post subject: roof top tent - dummy idea |
indulge my goofiness on this one.
could you permanently attach this to say a full size cargo van and cut the roof so you would have a pop top ?.
i'm thinking something like this.
https://www.campingworld.com/venture-forward-hard-...lsrc=aw.ds
and make the floor of the pop top fold back or somesuch so you can have a bed.
I'm thinking biggest problem is leaks? and perhaps attaching it to the roof.
whip out the naysayers |
mukluk Samba Member
Posted: Tue Aug 31, 2021 8:52 pm Post subject: Re: roof top tent - dummy idea |
Seems to me like it would work. _________________ 1960 Ragtop w/Semaphores "Inga" |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Wed Sep 01, 2021 2:40 pm Post subject: Re: roof top tent - dummy idea |
I’m sure anything is possible. My first thoughts would be:
1) Most vans have some sort of curve to the roof, so mounting / sealing could be a challenge.
2) The fibreglass shell of the tent might lose its structural integrity if you cut out a chunk of the base big enough to crawl through.
I’m sure theses issues can be overcome, but I don’t see it being an easy job. It would be interesting to see what you come up with. For whatever it’s worth, personally I would just mount the tent on racks like it is designed, and use an exterior ladder (you’ll probably need to climb up the exterior anyway to unlatch the tent case even if you had an interior access). It means you won’t have any mounting or leakage issues, and your van and tent won’t both be permanently altered if you ever wanted to sell or changed your mind on the mod. But if the modification makes your van more functional and enjoyable for you, then go for it! |
Posted: Wed Sep 01, 2021 6:12 pm Post subject: Re: roof top tent - dummy idea |
CanStan wrote: |
good thoughts , thanks - sometimes the path of least resistance is best as you point out |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Wed Sep 01, 2021 7:14 pm Post subject: Re: roof top tent - dummy idea |
Uhh, with a full size van, why would you want to cut a hole in the roof to graft some barely temporary roof top tent into it?
Do some research, those rooftop tents are known to have leak issues, canvass failure, & other frame/structure issues. Sounds like a great way to piss away lots of money. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Sep 03, 2021 11:49 am Post subject: Re: roof top tent - dummy idea |
hmm, doing my research here.
these alleged roof top tent leaks, to they occur with it open or closed?
I was thinking the roof top tents would be pretty firmly attached to roof structure ,
curve is roof would be a real problem. have to go check flatness of roof now.
still seems cheaper than having someone put a real pop top on. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12739 Location: Western Canada
Posted: Fri Sep 03, 2021 6:22 pm Post subject: Re: roof top tent - dummy idea |
Another thing you might want to consider is that with the value of VW Busses high and on the rise an unmolested tin top just might hold a better future value than one with a great hole whacked in the roof and a makeshift tent that you can no longer get repairs for on top. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Fri Sep 03, 2021 6:32 pm Post subject: Re: roof top tent - dummy idea |
oprn wrote: |
Another thing you might want to consider is that with the value of VW Busses high and on the rise an unmolested tin top just might hold a better future value than one with a great hole whacked in the roof and a makeshift tent that you can no longer get repairs for on top. |
I get the impression this is a non-VW van the OP is talking about here. But either way, my thought is this- you will potentially devalue both the van and tent by thousands of dollars. Is the ability to access the roof top tent from the inside worth thousands of dollars to you? If the answer is yes, then great, I say go for it. Do what you like and whatever makes the van the most useful and enjoyable for you. But if you’d rather pocket a few thousand extra dollars when / if you plan to ever sell, I’d say don’t cut a hole.
I still think that either way, you’ll need an exterior ladder to climb up the outside to unlatch the tent. So other than being able to wiggle down into the van in the morning without going outside, I personally don’t see a massive advantage to putting in all the time / money / effort. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Fri Sep 03, 2021 10:37 pm Post subject: Re: roof top tent - dummy idea |
Wouldn’t you be degrading the structural integrity of the van? _________________ "Albatross"! |
mukluk Samba Member
Posted: Sat Sep 04, 2021 12:14 pm Post subject: Re: roof top tent - dummy idea |
calvinater wrote: |
Wouldn’t you be degrading the structural integrity of the van? |
Depends on the size of the hole and whether or not it's braced. _________________ 1960 Ragtop w/Semaphores "Inga" |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Sat Sep 04, 2021 2:15 pm Post subject: Re: roof top tent - dummy idea |
I'd Build a rack, so the tent would have a porch, and a ladder to make climbing up easier.
I wouldn't cut up any van, for this project, it's not required, climbing trough degrades the space in the van, and in the tent. _________________ Good Luck
Al |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Sep 04, 2021 3:54 pm Post subject: Re: roof top tent - dummy idea |
I'd build a rack with a storage box on it (possibly with folding sides for aerodynamics when not in use), then I'd shovel all the crap that's inside the van into the roof box and sleep in the van.
For similar money to the roof tent you could buy a roof clip from a later Westfalia, graft that into the van roof and enjoy a well made, non leaking upstairs sleep if you wish. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
TrulyVintage Samba Member
Joined: April 13, 2008 Posts: 207 Location: Direct Enclosed Transporter
