Posted: Thu Sep 02, 2021 11:57 am Post subject: Engine Cooling |
Question,.. years ago it was common for folks to remove the factory oil cooler and adapt a larger cooler to the front side of the fan intake. It supposedly improved efficiency by unblocking air flow to cylinders 3 & 4. Living in the desert, it's important.
Is this still practiced and does anyone have an opinion?
Thanks, Jim. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Thu Sep 02, 2021 1:20 pm Post subject: Re: Engine Cooling |
No one does it anymore. Putting a cooler in front of the fan just pre heats the air that cools the engine. _________________ Glenn
Member #1009
#BlueSquare |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Fri Sep 03, 2021 6:45 pm Post subject: Re: Engine Cooling |
[email protected] wrote: |
Thanks, Jim. |
You can add a vw empi external oil cooler with and electric fan the kit also comes with a oil thermal Stat... |
Glenn Mr. 010
Starbucket Samba Member
Posted: Sat Sep 04, 2021 3:03 pm Post subject: Re: Engine Cooling |
We ran back and forth from Long Beach to Vegas doing 80 plus and once over the border and in NV we floored the rest of the way in and never over heated and this was probably 3 times a year. Watch your oil temp. it will tell you if you need something fixed. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Sun Sep 05, 2021 2:35 pm Post subject: Re: Engine Cooling |
Starbucket wrote: |
You're lucky. The NHP typically has cars camped out on the I-15 NB onramps in Primm (ex-Stateline) to wait for folks speeding down the mountain from CA. I've seen them pop more than a few folks which is why I never speed through there. |
Posted: Sun Sep 05, 2021 2:54 pm Post subject: Re: Engine Cooling |
Jon Schmid wrote: |
Starbucket wrote: |
Back in the 60's NV had no speed limit away from towns so it was peddle to the metal once you hit the city limits or crossed into NV. |
Posted: Wed Sep 08, 2021 7:19 pm Post subject: Re: Engine Cooling |
Starbucket wrote: |
Jon Schmid wrote: |
Starbucket wrote: |
Good luck trying that now... |
Posted: Thu Sep 09, 2021 7:04 am Post subject: Re: Engine Cooling |
Jon Schmid wrote: |
Starbucket wrote: |
Jon Schmid wrote: |
Starbucket wrote: |
I know all good things come to an end. |
